10-23-2018, 10:31 AM | #111 |
Rep 1,148
deneyer is correct. In the 2nd generation(LCI) Parking Assistant, the extra 2 side Rear Sensors are PDC type, not PMA sensors. PMA sensors are only the front 2 sensors.
11-15-2018, 05:42 AM | #112 |
Rep 58
Hello guys,
I have retrofitted surround view, pma gen 2, lcw and heated steering wheel with the amazing roxxor tutorials. I had problem with flex relay port in lcw but I used tool 32 to open the 5ag port. But now I am ending the pma retrofit but I have a problem with front left ultrasonic pma sensor. The fault in ista is short on positive. Anybody know what is the meaning? does the sensor need to be activate? Thanks.
F33 420d, E34 525 tds
11-21-2018, 06:50 AM | #113 | |
Rep 58
12-01-2018, 11:25 AM | #114 |
Rep 145
12-15-2018, 01:30 PM | #115 |
Rep 21
Hi, I made PMA2 retrofit on my bmw f31 with 2 PMA sensors on the front and 2 PDC on the back, this is all working but I was wondering if it is possible to activate the Active_pdc and side PDC. Side PDC appears on NBT but does not work. Its possible Coding for activate?
01-24-2019, 02:23 AM | #116 | |
Rep 211
02-05-2019, 12:46 PM | #119 |
Rep 21
Side pdc work now. but i have a question for who has done this retrofit, does the car use the automatic brakes to park or not?
04-04-2019, 06:28 AM | #120 |
Rep 47
Pdc sensors location
04-23-2019, 04:43 PM | #121 |
Rep 21
agilbert3143.00 |
05-06-2019, 07:09 AM | #123 |
Rep 1,148
05-06-2019, 08:08 AM | #124 |
Rep 6
05-06-2019, 09:52 AM | #125 |
Rep 1,148
05-06-2019, 01:43 PM | #126 | |
Rep 6
But on my rear bumper only PMA sensors fit correctly into hole, I tried to put regular pdc on side parking sensor holes, but they are differently shaped. |
05-07-2019, 11:06 AM | #127 |
Rep 1,148
My apologies, I am not familiar with the 1-series, which is why I mentioned on page 1 that my parts list may vary for other vehicles. It looks like the 1-series uses the PMA type all around except for 2 sensors on the front bumper. Find the correct part number for your rear bumper sensors here:
http://www.realoem.com/bmw/enUS/show...diagId=66_0440 |
05-08-2019, 09:58 PM | #128 |
Rep 2
Hi I don’t sure if anyone of you can help but I have BMW F30 2015 with iDrive 4 and rear park sensor. I want to add the front sensor but I don’t think my car have front PDC- is it possible to add sensor for front car? - I am based in UK. Thanks
05-10-2019, 11:50 AM | #129 |
Rep 50
05-12-2019, 08:47 PM | #130 |
Rep 47
PDC sensor holder
Are the guides (51127384465 & 6) really required to install the extra PDC sensors on the rear bumber?
I’m considering using normal PDC holders to hold the sensors. |
07-01-2019, 07:18 AM | #132 |
Rep 58
PMA2 Retrofit
Hi, i retrofitted PMA2 sensors.
No error on sensors scanning ecu. NBT shows only the 4 sensors on side in red, no other. Only error in pma is ICM Interface (steering angle , front axle , effective 56.1.2) probably caused from ABS Sensors still not changed) Can someone help me? i checked and checked again the cable, is everything ok. Maybe DSC Still not coded? Last edited by Drimacus; 07-01-2019 at 08:12 AM.. Reason: Adding particulars. |
