11-07-2018, 03:44 PM | #47 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
Thanks.
11-07-2018, 04:56 PM | #48 |
#gotboost
517
Rep 861
5 days here and no condensation.....though we most likely have much less humidity than NC
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
11-07-2018, 05:03 PM | #49 |
¯\_(ツ)_/¯
537
Rep 1,000
What wire did you guys tap for the turn signal? brian's video said he mixed them up from the harness so is it black with grey=Passenger and the black with white= drivers ?
11-07-2018, 05:35 PM | #50 |
Rep 472
Sorry to hear that...I'm installing this weekend I'm really hoping I don't have any condensation issues. You'd think Depo quality would be better than the regular eBay knockoffs.
11-07-2018, 06:57 PM | #51 |
#gotboost
517
Rep 861
I followed Shumile Swift's video which looked (and was) a lot easier. You use the wire tap on the 2nd wire (black w/ gray stripe) on each side. No messing around in the battery compartment
11-07-2018, 07:46 PM | #52 |
Rep 29
I ended up using a black and yellow wire for the passenger side turn signal and it worked perfectly.
2013 F30 328i N20 | Alpine White | OEM 437M | BCRacing Coilovers | Muffler Delete | DEPO Headlights | Blackline Tail Lights | Debadged | F80 Style CF Mirrors | M-Sport Front |
11-07-2018, 07:53 PM | #53 |
¯\_(ツ)_/¯
537
Rep 1,000
11-08-2018, 11:41 AM | #54 |
¯\_(ツ)_/¯
537
Rep 1,000
Here's the blackline on BSM
11-10-2018, 03:58 PM | #57 |
Rep 472
Tried to install today and I couldn't get one of the inner Depo tail lights in. It's almost like it didn't line up correctly. Any advice from someone who has installed already?
11-10-2018, 07:50 PM | #59 | |
Rep 112
Also, it appears that the insulation foam around the inner light is different than OEM, the depo foam is thicker and the outer edge actually moves a bit when i tried to press on it. Overall, the quality seems decent and hope the insulation foams will last. Edit: any long term owner of these lights? I noticed that the outer light harness is not really waterproof (exposed connectors and etc). The area where the harness/resistors are located is not waterproof by design, so I'm worried about the long term exposure to water. So far I've used electrical tape to mask the exposed connectors and will coat it with silicone gel. Last edited by pentagon; 11-11-2018 at 04:51 PM.. |
rcaso26331.00 |
11-11-2018, 09:01 PM | #60 |
Rep 370
Just installed them today shut out to Bryan at kiesmotorsport!
So far so good love the contrast on white I’m glad I went with the black one! |
Bryan_KiesMotorsports390.50 MrcsYcnth17.00 |
11-12-2018, 09:25 AM | #61 |
Rep 390
I installed last week. Everything is fine. Regarding the wire tap, I realized that the color code on the tap wire matched the color code on the light side of the plug so just tap into the wire that lines up with the same color wire on the other side of the plug. That might sound confusing but if you look at the connector behind the outer tail light you'll immediately understand what I'm talking about. I'm not sure why Bryan didn't tap in there.
Best,
Charlie 2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp |
11-12-2018, 09:47 AM | #62 |
Rep 187
Will the Depo F30 Blackline tail lights fit an F31?
These: https://www.uniquestyleracings.com/s...3016lciled4pcs If not, what are the options for the F31's?
2016 F31 M-Sport THP | 1998 Z3 1.9L Dinan Stage 3
11-12-2018, 10:20 AM | #63 |
391
Rep 449
11-12-2018, 10:21 AM | #64 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
Very nice. Can't wait to get mine!
11-12-2018, 10:22 AM | #65 | |
391
Rep 449
Bryan |
rcaso26331.00 |
11-12-2018, 12:01 PM | #66 | |
#gotboost
517
Rep 861
