05-12-2020, 04:14 PM | #1 |
Rep 271
MHD flash failed, failed to flash back to stock and now car won't start.
Hopefully someone can help here... I actually have a 2016 F15 X5 but I wanted to post here since that forum doesn't get as much traffic.
I had MHD stage 1 v1.08 91 OCT flashed to my X5 since last august and have not have any issues. Hadn't played with anything else since. Recently I had a few things that needed attention under warranty and I took it to the dealer. Flashed back to stock file with no issues. Had a headlight replaced, seat cover replaced, and steering rack replaced. Of note, they said they had to "code" the new headlight in and they had "issues" but turned out that some of the components that were swapped during the new headlight assembly had broke during the process and in the end it was all good but took a few extra days. Got the car back and had a chance today to reflash using the MHD flasher. Hooked up cable, read everything fine. Hit the stage 1 v1.08 91 OCT button and it first erases ECU and then gives me a message saying "Failed to flash ecu section. Error Code 7F 36 72" Tried it again; same result. At this point, I tried to flash back to stock. Again same result. At this point, I noticed a constant ?pump noise which I assume is the LPFP; not sure if I had noticed it going before the flash. Decided to hook up my charger and had same issues. I did hook up the charge since I've done this previously without the charger and never had issues. Did a quick search and saw some people say to pull LPFP fuses so I did that - same result. At this point, I go into the google play App Store and notice there's an update for the MHD app so I update it. Tried to flash stage 1 and stock again but this time I get the message "The file is not compatible with this DME" Tried to clear codes but it seems like there are some that remain. I have all the drivetrain error messages and the car doesn't even attempt to start now. Now that I think back, maybe the dealer flashed my DME and its now a new version that's not compatible. What do I do now? How fucked am I? Last edited by Everling; 05-12-2020 at 04:33 PM.. |
05-12-2020, 04:21 PM | #2 |
Rep 7,602
Step 1: Email MHD support.
Before you went into the dealer, did you completely uninstall MHD or just flash back to stock map? It's normal to hear the pump running and other noises during the flash, but i dont ever recall it being a constant noise. That could be because the flash failed or was interrupted so it didnt reach the stage where it stops it. |
05-12-2020, 04:40 PM | #4 | |
Rep 7,602
I just did exactly that a couple of weeks ago. I had been running MHD since last year (although i changed maps more recently, that was original install), i completely uninstalled before going in, had some service/warranty done, then completely reinstalled after i got the car back. No issues. Also, you always want to make sure you update the app before doing any flash. Sorry i can't be more helpful to your specific situation; it sounds like you tried what you could from within the app. Might have to wait to see what MHD says. |
pearlpower112.00 |
05-12-2020, 05:21 PM | #5 |
Rep 271
Yea then it was definitely a full flash since it took 25 minute today. When I said "pretty sure" I was kinda of second guessing myself because I noticed now there was an option to flash a "stock map" with MHD on the same page but if there's a large time difference then it was definitely a full stock flash/MHD uninstall.
Unfortunately I didn't realize I should be updating the app before all flashes |
05-13-2020, 12:19 PM | #6 |
Rep 271
Got a response from MHD with instructions. Everything is fixed now.
Just as I suspected, my car got a new software update at the dealership during the last visit and now my DME is locked. They gave me a special apk version to install that was able to get the stock tune back and now the car is fully operational. Will need a bench flash if I want to flash an MHD tube again though which sucks. Debating if I should just do that now or wait 1 more year when the warranty runs out. Thankful my DME isn’t bricked and was able to recover it fairly quickly with the help of MHD. Their newest app version would have detected this if I had updated it prior to flashing again. |
05-13-2020, 12:55 PM | #7 | |
Rep 7,602
1. Always update the app to the newest version. 2. Always completely uninstall MHD before going into the dealer or getting any service where you could get a software update. |
05-20-2020, 09:07 AM | #8 |
Rep 551
Just a quick question (as I am going to buy this application soon) On the choices of Android software (in French) MHD TUNING, as choice there is "flash back to stock" // "flash stage 0 (stock power)" // "generate update backup"
What choice to uninstall completely before going to your BMW dealer please ? |
05-20-2020, 09:15 AM | #9 |
Rep 3,695
Haven’t heard this over on the M2 forum, but is BMW locking N55 DME’s now, just like they did with S55’s?
To date, the M2C S55 guys now have to bench flash, but the M2 N55 guys can still do OBD flash. |
05-20-2020, 11:00 AM | #10 | |
Rep 7,602
Flash stage 0 keeps MHD installed but just goes back to stock tune. That would only take a few minutes. |
F20_M135i100.50 |
11-30-2022, 04:22 PM | #11 |
Rep 3
My TCU may be bricked.
I got the same error while trying to flash the GTS Transmission tune. Now I have transmission malfunction and it keeps failing every time. All other flashes work fine. Did I brick the TCU?
11-30-2022, 04:39 PM | #12 |
Rep 7,602
This is F3x N55 forum, that doesn't apply to us, better check forum for your vehicle
