03-25-2022, 07:13 PM | #1 |
Rep 2
NBT retrofit quick question!
Hi guys,
I am going to try to retrofit a nbt evo unit from an entry basis. I do not have a combox(so no mic or antennas). For the antennas I will pick some aftermarket ones(and place them in the dashboard), and for the mic I will man up and cut the headliner. I've also managed to find a pdf with the nbt quadlock pinout. However, I couldn't find one for the entry basis. I am wondering if my current quadlock will be wired correctly for the nbt unit. I guess not, but if someone could tell me for sure and also give me an example of a quad adapter that would do the trick it would be much appreciated :help Many thanks in advance! |
03-27-2022, 08:14 AM | #2 | |
Rep 3,062
All wiring you can check on newtis as well
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
03-28-2022, 02:07 PM | #3 |
Coding ECU's remotely
448
Rep 1,179
Unless you buy an Evo with GPS plug, you will need an ATM emulator to allow a GPS antenna to be connected.
I suspect you have the Mic wired in already but you will need to add a BT antenna. The rest of the wiring should be fine. The EVO will need to be coded to your VIN or it will go into Component Protection when connected to your vehicle. |
03-28-2022, 02:11 PM | #4 |
Rep 228
Drives: 2022 G20 330E
if anyone interested i have NBT EVO with GPS port for sale. can precode it for your VIN.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
nbt, quadlock, retrofit, retrofit nbt |
