03-29-2021, 06:40 PM | #1 |
Rep 172
Rear brake light bulbs
Hi,
Has anyone replaced the rear brake lights before? Seems easy. Realoem mentions H21W bulbs but a quick search seems to suggest that the f30 are using p21W. Thanks! |
03-29-2021, 09:57 PM | #3 |
Rep 535
It's not a difficult job but be mindful when removing the bulb cradle. The tabs are very easy to break off, especially if you're doing the task in cold weather.
03-29-2021, 10:14 PM | #5 | |
Rep 172
Does it require any coding when replacing with LED? Is it just brighter or? If so, may need to change both sides. Possible to share the link if you still have it? |
03-29-2021, 10:26 PM | #6 |
Rep 16,065
LED are brighter and react faster. Coding is always required with LED. I used these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The manufacturer part # is B01LW2IPSR, search that to find a source local to you. |
