08-16-2018, 04:41 PM | #23 |
Rep 25,121
My car made front page of Bimmerpost
MashinBenzin8464.00 |
08-16-2018, 04:43 PM | #24 |
Rep 429
If you think of the contact surface of sDrive and xDrive cars with the road, they are the same. If the tyres are the same they have the same grip to hold the car in place - consider them parked on a hill for example. But apply power to the wheels, only the xDrive can apply traction to all 4 wheels.
08-16-2018, 04:49 PM | #25 | |
Rep 15,858
Lease companies can be a pain to deal with over tyres and safety. Should work with BMW's recommendation for changing tyres with less than 3mm tread. I've the habit of looking at tyres when crossing car parks, so many cars (and that includes high performance cars) have such poor tread, often with the shoulders knocked off as well. I suspect quite a few are below the legal limit. I don't understand why folks allow their tyres to get like that. Often this is in winter, talk about increasing your risk of losing it in ordinary driving, let alone in adverse conditions. |
pmgreenwood483.00 |
08-16-2018, 05:11 PM | #26 |
Barge driver
8658
Rep 12,425
No, as an example a 335d xdrive has more traction out of corner or if you like can apply more tractive force to the road due to all 4 wheels been driven, however a RWD car like an M4 will be able to corner with more G force due to it's superior mechanical grip, the xdrive's front end will have started to wash out well before the rear end of the m4 starts to go.
In the same way an awd drive car can use its traction to get going in low grip situations (snow as an example) but doesn't have anymore grip on the road when it comes to braking than a RWD car. If we had a drag race from zero on a wet road 0-60-0 m3 vs 335 xdrive I guarantee you'd win in the xdrive but you wouldn't stop any quicker, you be able to gain more traction through the AWD system in the first phase, but you'd have no more grip under braking.
730d/Z4C
08-16-2018, 05:36 PM | #28 | ||
Rep 15,858
Interesting description from Michelin.
Grip is also shared.... again from Michelin. Quote:
08-16-2018, 05:44 PM | #29 |
Rep 15,858
Yes, the difference is how the grip is shared between the tyres. RWD can overwhelm the grip available from the rear tyres. Not enough grip to cope with high longitudinal forces, nothing left for lateral/transversal grip.
teaston10995.50 |
08-17-2018, 02:17 AM | #30 |
Rep 7,484
In the snow yes it helps. Anyhow, driver error.. misjudgment of speed and braking... driving like it is dry weather.. tyres.. you name it. Looks like he was just being a bampot.
08-17-2018, 02:25 AM | #31 |
Rep 125
Tbh I'm not convinced xDrive would help there and I have a 320i xdrive. I've went round a roundabouts at not overwhelming speed before and skidded. From what I understand tho, thats because I have the dodgy se suspension and need to get the acs springs
A lot of the time I wish I'd skipped xdrive, saved up another grand or so and got a 330i sdrive instead. Last edited by admg; 08-17-2018 at 02:50 AM.. |
08-17-2018, 02:36 AM | #32 |
Rep 19,982
Having now seen the video I'd point out that the accident happens right at where the traffic from the left joins on, which causes the traffic to slow down there, so most likely scenario is that a momentary loss of concentration whilst going a little too fast meant a loss of control under hard braking. Nothing to do with xdrive would have helped there.
08-17-2018, 02:58 AM | #33 |
Rep 13,043
Drives: BMW M340I G20
I don't think 4wd is a must have . But it does put two more driven wheels on the road.
Example would be in slippery conditions you avoid excessive braking pressure and would change down a gear to help the car slow. With 4WD you have four wheels taking the transmitted resistance through the drive train. This will bring you to a stop more quickly and with less brake pressure. The opposite of this would be to knock the car into neutral and then try and stop. You would be completely reliant on the brakes.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
magic juan26.50 |
08-17-2018, 03:02 AM | #34 | |
Rep 337
Refer to the pics in this thread from babybmw... https://www.babybmw.net/viewtopic.ph...aning#p1392332 As others have said, drive to the conditions!! The tyre treads on the MPSS are another reason why winter tyres are a must on the M135/140, but there are still lots of those driving gods out there that claim they are not needed!! Last edited by r1cey; 08-17-2018 at 03:09 AM.. |
08-17-2018, 03:06 AM | #35 | |
Rep 15,858
Grip is grip, overwhelm it due to whatever manoeuvre/conditions and we are out of control. Overcoming lack of grip is the biggest challenge, particularly in an emergency, once we lose grip. If DSC cant catch us, not much hope for most situations. |
08-17-2018, 03:09 AM | #36 | |
Rep 13,043
08-17-2018, 03:13 AM | #37 |
Rep 15,858
08-17-2018, 03:49 AM | #38 |
Rep 1,846
Xdrive is completely useless don't know why anyone would want it /why more manufacturers are moving to it. Of course there is a difference between 4wd and all wheel drive.
I suppose if I didn't have I'd try and justify to myself why it's not useful and why rwd and good tyres is all I need mainly not including driving pleasure. |
08-17-2018, 04:05 AM | #39 |
Barge driver
8658
Rep 12,425
Over the years I've had quite a few phone calls from friends with 4wd cars after they've called me to say they nearly crashed in the snow stating it's so bad out there! I set off OK but then couldn't stop or steer?! WTF, I thought 4WD would sort all that out? I bet your M3 won't move in this. No it's fine because my winter tyres have grip. Often they reply with how does that work?
Of course anyone that wants to maintain the efficacy of their awd drive system would also put winters on and drive to the conditions.
730d/Z4C
08-17-2018, 04:14 AM | #40 |
Rep 1,189
There is another issue in car design caused by the effects of climate change on our weather, and that is wading depth. For example, I was In Suffolk last week using rural roads with poor drainage during two days of heavy downpours. the F30 series of cars have a very low air intake and hence low wading depth irrespective of whether Xdrive or RWD. the minor and B roads were regularly under 8 or 9 inch of water for short distances last week. Fortunately, the friend I was traveling with had a Skoda Yeti which was able to cope. we decided to use his car again next day in similar conditions rather than risk my F31 which would have been very marginal. Unless the G20 improves on wading depth, my looking for something like a Macan next time. Although F30 the manual says 250mm is wading depth, the safe figure apparently is about 150 mm
see this past forum threads:- https://f30.bimmerpost.com/forums/sh...1209976&page=3 https://f30.bimmerpost.com/forums/sh....php?t=1212135 |
JustChris17499.50 |
08-17-2018, 04:27 AM | #41 |
Rep 786
Drives: 2018 F80 M3 CP YMB
I agree with most, can't see xDrive would help there (no more grip) - it could help if your car is stuck in gravel/grass after the accident (more traction)! Seems most likely the driver wasn't paying attention and didn't spot slowing/stationary traffic ahead, slammed on the anchors & swerved onto the gravel to miss the car in front where it all got a bit messy - so ABS/DSC ensured he had control while he was on the tarmac and didn't hit a car but after that he was on gravel and on his own... In fact the extra weight of xDrive could have cost the extra foot needed to swerve around the car in front - all academic I know as we don't know what did happen.
Blowout seems an unlikely cause unless he'd ditched his runflats + looks like tyres were pretty low profile so wouldn't have a massive impact... Useful thread though - doesn't matter what tricks your car can pull there are basic laws of physics that ultimately can't be defeated - so stay attentive & drive to conditions - easy to criticise others but I expect we've all had many times when we haven't paid enough attention but they didn't happen to coincide with the split second when something unexpected was playing out in front of us... My ownership of an xDrive 335d for 3 years told me: 1) it was really good at getting me out of mud/snow when I would not have had winters on (a) because mud was in middle of summer, and b) regardless I don't bother with winters as I live in the SW and I just need the AWD to get out of my road - if the main roads are bad I wouldn't go out) 2) I enjoyed flooring it out of junctions/traffic lights - there's not much on the road to compete with it - ultimately is that a necessary feature - no, was it fun, yes (and made up for the less than perfect handling/steering feel)... 3) it has no positive affect whatsoever on your ability to stop or your cornering speed in the real world on public roads (though obviously you are less likely to unsettle the car by using the accelerator when you really shouldn't - but you really should be nowhere near those limits on a public road) although engine braking on all 4 wheels rather than just the rears can also make the car slightly more stable on a bend in the wet although I think DSC would take care of this anyway Last edited by lethbridge; 08-17-2018 at 04:35 AM.. |
08-17-2018, 04:53 AM | #42 | |||
Rep 1,449
Yip - a good solution is to have winter tyres on, a better solution is winter tyres on xDrive
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
JD64270.50 |
08-17-2018, 05:10 AM | #43 |
Rep 4,935
Drives: 340i MPPSK
I know a good many people who have bought 4WD/AWD cars in the belief that it makes them immune to slippery conditions. Said people have usually never heard of winter tyres or think it's some marketing gimmick by tyre companies
Life is a state of mind |
08-17-2018, 05:59 AM | #44 | |
Rep 337
I had an X3 prior to my last 3 series x-drive, but as the X3 was on all seasons, as opposed to summers on the 3 (and 19” as well), I learnt that tyres were the most important factor, so invested in winter wheels for the 3, and it made a massive difference. To be fair, the all season pirelli scorpions on the X3 handled great, and were unflappable even in the deep snow we had in 2010 for many weeks. As I said in an earlier post, wouldn’t dream of 340 horses, RWD and summers on the M140 in winter!! |
pmgreenwood483.00 |
