01-12-2022, 10:14 PM | #1 |
Rep 221
N55 Engine Mount Replacement DIY
I've been looking around and can't find a DIY specifically for the F30 N55 engine mounts. The driver side looks straightforward enough to replace, but the nut on top of the passenger side looks impossible to access.
Anyone have any tips on this? Is it possible to get access to it while under the car? On a related note, I saw DIYs for E90s or F30 4-cyl that thread the tow hook into the engine and attach to the engine support bar. HOWEVER, on my car, (2015 335i N55 6MT RWD) the tow hook does not fit! I checked to make sure that the tow hook is the right one for my car and it does thread into my bumper. but the threaded hole in the engine is too small for it. What should i use instead? |
01-13-2022, 12:19 PM | #2 |
Rep 10,346
Did you clean the threads of both the tow hook and the block? The tow hook is supposed to work.
Try asking bmwtechnician.com
"Drive more, worry less. "
01-13-2022, 06:40 PM | #3 | |
Rep 785
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
01-13-2022, 11:12 PM | #4 | ||
Rep 221
01-14-2022, 08:33 AM | #5 | |||
Rep 785
oranga87.00 |
01-28-2022, 01:06 PM | #7 |
Rep 785
I'm still trying to decide if I'm up to the job. It would probably be the most challenging diy I've ever done. Dealership quoted 1425 including parts which is considerably less than I expected and about the same as the indy shop I talked to, so I may just hand them the car. I still haven't figured out where to support the engine on the driver's side so the front subframe can come down.
01-29-2022, 09:10 PM | #8 |
Rep 221
Pussiwillow would you let us know how it goes? I am also planning on doing it sometime in the near future
Jvac I totally agree, I am going back and forth on it as well, but am leaning more and more towards diy. Also what do u mean by supporting the engine on the driver side? If u just use the e90 tow hook and an engine support bar, you should be set, right? |
Pussiwillow521.00 |
01-30-2022, 10:19 AM | #9 | |
Rep 785
I don't think you'll get enough access to the oil pan just removing the passenger side mount. From what I read the subframe has to come down a few inches because the oil pickup hangs low into the oil pan so it can't just be slid out. It has to drop down quite a ways. If anyone has more information, please share. I've searched quite a bit but haven't found anything definitive. I believe there are threads for a second tow hook somewhere on the driver's side, but things like ac compressor, alternator, charge pipe etc are blocking view and might possibly need to be removed to get the tow hook in. I've been pushing the limits of my diy ability further and further lately but this job would be a big leap for me so I'm waiting until I am absolutely sure. In the meantime I dropped in some of that liqui moly motor oil saver stuff to see if it would slow or stop the leak. Also I would bet a second pair of hands would be needed to work the jack while you line up bolts and bolt holes to reattach the subframe, so I'm waiting until I have someone else to help. If I find any more info I will share.
01-30-2022, 08:11 PM | #10 |
Rep 1,148
I'll update everyone when I'm finished with it and I'll try to document everything as I go, I'm still in the air if I'm doing rod bearings or not, as well as sway bars so mine may get a bit more advanced here, lol
01-31-2022, 11:44 AM | #11 | |
Rep 785
Beyond that, there are a few bolts and a couple foam seals that are supposed to be replaced in the course of the job, so if anyone wants to see these docs pm me your email address and I'll send you a pdf.
03-11-2022, 01:00 PM | #12 |
Rep 30
Question on replacing the engine mounts. Any reason as to why? Symptoms? I think I'm going to need a mount replacement here and am trying to diagnose the issue to verify if it is the mounts, been cold out and haven't had time. But, my engine has a rattle on start up and only in reverse while holding the brake, feels like it's coming exactly from where the engine mount is
03-11-2022, 02:33 PM | #13 |
Rep 16,054
Have someone rev the engine while you look at it. It's normal for the engine to rock a little bit, but if it rocks more than a half inch the mounts may be shot.
03-12-2022, 06:31 AM | #14 |
Rep 30
It's not more of as a visible shaking, it has a rattle specifically at crack and a rattle in reverse only when the brake is applied. It did progress yesterday to sometimes in drive while coming to a stop. Not sure now if it is a Mount or not
03-12-2022, 08:12 AM | #15 |
Rep 16,054
Rattling would happen if the mounts are so severely trashed that parts which normally don't contact each other do. But if that's the case there would be very obvious visible rocking of the engine.
03-12-2022, 11:34 AM | #16 |
Rep 30
I'll go in and check it out when I get some time. Gotta do it here soon as it has started getting worse.
https://www.bimmerforums.com/forum/s...ile-stationary Obviously this is not an F30 (I have a F32) or a n55 but this is exactly the issue I'm having but now it is in drive as well after letting it go for a bit.. |
03-17-2022, 03:13 PM | #17 |
Rep 30
Update if anyone was curious:
Lol okay so, got up under the car as the engine was not rocking at all. Was a loose charge pipe. I started assuming that once it progressed into drivability issues but it didn't have any codes and I was assuming if it wasn't even connected it would throw a code.. but yeah initially it loosened in the silicone hose and was resting on the steering rack and rattling. Then it eventually just popped off which caused the drivability issues. So definitely was not an engine Mount lol but it's all solid now |
03-18-2022, 12:21 PM | #18 | ||
Rep 408
03-18-2022, 12:25 PM | #19 |
Rep 408
FWIW… 4 years owned 120,000 miles with 5,000 OCI's. Something like 16 oil changes?
Castrol 0W40 Euro 0W40 A few batches of Liqui Moly Molygen 0W40 and the rest Mogul Xcess Gen 2 5W 40 |
02-25-2023, 05:17 PM | #21 |
Rep 475
03-11-2023, 05:48 PM | #22 |
Rep 247
