09-24-2018, 12:01 AM | #1 |
Rep 72
Question about 02 sensor code 128E01
So, the last couple of days I've had issues with the idle on my 2013 335i. It started out with the idle being a little rough and it developed into an unstable idle where at stops it would almost constantly rev between 600 & 750 RPM, occasionally jumping up above 1000. Then it developing into this uneven idle followed by dying. It'll restart fine, but after a few seconds of consistent idle it goes right back into this little routine. Now, it the throttle will even jump a bit, and feel like it's down shifting during mild acceleration at slow speeds. Once I get up to 40+ MPH it seems fine.
It started out just an occasional occurrence, but has become a consistent problem over the last few days. So, I ran codes and it gives me a 128E01 fault code. I can clear it, drive a bit until the car acts up, and the code is back. The fault explanation is: Lambda probe upstream of the catalyst, electrical: interruption Nernstleitung. Obviously, the code sounds like the pre cat O2 Sensor is bad, but I just wanted to confirm that the this is the kind of symptoms you'd might expect to see from a bad O2 sensor. I did a search and found things like poor gas mileage and rough idle, but nothing to this extreme. Also, does anyone have any experience with a bosch O2 sensor vs. the OEM? Any feedback before I order the sensor tomorrow would be greatly appreciated. |
09-24-2018, 12:19 AM | #2 | |
Rep 72
07-02-2019, 02:12 PM | #3 |
Dream crusher
984
Rep 2,421
What was the outcome on this? Did the precat sensor replacement resolve the problem? I ask because I'm getting that error too on my N55.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
