01-01-2022, 05:14 PM | #1 |
Rep 3
Automatic Gearbox after oil change Zf8hp
Hello.
I have f30 320d 184ps automatic Car has 184000km and gearbox oil was never changed in previous owner. Car had ok shifting when got warm, but first two gears were rough when it was cold. After few minutes it would get better. Otherwise i didnt notice any strange noises sliping or kicks. I changed oil and filter with genuine zf kit with drain and fill on 40 celzius gearbox temp. First 50 kilometers after oil change cars was really amazing, shifts butter smooth and quick. But next day shifts got same like before oil change. I know there is a lot of old oil thats stayed in gerbox. Maybe because until it got mixed with old was ok but now again not. Any ideas why is it like this and what to do? One more time ddrain and fill? Last edited by Johni1; 01-01-2022 at 06:42 PM.. |
01-02-2022, 05:19 AM | #2 | |
Rep 1,483
I know older ZF6 was programmed to shift later from first to second in diesels when cold in order to bring operating temperature up faster. Not sure about ZF8 in diesels. It was always rough until it warmed up a bit. |
01-02-2022, 05:22 AM | #3 |
Rep 3
I dont know but 50km after change it was really smooth but after that nope not close like smooth. Before change it was also like that
01-02-2022, 11:20 AM | #4 | |
Rep 1,483
At what rpms. is changing gear when cold? First to second? |
01-02-2022, 12:15 PM | #5 | |
Rep 3
I have two teories, it was good until its mixed up with old or maybe because on working temo cooler opened and sucked more oil and now its underfilled. I will check oil level now on 40c to be sure. |
01-08-2022, 09:38 AM | #6 | ||
Rep 10,351
https://blog.fcpeuro.com/how-to-chan...d-transmission
"Drive more, worry less. "
02-05-2022, 09:35 PM | #8 |
Charles B
60
Rep 84
Drives: 335 M235 Z4 944 Turbo
I have 3 BMW's with that trans and they all shift like crap in 1 and 2. It is what it is.
02-06-2022, 01:32 PM | #9 | |
Rep 906
I'd run the tranny up to temp, then fill it up again till fluid starts flowing out. Rough behavior after a tranny fluid change is usually indicative of low fluid. The fluid change occurred at 184K KM (114K miles). There is a general consensus that after a certain point, the fluid should never be touched. FCP Euro says 50K miles, ZF has said 60K miles at one point, and ZF's latest stance is 93K miles (150K KM).
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
02-06-2022, 03:07 PM | #11 | ||
Rep 5,393
My buddy who owns a BMW shop now refuses to do first time transmission service if the car is over 100k miles. He said that he saw a pattern of customers returning claiming it caused new noises and shifting problems that were not there before. He speculated that the AT wears and those tiny particles go into the old fluid, thickening it. So it runs smoothly over 100k miles because of the combination of the worn transmission with the thicker fluid that fills in the worn spots. As soon as new thinner fluid goes it, the worn areas have more play and AT issues arise. His opinion is that the AT will last longer by not touching it. I've heard of guys with >100k miles draining and saving the old fluid, then replacing the transmission pan with its built-in filter and replacing pan bolts, but then re-installing the old fluid. Hope this helps! |
02-09-2022, 09:29 PM | #12 |
Rep 468
Just want to share my experience, but only changed my transmission oil at 155 000km. It was way smoother after especially on the first two gears when cold especially. One year later it's still smooth.
imperfectluck425.00 |
