07-27-2020, 07:50 AM | #1409 | |
Cheapskate
4450
Rep 4,993
07-27-2020, 07:52 AM | #1410 | |
Cheapskate
4450
Rep 4,993
07-27-2020, 09:42 AM | #1411 | |
Rep 30
Next I was going to try a higher octane fuel (maybe use Boostane). Interesting comment on the Air Filter above. I checked mine, and it's pretty clean and looks new. Would an upgraded (high flow) air filter help with timing? |
07-27-2020, 12:04 PM | #1412 |
Rep 452
07-27-2020, 03:05 PM | #1413 |
Rep 242
Guys Paul is close to finish my e30 map ,but i dont like my timing it goes up and down and alot corrections ,any ideas, maybe i should add more E, what you think?Car feels strong though and is definitely faster then 100ron map 0.4 off from 100-200time https://www.bootmod3.net/log?id=5f1f...0b43477ced69db
OzBMR574.50 |
07-27-2020, 08:15 PM | #1414 | |
Rep 585
You could try more ethanol, fuel rail pressure looks OK and it wouldn't hurt to try. To me it looks like the timing variation is more so to do with the target and limit values in the tune. They could look to increase the Load Limit to 220 between 3000 - 4000 RPM as the car is currently exceeding the Load Limit there. This may help to achieve more consistent Load and Timing. Could also fill the cells in the Target Timing table further to the right (higher Load) with the same ignition target values e.g. between 200 and 220 Load and 3400 - 3650 RPM target 8.5 degrees. At 6500 RPM and Load 213 for some reason timing target is 11.6 where at similar Load and RPM point the surrounding timing target is 14? Doesn't make sense. Making about 550 WHP by the looks of the log, adjusted for altitude. Nice power and the turbo looks to be a nice upgrade.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
yokata156.00 |
07-27-2020, 08:21 PM | #1415 | |
Rep 242
OzBMR574.50 |
07-27-2020, 08:30 PM | #1416 | |
Rep 585
Data here https://f30.bimmerpost.com/forums/sh...23&postcount=7
kern4174449.50 |
07-28-2020, 06:12 AM | #1417 |
Rep 171
Hey everyone I just did this log hopefully it has the right information in it for you guys to check it out
https://www.bootmod3.net/log?id=5f1f...90c6642d49dcff |
07-29-2020, 12:21 AM | #1418 |
Rep 435
Hi there
Been a long viewer of this thread and sadly none similar in the supra forums.. Had an F80 M3 and recently got a 2020 Supra ECUTEK 91 octane tune Pure800 turbo CSF Heat exchanger AA catted DP Akrapovic exhaust MST intake Forge chargepipe AEM methanol - 250CC just for cooling 45C weather - 40% humidity (Hot as hell) Can someone let me know what they think of these logs? Tuner says our gas is awful https://datazap.me/u/a90moe/4th-pull...?log=0&data=10
'16 F80 M3 6M/T (sold)
'20 Toyota Supra Last edited by F80Moe; 07-29-2020 at 12:36 AM.. |
07-29-2020, 02:53 AM | #1419 | |
Rep 585
Agree with your tuner, octane of fuel is very low and ignition timing advance is poor, negative until 5000RPM and only 3.5 degrees by 6000RPM. Your exhaust gas temperature would be very high. No access to ethanol and/or higher octane fuel? If not and you plan to continue to run that boost level you should increase your meth injection.
07-29-2020, 03:46 AM | #1420 | |
Rep 1,010
Strange from what I know fuel in Kuwait and UAE is good.
I think it's most likely the heat I have the same problem whenever it reaches 40C here my timing totally mess up even on stock MPPSK tune. Also you are running very high boost around 26 psi up to 5800 RPM which is definitely not helping with the heat. Which Supra did you get ? the newest 10.2 compression ratio ? I think you should ask your tuner to lower the boost and as OzBMR said if you have access to ethanol definitely go for it. Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
07-29-2020, 03:51 AM | #1421 | |
Rep 435
Sadly no ethanol through pumps here.. Looking at the logs here my timing does still look pretty bad.. I had higher expectations with pump gas that faded away (atleast 500whp) |
07-29-2020, 04:11 AM | #1422 | |
Rep 435
2020 Supra with 11.0:1 compression ratio.. Yes boost midrange is high 25psi and then falls down to about 20psi @ redline Better to lower and bring up more timing? |
07-29-2020, 04:34 AM | #1423 |
Rep 1,010
I asked my tuner for an extra tune for extreme hot weather with less boost and less timing and it's working very well.
And when extreme heat is over I switch back to the normal tune, perhaps you should consider this option.
07-29-2020, 04:41 AM | #1424 | |
Rep 435
Its now on revision 10 and improved a lot.. Tuner (Jeff Payn) has been really supportive and is always wanting to improve Just asked him to lower midrange to 20psi and hold till redline perhaps compensate with more timing Will see how it goes |
07-29-2020, 04:46 AM | #1425 | |
Rep 1,010
45C summer map with 26 psi of boost
Good luck mate and let us know how it went. Quote:
07-29-2020, 04:58 AM | #1426 | ||
Rep 151
Kirill @ OdinTuned
07-29-2020, 05:10 AM | #1427 |
Rep 435
07-29-2020, 05:25 PM | #1428 |
Rep 122
RON102 vs RON98
First of all I would like to thank kern417 for staring this thread, very interesting and it has been a steep learning curve!
I was interested in finding out the difference between RON102 and RON98 fuel. A couple of weeks ago I went to Germany and got some Aral 102 and when my tank was almost empty I did a log. Last week when my Shell V-Power 98 was almost empty I did logs, you can find all three here: https://datazap.me/u/remko3dl/ron102...og=0&data=3-19 All three runs were done on the same stretch of road in the same direction. What really surprised me was the higher boost with the RON98 fuel! As I'm new with this I guess that it might have to do with the higher IAT's and charge air temps during the RON98 runs? What do you think? I used Virtual Dyno as well to see the differences. (thanks to OzBMR for showing in this thread how to use it!) In the first screenshot you can see there is not a lot of difference between RON102 and RON98, although 102 is much smoother. I expected RON102 to be clearly stronger than RON98 but the difference is not that big. Maybe it's because I'm still on the stock tune and it doesn't take much advantage of the higher octane? The second screenshot shows my second RON98 run which I started at a higher rpm and according to Virtual Dyno I now made more power and torque on RON98?
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
OzBMR574.50 |
07-29-2020, 10:08 PM | #1429 | |
Rep 585
Load Required and actual torque is the same for all runs as it is the same stock tune. Variations in boost level are due to IAT and ambient pressure differences only as you mentioned. Timing is better/cleaner across all cylinders with 102RON fuel even at the stock tune levels. With stage1 or stage 2 tunes the fuel will be even more important. Your test highlights that even at stock levels 98RON_93 octane fuel is really barely acceptable and that for higher torque/load/boost you need to have higher octane fuel.
Uni-Rapide71.00 |
07-30-2020, 02:49 AM | #1430 | |
Rep 122
What about the throttle closures? I assume that's due to boost being over target? Is that something that can be solved by a (custom) tune? The fact that my second 98RON run showed higher power and torque is that within the tolerances of the measurement or is there another explanation?
