12-08-2020, 05:31 AM | #1 |
Rep 2,047
"increased steering effort" warning
I've been getting this message a couple of times during the last week. It only happens immediately after turning the wheel when starting the car and doesn't come back during the drive. Wondering if it's related to the freezing cold weather. Anything to be concerned about?
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
12-08-2020, 05:55 AM | #2 |
Rep 457
How's your battery doing?
12-08-2020, 06:55 AM | #3 |
Rep 15,858
Aren't you having low battery warnings?
Are you trying to steer straight away, before the alternator has a chance to stabilise a higher voltage? |
12-08-2020, 07:01 AM | #4 |
Rep 2,047
ah yes, might be the battery. Yes, I steer straight away as I turn on the ignition. Will start to unplug the dashcam when not needed to keep the battery topped up
12-08-2020, 07:38 AM | #6 |
Rep 389
Looking at the picture avoiding all the cyclists would be my guess
Not today Satan.......... Oh go on then just the one!
12-08-2020, 08:11 AM | #7 |
Rep 2,047
Exiting my spot in the garage requires some navigating
12-08-2020, 01:02 PM | #9 |
Rep 749
Drives: F31 320d xDrive M Sport
Don't touch the steering wheel until the engine is running and at a stable rpm, then you'll likely not get this message.
If you're trying to turn the steering wheel whilst starting the engine it'll get upset.
12-08-2020, 03:58 PM | #10 |
Rep 3,967
But you aren’t supposed to turn the wheel until the engine has started up and the electronic power steering is on
Normally you would press the start button to turn the ignition on and prime the fuel pump, then a second or two later press down on the appropriate pedal depending on manual or automatic, and press the start button again to start the engine. Then you would turn the steering wheel and most likely not get any unwanted warning pop up |
12-08-2020, 05:05 PM | #11 | |
Rep 15,858
Probably caught out the normal EPS 'Control Cycle' before the Intelligent Alternator Control could up the voltage and output. Could have been a voltage dip from the start, with a battery in low SoC, with a further instant voltage dip due to EPS demand. Triggering a warning. (May have caused a temporary drop to less than 9 Volts). Steering while stationary (worst condition) puts a high demand on the battery/alternator. Can be up to something like 1,000 watts. Simply delaying the steering for a few seconds from a start, would be a wise move. |
12-09-2020, 01:45 AM | #12 |
Rep 8,083
That high? The wiring to the power steering rack / motor does not look like it's rated to 80A.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-09-2020, 04:41 AM | #13 |
Rep 2,047
I sometimes turn on the ignition and a second after turn the steering wheel (when I'm in a hurry). I will wait a bit longer. Never heard about this issue, thanks all for clarifying!
12-09-2020, 06:20 AM | #14 | |
Rep 15,858
Where the issues could be on start up. A quick tug, with high torque on the steering wheel may be causing a spike with high draw, while voltage is in a critical low state. |
