05-12-2020, 05:22 PM | #1 |
Rep 13
Retrofit lumbar support
Hello I've got msport seats in my base spec UK f30. However the lumbar support does not work. How do I go about retrofitting it. All the stuff is in the seat for it to work however when it is connected to my car the switch does not do anything
Many thanks |
05-12-2020, 05:30 PM | #2 | |
Rep 1,704
https://f30.bimmerpost.com/forums/sh...fitting+lumbar |
05-12-2020, 05:36 PM | #3 | |
Rep 13
05-13-2020, 10:07 AM | #6 |
Rep 1,162
I'm slightly puzzled here. Are you wanting to retrofit the OEM adjustable lumbar support or do you have it factory fitted (both front seats have the 4 way rocker switch) and it doesn't work?
05-13-2020, 10:33 AM | #7 |
Rep 13
I have fitted msport seats which have lumbar support the old seats did not. And I cannot get the lumbar support to work. Everything in the seat is there for it however not working. Not sure if it needs coding or wiring?
05-13-2020, 10:41 AM | #8 |
Rep 159
_________________________________________
M135i F40 2020 - Misano Blue l Tech Pack 1&2 l Comfort Pack 1&2 l Adaptive Suspension Previous: 335d F31 MSport 2017 - Sapphire Black |
05-13-2020, 12:49 PM | #9 | |
Rep 1,162
I'll have a look at the wiring diagrams tomorrow for you and let you know what you should be looking for (if someone doesn't beat me to it). Out of interest was your car originally fitted with SE seats or sport seats with the side bolster adjustment and are the seats full electric? Any does the side bolster adjustment work on the new seats? |
05-13-2020, 05:59 PM | #10 | |
Rep 13
Thanks |
05-14-2020, 01:50 AM | #11 |
Rep 1,141
If you only have the rocker switch, that’s side bolsters only. Lumbar also has a round switch that rocks in 4 directions.
05-14-2020, 03:50 AM | #12 |
Rep 13
05-24-2020, 08:46 AM | #13 |
Rep 1,162
I've attached a couple of wiring diagram images that might be useful.
One problem might be that BMW have an annoying habit of using different wiring harnesses based on your factory build. In the case of the side bolsters (both front seats are fed from the same supply) they might not be wired up, or if they are then the fuse might not have been fitted, or both. Worth checking though. Hope this helps. |
08-16-2021, 06:24 PM | #14 |
Rep 117
Hi.
Sorry bring an old thread up but did any of you mange to get the bolsters working? I've just done the same and come fr SE basic seats to the sports with the electric switch for the bolsters. |
08-17-2021, 03:53 PM | #15 |
Rep 1,704
Mine already had sports seats with electric inflating bolsters. That comes as standard on M-Sport cars....so I only fitted the manual inflating lumbar support.
08-18-2021, 10:20 PM | #16 | |
Rep 117
Wasn't sure if anyone else had done the same as me and found a way of getting them to work |
11-02-2022, 12:29 PM | #18 |
Rep 3
im having the same issue, any updates? , my original seats were electric but did not have bolster or lumber support on them, i just installed sport seats from a 2018 340i onto my 2014 f30 that has bolster and lumber support on the new seats, but the buttons dont work, do i need to code something in with bimmer code for the buttons to work for bolsters and lumber
01-19-2023, 04:17 PM | #19 |
Rep 21
Has anyone managed to get this retrofit done ? .iv also fitted msport full leather with bolster adjustement switch also heated and in need of some assistance to get this wireing sorted .any help would be very apriciated
01-21-2023, 05:50 AM | #20 |
Rep 21
https://www.ma-bmw.com/forum/viewtopic.php?t=34845
10-26-2023, 03:19 PM | #22 |
Rep 9
Revival, but for those like myself trying to find the solution to this problem... This thread may be useful:
https://f30.bimmerpost.com/forums/sh...1293887&page=2 There are specific harnesses listed in this thread from Realoem.com, specific for cars coming from full manual, manual with bolstering, or full electric. |
