08-03-2020, 01:58 PM | #3873 |
Rep 280
New update
New version B_V1.0.2 for Andream NBT available on the 1st page.
This is for the latest unit with the new UI. Please only flash it e.g. if you are coming from version B-V1.0.0. It's not compatible with the 'older' units (currently there are no benefits anyway). Changelog is, as always, unknown. We will post an update for the custom mod as well later today (if everything checks out). |
08-03-2020, 02:11 PM | #3874 |
Rep 92
Hi everyone,
On my Carlinkit I just tried custom v1.0.C0.mod FW from cossie1 and Firefly1337, everything works well except selector cursor in Android Auto is totally gone. So I can't use any functions because I don't see what I select )) Ok, no worries I thought - just install v9.2.7.t.yl.b and cursor will be back, but NO CURSOR... Ok, lets switch MCU's - tried MCU 20.06.02, MCU 20.1.4, MCU 19.12.12 - NO CURSOR. Ok, maybe old MCU 19.12.12 + v9.1.9.yl.b firmware - NO CURSOR. So right now I can't bring back selection cursor to my Android Auto interface at any Firmware and MCU version. Any thoughts maybe? Is there firmware restore option to clean unit? I think some old config files from v1.0.C0.mod stuck in the system even after FW update/reinstall. Last edited by yulian; 08-03-2020 at 02:25 PM.. |
08-03-2020, 02:43 PM | #3875 | |
Rep 43
08-03-2020, 02:50 PM | #3876 | ||
Rep 1,217
08-03-2020, 02:58 PM | #3877 | |
Rep 92
08-03-2020, 03:12 PM | #3878 | ||
Rep 1,217
https://support.google.com/androidau...msgid=12809223 |
08-03-2020, 03:47 PM | #3879 |
Rep 280
New custom version v2.0
Hey,
here's the newest update for our custom version: v2.0.B0.mod for BMW NBT and v2.0.M0.mod for MINI NBT. They are available on the 1st page. The biggest change is that this version will run on any device. It does not matter if you have an Andream, Carlinkit, RoadTop or Bimmertech device. It is based on the latest Bimmertech update featuring their UI (see below). //Edit: Since it's based on the Bimmertech update, calls on AA should be fixed as well. //Edit2: A word regarding MCU updates: With this update you can only flash the MCU updates by Bimmertech. Flashing the default MCU from Andream/Carlinkit etc is only possible on their firmware. Currently there is no need to do anything (no new features etc), so you can leave everything as is. Also note that Bimmertech transforms the first digits of the MCU version from '20' to '10'. I'd like to take the opportunity and thank cossie1 for the update, he really did most of the changes and created many new icons and images. Also thanks to dkeruza and Feisar328i for their continuous support and muniz_ri and xDHC for test flashing the update Changelog/Contents:
23
cossie1624.50 chambo62236.50 muniz_ri447.50 eduwinner3.00 FransL3.00 x-m4n148.00 Unspec1299.50 623baller14.50 Feisar328i4.50 Besty787.50 TheUltimateDrivingManiac835.00 i3BEV10.50 contracts3444.50 Fuechslein3.00 stvward133.00 singhinho1.50 dws1997.50 corduroy110.00 propernorf15.50 Eddamoo391.00 theblues86.50 max13290.00 fe7565552.50 |
08-03-2020, 04:03 PM | #3880 | |
Rep 1,217
Firefly1337846.00 |
08-03-2020, 04:38 PM | #3881 | |
Rep 37
08-03-2020, 04:43 PM | #3882 | |
Rep 1,217
08-03-2020, 05:01 PM | #3883 | |
Rep 2,591
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
08-03-2020, 05:35 PM | #3884 | |
Rep 843
You can update the MCU to the Bimmertech MCU (also on the 1st page) once this update is installed. But if you want to flash back to the Andream / Carlinkit / Roadtop MCU you will have to reflash your mmi with the correct software for your unit first then update the MCU. |
08-03-2020, 05:38 PM | #3885 |
Rep 175
08-03-2020, 05:41 PM | #3886 |
Rep 843
08-03-2020, 06:06 PM | #3887 | |
newbie
Rep 25
08-03-2020, 06:31 PM | #3888 | |
Rep 53
would you say the bimmertec mcu is better ? |
08-03-2020, 06:33 PM | #3889 |
Rep 6
MCU Changelog ?
I got the Carlinkit today and installed on my F36 right away and almost everything worked. Upgraded the software with the new 2.0 Custom and it worked , just noticed a bit of pixelation on the outer edge of everything in AA, don't know if this is due to be connecting wireless.
Went to upgrade the MCU and it says: USB Stick with upgrade_mmi.bin update file has not been detected . I could easily change the file name but a few questions before trying upgrading the MCU: 1. My System Version says: MCU Version 10.6.2.0 What would the latest version for Carlinkit be? This forum says MCU 20.06.02, is this the same that I have and It just happen to show wrong version on mine? 2. Can I find anywhere the changelog for the MCU to see the benefits on upgrading? 3. My steering wheel buttons don't do anything on the MCU version it came with . I tried answering a call or hanging up and it didn't work. Would the MCU 20.06.02 fix this? Thank you everyone for the awesome work! Last edited by frviana; 08-03-2020 at 07:07 PM.. |
08-03-2020, 07:28 PM | #3890 | |
Rep 1,217
GEDDES1.50 |
08-03-2020, 07:44 PM | #3891 | |
Rep 84
so i did the Andream B version update and its so much more responsive now when using the IDrive wheel or the steering wheel buttons. before it would lag a lot but now its perfect.
435i M Package, VRSF FMIC, VRSF CP, MHD stage 2+, stock cat
08-03-2020, 08:42 PM | #3892 |
Rep 6
Thank you. It worked. Everything is working now. Just wondering if I leave both Bluetooth connected, where is my call going to be routed through when I answer the phone in the car. How does it Select?
08-03-2020, 09:10 PM | #3893 | |
Rep 1,217
08-03-2020, 09:36 PM | #3894 | |
Rep 1,217
andream, android, android auto, apple, carplay, mmi, retrofit |
