03-08-2020, 01:30 AM | #529 |
Rep 135
B58
OzBMR: yesterday made again one log on 4 gear MHD stage2 Ron 98 map. Can you check please and make a virtual dyno please(340i rwd, r19)? Last time you showed 477whp (but is too much for OTS map)
https://datazap.me/u/janea1207/bmw-3...&data=5-24 |
03-08-2020, 07:23 AM | #530 | |
Rep 585
Based on the data it looks like you might be making about 410 - 420 WHP, but you'd need to provide a few good logs from same flat section of road to verify. I think you'd make more power with the v3 Stage 2 95_102 OTS map which has less initial boost but more timing. The timing you're getting looks good and consistent across cylinders, just low as you are using the lower octane map.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
janea120728.50 |
03-08-2020, 09:43 AM | #531 |
Rep 25
logs
Hey OzBMR
any chance of a virtual dyno? Actual dyno says 370whp https://datazap.me/u/coeman/4th-and-...og=0&data=4-26 this is a custom tune for 91(95) on a PPF car. Drives great and I asked for limited torque so it doesn't hit too hard. Very happy but always looking at where to go next. Probably downpipe (with cat) chop out the ppf and put on MHD stage 2 with xHP appreciate all your input in the thread. It is very interesting to read. Only thing I would want different is it to hold boost better after 6k, not entirely sure why it dips so much as does cause throttle closures sometimes but not always at around 6k. Perhaps they did this due to being on 91(95). Or maybe to do with the PPF as the pressure sensor is reading around 8psi of back pressure :/ seems a hell of a lot. But I really like the fact it doesn't hit too hard and builds nicely. Last edited by Coeman140; 03-08-2020 at 09:53 AM.. |
03-08-2020, 12:58 PM | #532 |
Rep 163
Here's another log after the sparkplug install
https://datazap.me/u/dparadis21/mhd-...og=0&data=5-19 Any idea why my boost target is so low? I've had around 18 psi of boost before but this run I'm only around 15. Also should I go back to the 91 tune again since I'm consistently getting around 0.5 degrees of timing correction (better than the 1-1.2 pre sparkplug install though). |
03-08-2020, 04:41 PM | #533 | ||
Rep 135
b58
thanks a lot for info |
03-08-2020, 06:09 PM | #534 | |
Rep 585
From the 3rd, 4th, 5th log... 100 - 150 3.4 seconds 100 - 200 9.1 seconds PPF is holding it back for sure, not so much the downpipe.
03-08-2020, 06:22 PM | #535 | |
Rep 585
03-08-2020, 06:28 PM | #536 |
Rep 25
Thanks for that. That 3rd 4th 5th pull is quite a bumpy road with some uphill and going round a corner so not ideal
no xHP yet. I'm waiting to hear back from the tuner what they did regards torque scaling and whether any scaling was applied to fool the transmission before flashing xHP I'm just dubious of the PPF as BMW do a lot of calibration incl. transmission cal to look after the filter. There is actually a puma case to tell customers who have PPF cars that there upshifts in manual are lazy to look after the filter if they complain about poor upshifts. And tbh they are terrible, sometimes I use a short shift to stop wheel spin and it always catches me out as there is such a long delay on the shift you can be in a ditch by the time it shifts. Probably look to delete the PPF and flash xHP at a later date. But would quite like to see what happens in the UK with the first PPF cars getting MoT tests over here whether the rules change or testing criteria changes etc. anyway car still drives great and is very fast so no complaints. Last edited by Coeman140; 03-08-2020 at 06:41 PM.. |
03-09-2020, 06:58 PM | #537 | |
Rep 103
M140i Mineral Grey 3door 09/18 - Supersprint Catless Downpipe / Stage 2 MHD
03-09-2020, 07:59 PM | #538 |
Rep 163
So here are some logs I just made
https://datazap.me/u/dparadis21/mhd-...og=0&data=5-19 This looks really bad, any thoughts? Losing 40+ hp and pulling 3 degrees of timing by the end. Is this just like really awful gas? Just filled up yesterday and my previous logs that looked fine were on a previous fillup. Edit: Reflashed 91 tune about two hours later after the car cooled down and I got this log https://datazap.me/u/dparadis21/mhd-...&data=17-19-44 Last edited by baldeagleman; 03-09-2020 at 10:02 PM.. |
03-10-2020, 02:24 AM | #539 | |
Rep 413
You have rail pressure drops of 600psi on every log.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
03-10-2020, 02:35 AM | #540 |
Built Motor F30 340i
403
Rep 257
Story of how to blow up a B58 in one simple log:
https://datazap.me/u/richmichael97/s...59-60-61-62-69
kern4174449.50 |
03-10-2020, 07:06 AM | #541 | |
Rep 25
03-10-2020, 01:45 PM | #543 | |
Rep 135
B58
alyabiev160.50 |
03-11-2020, 12:46 AM | #544 |
403
Rep 257
Yup, we have no clue why it happened. Previous logs when it misfired it'd always throw into limp mode, but for some reason something happened this time and it decided "na we're just going to compensate for loss of cyl 5"
janea120728.50 |
03-11-2020, 09:28 AM | #546 |
Rep 3,189
I don't understand why people are thinking the tune compensated for cylinder 5 dropping and that caused the wastegate to slam closed and 40+psi. The MAF is before the turbo, so it would read whatever the turbo is sucking in. Having a cylinder that is not firing would still have 40psi flowing through it, it just would be down on power. The slight lean AFR makes sense, but the worst think the tune should do is make all of the other cylinders richer to get AFR on target.
alyabiev160.50 |
03-11-2020, 01:58 PM | #547 |
Rep 198
I bought a Dragy for fun and here's first result. 0-60 came in at 4.5s, but as "invalid" on Dragy.
View post on imgur.com I logged at the same time...any idea what the various limiter values are? i.e. 131072 (I long pressed the traction button) https://datazap.me/u/instigatorx/log...-43&solo=10-43 https://datazap.me/u/instigatorx/log...-19-43&solo=43 I was running MHD ST1 95oct, but after doing a legit 4th gear log, my car doesn't like it even at E18. So I'll go back to 93oct for now. Last edited by InstigatorX; 03-11-2020 at 04:06 PM.. |
03-11-2020, 02:24 PM | #548 | |
Cheapskate
4450
Rep 4,993
Also, the tuner himself said that he thinks that's what happened. |
janea120728.50 |
03-12-2020, 06:50 AM | #550 |
Cheapskate
4450
Rep 4,993
Like I said, I don't see why it wouldn't make sense. They've been chasing the issue for a while now, because he was overboosting a few weeks ago. If a cylinder was deactivated, you have airflow that isn't being combusted. So now you have WGDC and Lambda targets fighting each other. All of this on the assumption that the car deactivated the cylinder but didn't put the car into limp mode (he was still able to start and drive the car, just saw oil everywhere when it failed). Regardless, you can make more boost at the same maf level depending on the conditions so you can't directly correlate the two (keep in mind he had a pure800 so you can't even compare it to stock maf values).
janea120728.50 |
