08-05-2020, 12:24 PM | #4005 |
Rep 44
Upgraded to the latest "B" custom firmware from "A" on my Andream and it resolves wired AA auto start and night mode change. However, I have lost wireless AA connectivity even if I connect to wifi using the 12345678 passwd
When I click either the ios or android icons, nothing happens - no warning msg like the USB gives or any hint that it started an app (previously I got a dialog about not being connected). Is there some way to reset all config? Selecting "reset" in the settings menu just reboots - it doesn't reset config Since wired AA works, I'm using that, though i start the car and then connect the wire. Otherwise I sometimes get reboots or failure to connect |
08-05-2020, 12:35 PM | #4006 | |
Rep 1,217
08-05-2020, 12:47 PM | #4007 | |
Matusov
Rep 43
I just flashed the software (not the MCU) on my Carlinkit. I only spent 15-20 min on it and so far I noticed couple of things: 1) It now automatically goes into AA wirelessly after 20 or so seconds 2) As far as "Autolink Mirroring Screen Size Fix" i don't see any changes from previous versions on my X5 F15 NBT 10.25 screen. There are still black bars on both sides. Was hoping it would be full screen... 3) Some odd behavior when trying to go in and out of Mirror Link. If going from AA it did not launch Mirror Link unless I disconnected and reconnected the wire. And the same thing going back to AA from Mirror Link, it would not go back unless I unplugged and plugged the wire back in. Is this normal? 4) The menu button does not exit out of AA or Mirrorlink anymore. |
08-05-2020, 12:52 PM | #4008 |
Rep 2,591
This is because channel 6 is 2.4ghz WiFi, and 36 is 5ghz. 2.4ghz is hugely congested and is very prone to interference.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
08-05-2020, 02:15 PM | #4009 |
Rep 63
Wondering if you can help with my issues.
1- Reverse Camara does not come in, it did when I tested bedore putting it together, prc makes the sound however. 2- if I select Spotify music wont be heard if I dont choose carplay on the phine, it defaults to Bluetooth of car 3 - Calls, same thing as 2, for me to listen I need to take off car, Pretty sure I am missing a step along the line. Thank you in advance |
08-05-2020, 06:02 PM | #4010 |
Rep 1,217
1- Reverse Camara does not come in -- make sure that the camera is set correctly in settings as either original or aftermarket
2- if I select Spotify music wont be heard if I dont choose carplay on the phine, it defaults to Bluetooth of car -- try switching off media audio in idrive bluetooth setting 3 - Calls, same thing as 2, for me to listen I need to take off car, --- not sure on this. I use Android Last edited by muniz_ri; 08-05-2020 at 06:21 PM.. |
08-05-2020, 06:10 PM | #4012 |
Rep 6,723
Check to make sure your connection is good. I had same issue and found that my crimp connection wasn’t making full contact.
08-05-2020, 07:14 PM | #4013 |
Rep 55
Not totally related to this thread but has anyone else got a new voice in Google maps??
The google maps lady has taken the night off by the sounds of it and been replaced by a guy. |
08-05-2020, 07:53 PM | #4014 | |
Matusov
Rep 43
You can change the voice back to English(US) in the Navigation Settings of the maps if you want the lady to tell you where to go. |
08-05-2020, 08:37 PM | #4015 |
Rep 115
Drives: 2015 Nardo Grey M5 Competition
Sorry if this was answered, but I have the Andream system and I have a few comments/questions that maybe you guys could help with. I apologize in advance, but I searched the thread and couldnt find exactly what I was looking for.
I have the Andream unit in my F10 M5 and installed it perfectly. SDK: 25.0.0.5.6.0.0.0 MCU: 20.4.2.14 (downloaded the MCU 20.06.02.zip...need to know how to upload to unit) I use Apple Carplay as well through my iPhone 10. 1. Wifi shows on my phone as Carplay but says below it No Internet Data Available. PW is 8888888. Anyone have this issue? 2. Phone calls come in on the Carplay, but when I call someone or use my calls through carplay I cant hear anyone but they can hear me. Also, sometimes if I answer through carplay the call immediately drops. If I use my calls and have it connected through the BMW BT, both work. 3. USB plug doesnt seem to work but all connections are secure 4. How do I upload the latest firmware into the Andream unit? I downloaded MCU 20.06.02 5. Airplay doesnt recognize because the wifi doesnt have internet data Seeing if anyone could help and MUCH APPRECIATED. |
08-05-2020, 11:22 PM | #4016 |
Rep 93
Just got version 2 installed on my Andream unit, and it seems to work great with auto connect etc. The only problem I have is when I have auto switch AUX on, it seems to switch to it every 1-2 minutes, meaning that if I hear radio, it will switch to AUX by it self.
Does anyone else have this problem as well? |
08-05-2020, 11:30 PM | #4017 | |
Rep 1,217
08-05-2020, 11:41 PM | #4018 |
Rep 93
08-05-2020, 11:47 PM | #4019 | |
Rep 1,217
08-05-2020, 11:55 PM | #4020 | |
Rep 55
This is on an iPhone, maybe it’s hidden somewhere. I don’t mind him, was just a surprise. |
08-06-2020, 02:11 AM | #4021 |
Rep 93
08-06-2020, 04:18 AM | #4022 |
Rep 9
reverse camera wiring help
Hey Guys
I need a little help with wiring an aftermarket reverse camera to my Roadtop MMI box. So I have the wiring as follows from the Motormax wiring diagram: #1 reverse camera - Fitted #2 Green wire #3 Blue wire - connected to reversing light feed Black wire connected to brown feed #4 camera loom - fitted #5 #6 #7 Camera RCA - connected to RoadTop camera input #8 Blue reverse, Red 12v Live, Black Ground #8 is were I need the help do I just connect the Red 12v to the MMI and not connect the Blue and black wires? Any help appreciated thank you! Last edited by Glayham; 08-06-2020 at 05:51 AM.. Reason: Updated information |
08-06-2020, 06:31 AM | #4024 | |
Rep 53
jaypayne0525.00 |
08-06-2020, 06:38 AM | #4025 | |
Rep 9
At the camera end (number 3 in the diagram) I have connected the blue wire to the white wire on the reversing light and the black wire to the brown wire on the reversing light. I think thats correct but I'm not getting a signal. The RCA is connected at the front. The connections I'm unsure about are Number 8. Any ideas? thx |
08-06-2020, 06:42 AM | #4026 | ||
Rep 53
andream, android, android auto, apple, carplay, mmi, retrofit |
