BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 NBT retrofit -2016 328xi
      06-16-2021, 05:51 AM   #1
xSauL
Drives: Bmw 2016 328xi
Hello everyone, I am a noob so pls excuse my ignorance. I have recently bought the bigger oem 8” screen, the bigger nav box and the touch IDrive controller from someone for a good price. I thought it would be plug and play but the screen says No Signal and the “box” needs more connections. Can someone be kind enough to tell me if it is possible for me to install this and exactly what else I need to buy and how to do it. Thanks! I can Venmo you a bit of cash for taking up your time too!
      06-17-2021, 12:46 AM   #2
Siki78
Siki78's Avatar
136
Drives: F30,G30
Which screen you have? If it is appix2 will not work because this is nbt
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      06-17-2021, 02:30 AM   #3
xSauL
The screen and the box were both made in 2012
      06-18-2021, 07:40 AM   #4
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Post a picture of the back of the screen so I can see the part number.
The headunit will need coding to your car and activating with FSC codes - it's not plug and play without some work.
      06-30-2021, 02:34 AM   #5
xSauL
This is the back of the screen
      06-30-2021, 03:03 AM   #6
Wibbles
Wibbles's Avatar
445
Drives: M3LR
The screen should work with that Headunit, it likely just needs coding to it - can be done remotely with an ENET cable
      06-30-2021, 03:05 AM   #7
xSauL
Can I do it with BimmerCode?
      06-30-2021, 03:07 AM   #8
Wibbles
Wibbles's Avatar
445
Drives: M3LR
I don't use bimmercode, it's a POS - however you can probably change the screen settings in the HU with it.
      06-30-2021, 07:12 AM   #9
Siki78
Siki78's Avatar
136
Drives: F30,G30
He has to change his FA first and VO code HU-NBT
