BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding??
      06-02-2019, 05:10 PM   #1
whatevs
Drives: 2016 bmw 328
Coding??
Hi Guys - Please pardon if my question sounds stupid (BMW newbie) - What is coding? Is it something I could easily do, and would it affect warranty?
      06-02-2019, 06:28 PM   #2
KingpinRCR
Belgium
61
Drives: F30 320d ed
Coding is changing parameter in your car’s ecu’s. You can add options for example or change start up emblems on your combi, enable/disable things like start/stop, dvd while moving, disclaimers,... there are a lot of,things you can change.
It’s not that hard, you just have to follow the right procedure (wich you can learn easily).
I don’t know for sure about the warranty, but I bet it will be void if all goes wrong.
But if you just stick to the tested coding and follow procedure you’ll be fine. I don’t know anything about computers but I can code my car.
      06-03-2019, 06:03 PM   #3
balsingh458
Drives: F30 320xi MSport (2012)
There's tons of threads on here so I have no idea where to start. Worked out that I need a lead to connect to my laptop and some software.
Any pointers to a few threads from where I can look to start obtaining these?
Note that I am based in the UK and drive a F30 so would need to be ideally be able to source the lead from the UK
Thanks in advance
OP - sorry, didnt mean to hijack your thread but I assumed you would have these same questions too!!
      06-03-2019, 08:09 PM   #4
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
So many different ways to do it.
I bought the bimmercode app for my phone and a bluetooth obd2 adapter.
I did everything from my phone. No cables. No computer.
Just turn airplane mode on so you’re not receiving texts or calls while you’re trying to code.
Kingpin4386.50
bmw, coding, warranty
