10-06-2019, 09:45 AM | #1 |
Rep 1
Depo rear lights up fog lights instead of reverse
Hello,
I've just installed the DEPO LCI rear lights set. Everything works fine besides that when i get in reverse the fog lights light up instead of the reverse light. I've checked the connections that I made a few times and everything seems to be alright. In the past the rear fog lights didn't work, but I've seen that somebody tried to code them in bimmercode, but probably skipped a step and only the rear fog symbol would light up on the dashboard, but the lights wouldn't. Is it a problem with manufacturer connections or somebody who has previously coded the car messed something up? I also don't have an access to obd2 and bimmercode so I would like not to buy it untill necessary. Maybe it's worth mentioning that the DEPO fog light's are in the same position on the car that the reverse lights on the Pre-lci were. |
10-06-2019, 10:28 AM | #2 |
Rep 16,054
01-06-2020, 07:24 PM | #3 |
Rep 8
01-06-2020, 08:49 PM | #4 | |
Rep 867
01-06-2020, 09:03 PM | #5 |
Rep 472
This happened to me. Switch the wiring harnesses and the problem will be fixed. Move the harness from the left to the right and the harness from the right to the left.
coding, depo, fog, lights, rear, reverse |
