BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Fsc code Generator
      07-18-2018, 03:27 PM   #1849
pcp1234
Drives: G03
thank you. struggling to get it working. could i have a clue for road map europe next 2018-2 please?
      07-18-2018, 03:30 PM   #1850
shawnsheridan
shawnsheridan's Avatar
Pull DE File from NBT, feed DE File to FSC Gen using parameters 0xA9 0x32.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-20-2018, 02:36 PM   #1851
pcp1234
Drives: G03
appreciate your help so far. got my dads car to update his maps and he has ROAD MAP EUROPE PREMIUM 2010. I see that there are currently 2018-1 version, however split is West and East. Do I update it to both versions (West and East) or just one?
      07-20-2018, 05:19 PM   #1852
shawnsheridan
You can only load one or the other. U.K. is West.
      07-29-2018, 12:50 PM   #1853
Iangiulu
Drives: BMW F25 x20d
Hi guys, I read in the previous page that the FSC code to update Route Map on HU_EntryNav must be bought from dealer because ASAP access is needed. Something changed or this is the only way to get an activation code for this map? Thank you.
      07-29-2018, 01:04 PM   #1854
shawnsheridan
There is no public FSC Generator for ROUTE Map Update, so you cannot do it yourself. But you do not need to pay Dealer. PM sent.
      07-30-2018, 06:01 PM   #1855
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Just wanted to thank all those who posted instructions & what worked for them Most difficult part for me was getting the VIN to show up in E-Sys. Below are the order of steps I think worked for me.
Prerequisite: disable all firewalls, Antivirus & WiFi. Set Ethernet to DHCP (not static)
1. Connect ENET cable to OBD port
2. Connect ENET to laptop Ethernet port
3. Start vehicle (DO NOT step on the brakes, engine does not have to be on)
4. Wait until Ethernet has yellow exclamation ! Open command prompt & type ipconfig
5. Ensure you have 169.254.xxx.xxx IP address for Ethernet
6. Launch E-Sys Launcher (NOT E-Sys)
7. Select Connect
8. Select appropriate Target (based on I-Level)
Note: Don’t use _DIRECT
9. Select Connection via VIN
10. Select Connect
11. Click Expert Mode
12. Select FSC Extended
13. Diagnostic Address (hex) = 0x63
14. Click Identify
15. Application Number (hex/dec) – 0xDE
16. Upgrade Index (hex/dec) – 0x1
17. Scroll down & select StoreFSC
18. Select Add to the batch button (>>)
19. Select Read
20. Select Save
21. Use the following naming format when saving FSC file. XXXXXXX_000DE001.fsc
Note: XXXXXXX is the last 7 of your VIN
>>> Generating FSC code for map updates <<<
1. Copy NBT.EXE + XXXXXXX_000DE001.fsc to C:\EC-APPS folder
2. Open command prompt & go to C:\EC-APPS folder
Type: NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt
Ex: C:\EC-APPS> NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt
This will create a file called code.txt with the map FSC code inside
I used the FSC file as is, did not have to use BASE64 or decode the file.
Out of laziness, decided to use a batch file that I used to generate FSC for my CIC
Ex: batch file. Note: replace XXXXXXX w/ the last 7 of your VIN
ECHO OFF
CLS
IF NOT EXIST NBT.exe ECHO File NBT.exe NOT FOUND!
IF NOT EXIST XXXXXXX_000DE001.fsc ECHO XXXXXXX_000DE001.fsc does NOT EXIST!
c:\EC-APPS\NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt
IF %ERRORLEVEL% EQU 0 ECHO File code.txt was created successfully!
PAUSE
Place & run batch file in C:\EC-Apps where NBT.exe & your FSC file is located.
NBT.exe I have is dated 7/1/2015 (77KB). Seems to be newer than what I found in the ZIP files posted by others.
Uploaded all the files I use here if anyone wants it: https://drive.google.com/drive/folde...Nl?usp=sharing
>>> Determine Region & Map sequence code <<<
Note: requires HxD application: https://mh-nexus.de/en/hxd/
Region & Map sequence code - located in the 1st folder of the map files
File path = 1\INFO_MAP_NANT_#####\Info_Map.imp
North America NEXT:
      08-02-2018, 03:46 PM   #1856
brstlk
Drives: F30
How to sync maps FSC for NBT EVO =?
      08-02-2018, 04:20 PM   #1857
shawnsheridan
What is meaning of "sync maps FSC"?
      08-02-2018, 04:23 PM   #1858
brstlk
Drives: F30
fsc code for nbt evo How do I get it
F30 3.20 I ed 2015 in my car navigation is off
      08-02-2018, 04:42 PM   #1859
shawnsheridan
PM sent.
      08-04-2018, 08:05 AM   #1860
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Just curious as to what everyone's procedure is that always shows "Connection via VIN"? vs being grayed out.
I tried this same exact procedure on an 2013 F10 M5 & after 3 tries, it was still grayed out.
- 1st try the door was left unlocked (everything off) & has been sitting for an hour while the key was at least 100 ft away
- 2nd try I locked the door and waited 2 minutes, key 3 ft away
- 3rd try I locked the door and waited 5 minutes, key 3 ft away
Was in a hurry so I didn't try locking the doors for a longer period of time before trying again (sleep mode)
Is that 15 minutes or 30 minutes to enter sleep mode?
My initial testing was on a 2015 M6 GC
Thanks
      08-11-2018, 05:33 PM   #1861
pcp1234
Drives: G03
Can I learn too how to get fsc for nbo evo please?
      08-11-2018, 05:48 PM   #1862
shawnsheridan
PM sent.
      08-12-2018, 11:37 AM   #1863
Lykke
Drives: I3 BEV & I3 REX
Can anyone help with the short code or Loockup file for Europe NEXT 2018-2. I have tried 0xa8 0x32 without success. Thank you in advance.
      08-12-2018, 11:46 AM   #1864
shawnsheridan
Europe is A9, not A8, so 0xA9 0x32.
      08-18-2018, 06:45 AM   #1865
vmiro
Bosnia
Drives: BMW 318d E91
Hi, what parameters should I use to generate FSC code for Road Map Europe Premium 2018-2 ?
Thanks
      08-18-2018, 07:50 AM   #1866
shawnsheridan
Thanks
0x28 0x32
      08-19-2018, 03:24 AM   #1867
RoopD
Drives: F30 Alpine Weiss
@shawnsheridan
Thnx RoopD
      08-19-2018, 07:32 AM   #1868
shawnsheridan
Originally Posted by RoopD View Post
@shawnsheridan
Thnx RoopD
PM sent.
      08-20-2018, 12:32 AM   #1869
vmiro
Bosnia
0x28 0x32
Great, thanks
      08-21-2018, 12:22 PM   #1870
22marco77
Drives: BMW 320d (F31) mod Luxury
PM sent.
Could you send me this information too?
Thanks for the help!
