11-27-2018, 01:16 AM | #1 |
Rep 4
Hey guys need some help here. So randomly the other day I got a "lighting malfunction" warning on my dash then went on to realize when I use the turn signal it clicks very fast but does not work in the rear. However if I press the hazard button the signals then work in the back. So already that confused me. I then went to turn my back window down and it did not work, and also my PDC stopped working. Finally I noticed my trunk wouldn't open. I thought this was all a problem from me coding my car via the Carly app but when I went to check, the REM module wasn't even being recognized anymore. I tried unplugging the module (one of my tail lights then do not work) and plugging it back in (then my tail light works again, so it's getting power). Nothing. Indicator PDC and rear windows still not working. Is there a specific pin I should check that controls these things to see if something is unplugged? or is my REM faulty. thanks guys :/
11-27-2018, 10:48 AM | #2 | |
Rep 4
11-27-2018, 07:20 PM | #3 |
Rep 1,170
Advise you post this in the coding section, hope someone there can help. Good Luck!
https://f30.bimmerpost.com/forums/fo...play.php?f=429
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
bmw, coding, electronics, f30, module, rem |
