03-05-2017, 01:15 AM | #11661 |
Rep 331
Drives: M140i F20 LCI-2
Carly for BMW Pro Coding Stop/Start OFF
Stop/Start was annoying me so a few minutes with my Carly for BMW Pro Android app and the Carly adapter quickly sorted it. Now, Comfort, Sport and Sport+ driving modes commence with Stop/Start OFF. I left Eco-Pro mode with Stop/Start ON as the default.
Yes, if I want to turn Stop/Start ON in the first three modes mentioned, I just click the button above START. The Android Smartphone or Tablet connect to the Carly Adapter via Bluetooth.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. Last edited by DrGadget; 03-05-2017 at 01:23 AM.. |
03-05-2017, 06:48 AM | #11663 |
Rep 93
Hi. Need some help guys.
I have coded today M135. Added 6nk and removed 6nh. write to car. And coded hu_entry. Now telephone option dissappear in I drive. Can't read svt in hu_entry now? I think the caf file is missing. please advise : |
03-05-2017, 08:00 AM | #11664 | |
Rep 40,785
Yes. F020 psdzdata covers F020/F021/F022/F023/F030/F031/F032/F033/F034/F035/F036/F080/F082/F083/F087/F088
Dawko193.50 |
03-05-2017, 08:03 AM | #11665 | |
Rep 40,785
Now you need to inject CAFD into ECU and VO Code it to fix it: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired HU_ENTRY => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on HU_ENTRY (the ECU itself not the underlying CAFD) => Select CODE.
myszano118.50 |
03-05-2017, 08:25 AM | #11667 |
Rep 74
some FDL options I wonder
Hello,
I wonder what the following options in FDL mean: 1. HU_NBT -> 3001 EXBOX -> Camera System available options are: TRSVC, icam_rvc, rvc_standalone and some icam with different top view and side view cams. 2. HU_NBT -> 3001 EXBOX -> ICAM_PBA available options are active and not active 3. HU_NBT -> 3001 EXBOX -> Communication_Parkmaster available options are gen1, no_pm, gen2 4. HU_NBT -> 3001 EXBOX -> Auto_PDC available options are active and not active 5. HU_NBT -> 3001 EXBOX -> Hud_generations available options are apix, not active and CAN |
03-05-2017, 01:40 PM | #11668 | |
Rep 93
03-05-2017, 01:43 PM | #11669 |
Rep 40,785
Use what you have.
myszano118.50 |
03-05-2017, 01:54 PM | #11671 |
Rep 17
Car updated
Hey Shawn I took my car to the dealer and they updated the software on my car. When I went to reprogram the car there are several errors of missing cadf files when i read the coding data. Do I need a newer version of the programming software? My ecu is currently at f10-16-11-503. Any guidance will be appreciated. Thanks
03-05-2017, 01:54 PM | #11672 |
Rep 40,785
It's not all that important which one. The instruction was to "Select the CAFD from latest I-Level shown". If that is not obvious from the list, it is one at bottom.
myszano118.50 |
03-05-2017, 01:57 PM | #11673 | |
Rep 40,785
03-05-2017, 02:01 PM | #11674 | |
Rep 93
I'll try to do that when he pop in. Also the DAB radio is not present right now, and usb, that is all because that CAFD filr missing in HU_ENTRY ? |
03-05-2017, 02:09 PM | #11675 |
Rep 40,785
Right now, you are lucky you have anything at all. Until CAFD is injected and Head Unit encoded, don't worry about limited functionality.
myszano118.50 |
03-06-2017, 07:50 PM | #11677 |
Rep 1,254
I just ordered my cable but more I read about coding more I am getting confused
PDF showing three different ways I don't know if I will be able to do this I Don't want brick my car then I would be F@#%$ big time
03-06-2017, 08:54 PM | #11678 | |
Rep 8,364
There are two types of coding:
03-06-2017, 09:20 PM | #11679 | |
Rep 1,254
I think this is where I'm getting confused how ever you did clarify a lot by explaining how and what now I am understanding better I guess we will se if my balls are big enough to do this when I get cable
03-06-2017, 10:18 PM | #11680 | |
Rep 8,364
From same section, Expert Mode > Coding, "Code" is used for VO-coding and "Code FDL" is used for FDL-coding. Not sure which PDF is confusing. Here is two helpful links: |
03-07-2017, 07:51 AM | #11681 | |
Rep 1,254
03-07-2017, 08:42 AM | #11682 |
BMW Enthusiast
Rep 10
Drives: 2011 BMW 320d
I have a question
Hi Everyone,
I want to backup my car coding values but i don't know how can i do. I coded my car, but i want to add Cruise Control. VO Coding operation can it reset my codings (sidemarker, mpm logo, adaptive fog lights.. etc) ? Thanks for support. |
