08-06-2020, 06:45 AM | #4027 | |
Rep 9
as in the diagram |
08-06-2020, 06:47 AM | #4028 | |
Rep 53
08-06-2020, 06:54 AM | #4029 | |
Rep 9
08-06-2020, 07:09 AM | #4030 | |
Rep 9
08-06-2020, 07:39 AM | #4031 | ||
Rep 53
08-06-2020, 09:46 AM | #4032 |
Rep 143
Just to make sure I understand.
I currently using carlin mcu and custom v1 and actually really happy with it (no echo on calls after playing with the setting) so i am really happy with it. The only thing i would like to change is auto connect to AA. 1. So I need to install v2.0.B0.mod and then bimmertech MCU? 2. If I would like to go back, I need to install carlink MCU and then custom V1 or carlinkit firmware? Thanks. |
08-06-2020, 09:49 AM | #4033 | |
Rep 843
08-06-2020, 10:15 AM | #4034 |
Rep 21
Bimmertech MCU uses Steering wheel buttons option, what ise very terrible and not possible switch it on/off. No suggest install this MCU. Flashing back to AA MCU is not possible with Bimmertech FW.
08-06-2020, 11:47 AM | #4035 | |
Rep 15
08-06-2020, 12:38 PM | #4036 |
Rep 93
08-06-2020, 01:44 PM | #4037 | |
Rep 1,217
08-06-2020, 02:13 PM | #4038 |
Rep 102
Custom software
Hi Cossie/Firefly
Wonder if you can answer a query or two. I am now running the Custom S/W v2.0 and the latest Bimmertech MCU. I have been getting told that when I make/receive a call (iPhone XR) the other person is getting an echo of their voice. Not Had that before. I noticed in the settings the following options: Microphone Volume Microphoe OP Gain Microphone PGA Gain Microphone AEC Delay Microphone AEC Quality After a quick Google AEC seems to be for correcting echo issues with Microphones in general. It is default set to 0 but has a range of 0-20. I have tried setting it to 10 and so far seems to have improved. Am I on the right track with this? Also, any idea what the other settings are for (other than the obvious volume)? Cheers and thanks again for a superb piece of work with this Custom S/W Last edited by contracts34; 08-06-2020 at 03:06 PM.. Reason: Updated |
x-m4n148.00 |
08-06-2020, 04:05 PM | #4039 |
Rep 12
Hi all,
I noticed that, in AA, multimedia content doesn't resume automatically. I double checked this option in AA car settings and in AA phone options, and it is activated in both cases, but it doesn't resume automatically after reconnection. I have to do it manually. I'm using new custom V2 version and the last Bimmertech MCU. Can someone help me to solve this little issue? Thank you in advance. |
08-06-2020, 04:56 PM | #4040 | |
Rep 2,591
Using the custom v2, I noticed that the autolaunch doesn't work if you're in PDC view when the unit tries to switch. Not a big deal, just hold menu button.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
08-06-2020, 05:31 PM | #4041 |
Rep 37
Hi guys, I have only rear PDC (and no button to activate/deactivate in center console).
Mi car has manual transmission and I installed the Custom version 2 by Firefly1337 and cossie1 with latest bimmertech MCU. I have 2 poblems/questions: 1- How do I activate front camera? The camera icon has gone, it was in previows version but that new one doesn't have it and I don'k know how to ativate front camera. 2- My car (BMW 3 series F30) only has rear PDC and there is no button to turn it off/on. When I put reverse gear, PDC sensor starts and it doesn't deactivate even I put neutral or firts gear, PDC only switch off when I move the car forward. In this case, I can't back to Andream by pressing MENU button even it is working as spotify was running and it sounds when rear PDC stops. Do you know how to solve these issues? |
08-06-2020, 05:56 PM | #4042 | |
Rep 843
2 - Afaik pressing menu should work, but maybe press and hold back for 2 seconds will work instead. |
eduwinner3.00 |
08-06-2020, 07:21 PM | #4043 | |
Rep 12
08-06-2020, 07:48 PM | #4044 |
Rep 115
Drives: 2015 Nardo Grey M5 Competition
08-06-2020, 09:59 PM | #4045 | |
Rep 1,217
Volume: 13 Microphone Volume: 18 Microphone OP Gain: 4 Microphone PGA Gain: 0 Microphone AEC Delay: 0-20 Microphone AEC Quality: 0 Last edited by muniz_ri; 08-06-2020 at 10:16 PM.. |
contracts3444.50 |
08-07-2020, 02:01 AM | #4046 | |
Rep 102
08-07-2020, 02:21 AM | #4047 |
Rep 79
For cic users
135€ € 135,28 29% Off | Auto Draadloze Carplay Activator Android Auto Interface Box Voor-Bmw Cic 1 2 3 4 5 6 7 Serie e60 E70 E71 E84 F01 F02 F10 https://a.aliexpress.com/_dX1NIf0 |
08-07-2020, 03:01 AM | #4048 | |
Rep 41
Must have been some odd setting or app causing the issue. It now works flawlessly. Thanks to all who helped I think people might be to quick to point fingers at the MMI not working correctly when our phones are choaking on a hundred different apps all fighting to work Last edited by Furbz; 08-07-2020 at 03:26 AM.. |
andream, android, android auto, apple, carplay, mmi, retrofit |
