01-15-2021, 02:39 AM | #243 |
Rep 389
Drives: 18 BMW M2LPower
My old 2013 BMW 335ix came with a defective transfer from US with 62k miles...I bought an used transfer and runs over 20k miles never had a transfer failure ATC35L in my hand.
Over 500 1/4 mile passes from 13 to 10 sec and over 130mph trap speed. Oil Transfer change every 6 months with bmw oil. ( Is not lifetime oil for sure )
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD 18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires instagram @luchocampusano YouTube Lucho Campusano |
01-15-2021, 05:27 PM | #244 |
Great Teacher
1084
Rep 1,305
Drives: 06 e91 325ix
Yours was gas and not diesel.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
01-24-2021, 07:16 PM | #245 | |
Great Teacher
1084
Rep 1,305
they failed it due excessive rust on the output (think PO surfed and snowboarded)
02-02-2021, 06:40 PM | #246 |
Rep 11
Additional data point(s), added to the spreadsheet.
I've had two failures on my 2014 328d xDrive Wagon, one at 48k miles and one at 98k miles. Square setup the entire time: OEM 225/45R18 for all but ~2k miles, where I had 255/40/18 square RE-71R on aftermarket square Apex 18" wheels. Both TCs replaced under warranty. Of note, the car had a ChipWerke piggyback tuning module on it for the majority of those miles and was driven hard, including on gravel, dirt, and snow.
2016 F83 M4 Convertible - Tanzanite Blue over Silverstone
2014 F31 328d M-Sport - M-Performance brakes, DUDMD tune E36 "M3" - 328 fully converted track car E28 535i - M30B35 swap, 4.10 LSD, Lemons racer |
02-02-2021, 07:55 PM | #247 | |
Rep 1,799
See this thread. Cause has been discovered, and the remedy from BMW is to use the rubber giubo instead of the aluminum one to reduce vibrations into the output flange.
02-07-2021, 06:00 PM | #248 |
Rep 17
This may be a ridiculous question but is it feasible to convert the car to RWD by removing the transfer case and xDrive components, using a drive shaft from a RWD equivalent model, and running xDelete to solve the coding?
I have a 2014 435ix and reading all of this made me nervous... I'm sitting at 47kmiles and I just want to know if there would be other alternatives out there other than buying a new transfer case or repairing one, if mine ever acts up. Because preserving the xDrive isn't as important to me and I would be okay with saving some $$$ if it meant just using a drive shaft and converting to RWD. Sorry to those who had to deal with this issue, seems incredibly unlucky. |
02-08-2021, 08:06 AM | #249 | |
Rep 1,799
Most of the failures are caused by engine vibration hammering on the output flange. The transfer case on the 6 cylinders are way less affected by the output flange issue, and you'd be much better off with changing the flex disk (giubo) to the updated rubber variant. Changing to rwd simply by removing the shaft doesn't actually 'fix' anything, since the transfer case connects the transmission to the driveshaft. You'd have to replace the transmission to the rwd variant, remove the front differential and change the front hubs too if you want a complete conversion. Deleting xdrive function does is not protective and it does not increase power or benefit much of anything.
Onizukachan1083.50 |
02-08-2021, 01:24 PM | #250 |
Rep 162
I believe some compromised transfer cases suffer from something other than worn flanges.
Mine was doing the symbolic shudder under acceleration but it wasn't the flange slipping. When running in RWD only the symptoms were completely gone, ruling out the rear flange. I never got to the bottom of it but I'm guessing some of us are experiencing clutchpack (within the TC) slippage. |
AndrewC198910931.00 anielsen71558.50 |
02-08-2021, 04:02 PM | #251 | ||
Rep 4
04-14-2021, 11:46 AM | #252 |
Rep 17
Firstly please excuse my lack of technical knowledge. I think this thread is relevant to me so would like to post my story and ask a couple of questions.
2013 3 Series petrol M Sport xdrive, purchased brand new and I am the only one to have ever driven it. I love my car and treat it extremely well. It is driven gently and moderately, mostly long distance on motorways. I have done 48,000 miles in it. Immediately after a previous service (to replace a wheel bearing and the sensor that does all the electronic stuff) I noticed a clunking nose occasionally happening underneath the accelerator area. It didnt seem to impact the actual car too much but pulling away from a standing start at roundabouts was the time I noticed it the most. I did notice it sometimes at higher speeds as well. I could even "feel" the clunk through the accelerator. I took it in to be looked at by BMW and have received the following line in the email I got back this afternoon "Clunking noise from VTG Internal fault. Requires VTG" This is priced at a staggering Ł4,200. Is this the fault a lot of people in this thread are reporting? They changed two of the tyres in January and left the other two the same could that have anything to do with it? Thank you in advance for any replies. |
05-27-2021, 02:26 PM | #253 | |
Rep 357
08-05-2021, 04:56 PM | #254 |
Rep 37
i think they were underfilling them from the factory. i just did my fluid service at 59k, had some binding and t case overheating issues, guess how much of that nasty fluid i was able to pull? maybe .35 quarts. thing is supposed to hold about .7 quarts. nonetheless, got that new DTF1 in there (with a little anti-friction additive, i like to live dangerously)
08-05-2021, 05:27 PM | #255 | |
Rep 1,799
That quantity is normal for vacuum extraction. Anti friction additive in a place where there are clutch plates swimming in fluid that need friction?
08-05-2021, 05:31 PM | #256 | ||
Rep 37
for what was retained in the clutch pack/gears |
08-05-2021, 05:38 PM | #257 | |
Rep 1,799
This is the only way to get all the fluid out:
08-05-2021, 05:45 PM | #258 | ||
Rep 37
the fill plug is right by the top left side of that rubber bushing, please go on about this 'well' you speak of |
08-05-2021, 05:48 PM | #259 |
Rep 1,799
You'll never get all the fluid out from there unless you turn your car upside down.
08-05-2021, 05:52 PM | #260 |
Rep 37
so, those 2 chambers dont have direct fluid flow? theres no way im removing the fkin driveshafts. id rather do 3 slotted fluid changes that pull the driveshafts. i'll do some research on this before i reply 🤣
08-05-2021, 05:53 PM | #261 | |
Rep 1,799
You can just mix and dilute out the old fluid by removing half quantity for 4-5 times and then you have over 95% replaced.
08-11-2021, 11:20 PM | #262 |
Rep 4,551
Drives: 2015 328d xDrive
So my story goes like this: at 50k miles I learned about this issue from the forum and proactively changed the fluid in the case, put a new flange in, and added the rubber flex disc. A few months later, the official recall was issued and I took the car in to bmw. I was told all is okay and that I already had the updated parts. Now at 67k, I get an occasional shudder under heavy throttle and feel some hesitation and clunkiness when setting off from a complete stop. As soon as I did xDelete all the symptoms went away…
Not sure what to do at this point. Is the transfer case covered by bmw under the cv joint recall? If not, can I just leave my car in rear wheel drive indefinitely and avoid dealing with this issue altogether?
08-12-2021, 03:29 AM | #263 | |
Rep 412
Max |
08-12-2021, 10:37 AM | #264 | |
Rep 4,551
My symptoms aren't that terrible yet so I feel like if I brought the car in now they wouldn't just happily offer me a new case.
