04-17-2018, 09:28 PM | #1 |
Rep 552
Carbon Fiber Exhaust Tips on MPE
Does anyone have any experience replacing M Performance Exhaust chrome tips with carbon fiber ones or using the slip on CF finishers? Attached a pic of my MPE before the install...trying to figure out if finishers can be added on top, or if these need to either be pulled off, unscrewed, or cut/clamped. Thanks guys
04-18-2018, 12:54 PM | #2 |
No 55mph
1621
Rep 8,476
There are no carbon fiber finishers that slip over your existing chrome tips.
The CF tips use double layer design inside consisting of chrome tips with CF sleeve permanently riveted onto a spacer setup on the inner chrome tip - you can't buy only the CF sleeve, nor would it work on the chrome tips you have anyway... Your tips slide on & clamp to tailpipe with screw as in pic below - simply unscrew and slip off tips CF tips also have similar set screw design - just slip them on & tighten screw Pics shown here don't show screw clearly - but you can just make it out in 3rd pic poking out on inside
mlev370.00 Paul Blart51.50 |
04-25-2018, 11:24 PM | #3 | |
Rep 552
I was wondering if you also knew how I would unscrew these? Would I need some sort of rivet gun? I read somewhere that these use a Torx T15 which I bought, but had no luck. Here are some closer pics: Thanks again |
jimmy8904563.00 |
04-26-2018, 04:01 AM | #4 | |
No 55mph
1621
Rep 8,476
No harm in buying the T15 Torx - you'll likely need it sometime anyway. A lot of fasteners are that size...
04-27-2018, 07:20 AM | #5 |
Rep 3,030
Hey guys anyone know where to best source these at a reasonable price rather than buying brought ECS or dealer?
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
05-03-2018, 09:42 AM | #6 | |
Rep 3,863
I got this from Holy Land of China for £110 for both tips and quality is very good and would recommend. Here are pics for you mate |
aps335.50 a358970751115.50 |
05-03-2018, 10:41 AM | #7 | |
Rep 3,030
I'm particular with what I use between genuine and replica and with the tips I wanted genuine. The engraving and font style you can see are very different than the genuine tips, otherwise it would have been a no brainer for me. I just went and dished out the cash for the real ones.
2016 BMW F80 ZCP
05-03-2018, 01:55 PM | #8 |
No 55mph
1621
Rep 8,476
Are these installed on the MPerf exhaust muffler, or STD dual outlet muffler?
05-08-2018, 10:03 PM | #9 |
Rep 1,487
Drives: 2108 X3 xDrive30i
Just curious...what's the warranty on the tips. I've seen CF tips on a Porsche de-laminate.
10-02-2018, 04:37 AM | #10 | |
Rep 162
10-08-2018, 02:14 PM | #11 |
Rep 77
05-16-2020, 09:51 AM | #12 | |
Rep 16
Hey could you please tell me what the inlet and outlet size of your tips are? Or the link to find these please! Ive been looking everywhere! |
