08-05-2020, 07:08 AM | #3983 |
Rep 52
08-05-2020, 07:11 AM | #3984 |
Rep 843
It will, but if you use it, you can not go back to the newer software, which means you are stuck with the custom firmware forever.
And therefore if updates for the older units (which the custom firmware is based on) stop, then you will no longer get updates for your new unit either. |
08-05-2020, 07:36 AM | #3985 | |
Rep 5
08-05-2020, 08:16 AM | #3986 |
Rep 256
so can we use that mcu with the latest custom firmware? i thought we could only use bt mcu with it
08-05-2020, 08:26 AM | #3987 | |
Rep 843
But to flash that mcu now, you will have to update your unit to andream / carlinkit firmware first, then update the mcu then flash back to the custom firmware. |
nitsuj1756.00 |
08-05-2020, 08:56 AM | #3988 | |
Rep 41
i'm tempted to factory reset my phone - it has been a while and i find it often helps with these bugs. maybe that will help. i'll wait to see if someone else has a solution before i resort to resetting the phone fully. its such a nightmare setting everything back up again |
08-05-2020, 09:23 AM | #3989 | |
Rep 5
Yeah factory reset is a real pain. But it often helps. Another tip i read was, that you could look into Androids (OS) App settings and deactivate the option for AA to use WiFi-Data. And just beacause I'm curious: Did you not get the dialogue to choose mobile data when connecting to AA or did you not get to activate mobile data despite choosing so in the dialogue? |
08-05-2020, 09:24 AM | #3990 | |
Rep 78
08-05-2020, 09:35 AM | #3991 | |
Rep 41
mine came up saying it will use Mobile data as this wifi does not have a internet connection. and gave me the path to turn it off if i wanted. still no luck though. yep, even that did not work... |
08-05-2020, 09:42 AM | #3992 | ||
Rep 1,217
08-05-2020, 10:07 AM | #3993 | |
Rep 92
And my new question to get perfection))) Maybe someone have MCU 19.12.12 for Bimmertech firmware? I want to try it with v2.0.0.B0.mod because only this MCU makes button "back" working and bringing me back to NBT menu. Have tried andream MCU's even with renaming to fool bimmertech firmware but it doesn't want to flash. P.S. Have tried all flashable bimmertech MCU's from first page - no luck. ( Last edited by yulian; 08-05-2020 at 10:47 AM.. |
08-05-2020, 10:31 AM | #3994 | |
Rep 92
Try MCU 19.12.12 it works for me but only with "original" carlinkit firmware versions. Last edited by yulian; 08-05-2020 at 10:47 AM.. |
08-05-2020, 10:48 AM | #3995 | |
Rep 57
08-05-2020, 11:04 AM | #3996 |
Rep 15
Man all these widescreen issues, factory phone resets and Developer setting tweaks really makes me appreciate my iPhone 😀.
contracts3444.50 jaypayne0525.00 |
08-05-2020, 11:17 AM | #3997 | ||||||
Rep 15
You will not need to run a 3.5mm cable to the Aux port but you will need to set your car to Aux to hear the audio. Quote:
08-05-2020, 11:25 AM | #3998 |
Rep 1,217
08-05-2020, 11:31 AM | #3999 | |
Rep 1,217
It does for me on my Carlinkit unit using either the latest Carlinkit/Andream mcu or Bimmertech's latest mcu. |
08-05-2020, 11:34 AM | #4000 |
Rep 92
Sadly but no. Only revert to MCU 19.12.12 with any Carlinkit firmware makes it working via 2 sec hold "back" and "menu". Sadly bimmertech 2.0 custom does not support old MCU's. Maybe it's because I have updated all BMW firmware with local dealer recently and I have newer version somewhere, I don't know...
08-05-2020, 11:49 AM | #4001 |
Rep 1,701
Drives: 22 X3MC MBB - C-17 Globemaster
08-05-2020, 12:05 PM | #4002 |
Rep 72
I used to be able to answer and end calls by pressing the "phone" button on the steering wheel, I lost that feature with the latest update plus voice command button used to allow me to control Siri. no longer working.
Any idea? |
08-05-2020, 12:19 PM | #4003 |
Rep 289
Latest update of what? And which versions? What car?
08-05-2020, 12:22 PM | #4004 |
Rep 72
Sorry for not being clear.
I own 2014 X5. Previous MCU version which worked fine with buttons was: 20.5.9.10 and now the version I have is 20.6.2 which fixed other various issues with unit except the new issue is the existing buttons. |
andream, android, android auto, apple, carplay, mmi, retrofit |
