01-13-2021, 09:07 AM | #375 |
Rep 474
Drives: 2014 328D xDrive
Just a hair shy of 150,000 miles now - and I got the dreaded "improper exhaust fluid" error... It gave me 201 miles to no-start, and I drive 120 miles round trip to work...
Got it back home with 155 miles left; driving my Mini until I can fix it... |
01-13-2021, 01:38 PM | #376 | |
Rep 1,800
Let me know if you need extra help. |
01-13-2021, 02:06 PM | #377 | |
Rep 474
With how much I normally drive, the DEF is never in my tank longer than 3 months anyway so fluid going bad was never a concern. This year has been a bit different obviously... |
01-13-2021, 02:08 PM | #378 | |
Rep 474
What requirements are there for ISTA? I am quite familiar with coding software and have VCDS for Volkswagens (as well as a CAN-USB cable), but I have no idea if ISTA needs a specific cable, or just software, etc? Thanks! |
01-13-2021, 03:49 PM | #379 |
Rep 1,800
This has happened to me after putting a more questionable fluid inside, so in my case I can confirm it wasn't the NOx sensors.
Send me a PM with your email or something and I can see if I can help a bit. You do not want it to get to zero.
Uber Commuter721.50 |
02-24-2021, 10:54 AM | #380 |
Mini Cooper, Present F15 Owner
Rep 90
Don't want to hijack this thread but what advantage is there to staggerered wheel setups. I would think the inconvenience of buying tires, not being able to rotate them easily, etc., would really make this not a great idea. What say you, FaRKle? P.S. I'm a fan of your YouTubes!
03-04-2021, 05:12 PM | #381 |
Rep 30
All Two's
Bought new in December 2014 with 4 miles.
03-05-2021, 12:10 AM | #382 | |
Rep 3,539
Chukker27.00 |
03-05-2021, 01:31 PM | #383 |
Rep 9
Have you had to get a new t-case yet? I had the flex disc recall done and the dealer said the t-case was fine but I get some odd slipping sometimes coming out of a low speed corner. I just hit 99k miles on my '14. Hoping to see at least 200k with the car no major issues fingers croseed. I still have CPO wrap until 125k....
03-05-2021, 02:10 PM | #384 |
Rep 30
t case
If you go back a bit through the threads i had 3 new transfer cases in first 120k but none since then. When i hit a large pothole i get a weird slipping as well that feels like it's transmission related but doesn't seem to make any noise or be an issue. Never changed tranny fluid so it's probably related? not really sure, only happens every now and then.
03-06-2021, 03:21 PM | #385 |
Rep 2
2014 BMW F30 328D N47D20 (U.S. N47TU) Diesel High Mileage Report. - 144,000 miles
Original owner, CA purchase in Fall of 2013 and moved to Texas with 38k in the Spring of 2014. As of 02/2021 has 144k ODO. It still idles and accelerates smoothly with power to the top of the tach. The GA8 auto transmission still gets it. Following BMW provided 9k service intervals with Castrol oil changes until 50k. Since then I've been using Liqui Moly 5W30 Top Tec synthetic oils every 5-6k: 4200 (LM2011 5L), 4605 (LM2244 5L) with Mahle, Hengst or BMW OE filters. Will begin next oil change using Top Tec 4600 (LM20448 5L) BMW Longlife-04 approved. The LM tech rep (yep, he answered my email) says 4600 is newest BMW LL-04 spec, including diesels.
I’m a DIY mechanic and do all routine maintenance. What has needed repaired/replaced along the way? Diesel particulate sensor @65k; EGR @95k; integrated recirculation cooler with intake plenum @105k (had a thermal event melting the intake plenum that caused some torching); covered by BMW recall (#18V755000) under federal emissions warranty at their cost, $7600. Thank-you BMW! New turbocharger @125k, $2800. OE brake pads/rotors@(85k (hydraulic fluid flushed 85k and 125k). Brakes replaced with Zimmerman rotors and Akebono ceramic pads, $485. No pedal fade yet. New upper/lower coolant hoses at 105k; serpentine belt at 85k and 140k. However, recently the engine has developed a slight oil leak - residue coming from the rear of the engine valve cover gasket (BMW 11128511814 - $30) onto the CAT, which makes it a little smokey at traffic signals unless I wipe the residue from the head every 80-100 miles. In addition to replacing the engine valve cover gasket, I'll also replace the overflow oil line (BMW 13537823408 - $87) using BMW AIR repair instruction: # 11 12 000, R&R Cylinder Head Cover (N47D20 K/U/O/T 1); # 13 53 158, R&R Fuel Injection Pressure Accumulator; and # 13 53 170, R&R Fuel Injector Pressure Lines. I'm not very excited about messing with the fuel injectors at $600 each. How it is driven and performs: High speeds long hauls on Texas highways, the F30 chassis provides a rock-solid platform for the N47TU. The forced draft oil burner (diesel) breaths easily all day long in 8th gear at 2250 rpm and 85 mph. In Texas, traffic school is good every 12 months up to 25 mph over or 95 mph max. If a State Trooper makes a vehicle stop, expect a citation to pay the judge in that county, plus 20 over is $146. Try the 130 Toll Road south-east of Austin. Just south of the COTA race track the posted speed limit is 85 mph to San Antonio. Beware of mass feral hog crossings! |
03-06-2021, 04:35 PM | #386 | |
Rep 3,539
What happened to need a turbo replacement? There's a couple other Texan 328d owners that just replaced their valve cover gaskets recently. I think around the 120k mark.
03-06-2021, 09:58 PM | #387 |
Rep 1,800
Texas here, amd I recently did my valve cover gasket. You'll need to wash the exhaust manifold well to stop the smoking.
Injectors at $600??? They're $230 a piece. They pull out by hand, then you clean the bore, grease the side of it, put a new copper crush washer (Bosch at $0.90 each), and install back. Turbo replacement at 125k is unusual. |
04-08-2021, 09:37 PM | #389 | |
Rep 9
06-10-2021, 01:23 PM | #390 |
Rep 90
After I got through the trials of EGR, O2 Sensors, giubos, transfer cases, etc., I have finally been able to begin putting some miles on my '15 328D - just rolled over 71,000 miles this month. I love this car - it's wonderful to drive and distinctive to look at (it's a touring - not like a zillion other Subaru Outbacks rolling around Colorado) and once again (at least for the moment) diesel is selling for slightly less than unleaded regular. I treated myself to new floormats and can't wait to take my next long trip to SoCal!
06-11-2021, 01:44 AM | #391 |
Rep 190
Not a high-miler at all yet at 75k miles 320d (UK), but decided to do all the diff and t-case fluids the other day (t-case was replaced @ 32k miles) together with all new drain/fill plugs.
Fluid from the rear diff was dark The front diff oil was worse and the drain plug had what looked like black sludge build up on it Fill plug on front diff is the in the middle of the pic and rear diff plug is far right Don't know why BMW calls this lifetime fluid but I would recommend to anyone to get this changed for longevity |
06-11-2021, 10:49 AM | #392 |
Rep 73
My cousins is sitting at 101k miles. 2014 F31. Drives and runs great except for the occasional drive train malfunction, which i am equating to a EGR valve that needs to be cleaned.
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/ |
07-25-2021, 04:06 PM | #393 |
Rep 12
500k?
99,000 miles. F30 2015 328d sport
Goal is to make it last me well into the 300k range, maybe 500k. Ive seen ford f350 trucks last into that range so I would like to think BMW can build an engine that can be on par with that. Maintenance!!! Out of curiosity does any one know if the 6 cylinder diesel fit in the F30 US spec, when it is time to swap into a new engine? |
07-25-2021, 07:30 PM | #394 |
Rep 424
Just hit 101k on my 2014. I know its not much for a lot of you, but I was proud. Here's to 200k
MineralGrayF3116.00 |
07-25-2021, 07:37 PM | #395 | |
Rep 3,539
08-13-2021, 06:10 PM | #396 |
Rep 13
Have 157,000 miles and ready to call it quits. Just got the dreaded DPF code and have a NOX sensor I need to replace. Been reading that the DPF can't be cleaned and it's a big bill when the regen system starts to go. Not sure how much longer I should continue to roll the dice with a 700 mile per week commute. Would love to just to do a delete since I live in a friendly state. I saw the guy that posted that had 200k which is fantastic. Any others out there with DPF issues and rolling the dice?
