12-06-2018, 09:50 AM | #1 |
Rep 482
Drives: 2014 Glacier Silver F30 328i
Considering changing my set up. F30 328i xDrive tire size help?
Good morning,
I’m currently running a squared set up 245/40/18. My car is lowered 1 1/2 inches on Dinan lowering springs and I’m also running 12mm spacers. I’d like to go wider (255) in theory in the rear to get a more fatter look but I’m not sure if I’ll get tire rub or mess up my xDrive. Wheels are VMRV710's 18 x 8.5. What would be a good suggestion for tire sizes? I heard some people running a 225/40/18 in front and 255/35/18 in rear. With running a 225 in the front wouldn't that make the tire size look skinnier than the rear? Thanks~
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
12-06-2018, 10:20 AM | #3 |
Rep 482
12-06-2018, 11:33 AM | #4 |
Rep 4,318
oem is + or - 26". 255/35/18 is 25", too small. just run square 255/40/18 on the 18x8.5" VMR, less spacers. keep it simple for your x-drive. then you can rotate any direction as well.
MacklinUSOB518.00 |
12-06-2018, 04:05 PM | #5 |
Rep 482
I'm trying to get a wider look in the rear. How about running 245/40 in the front and 255/40 in the rear? Keeping the spacers because I have too much under tuck.
12-06-2018, 04:10 PM | #6 |
Rep 4,318
On an xdrive youd be close to the limit of difference in diameters and probably run into xfer case/driveability issues. Is it worth the risk?
12-06-2018, 04:14 PM | #7 | |
Rep 482
So 255/40/18 squared and drop the spacers?
12-06-2018, 04:27 PM | #8 |
Rep 4,318
See where you're at without, then add spacers as necessary
here is 255/40/18 on 18x8.5 +35 square... https://f30.bimmerpost.com/forums/sh....php?t=1275285 Last edited by alohasurftoad; 12-07-2018 at 11:23 AM.. |
