05-13-2023, 11:03 AM | #1 |
Rep 38
Retrofit heated manual seats to electric with memory sport seats
Hello, my F30 came with the basic fully manual seats by the factory. The only plus is that they are heated. I'm thinking of swapping them with the sport leather version, but it would be nice if I could use the fully electric version with memory, and of course being heated as well. My question would be if I have to replace any module or they just need to be plugged and coded? If replacing any modules could be complicated, I'm thinking of using the same spec (fully manual + heated) for the sports ones, as it's simpler to just plug and play them.
05-13-2023, 12:20 PM | #3 |
Rep 38
I don't have any knowledge of the required parts, but since you put it this way I guess I should just stick with the manual heated sport seats and I won't have to worry about retrofitting any module or electrical parts.
05-17-2023, 10:27 AM | #4 |
Rep 57
It's not too complicated if you're happy with adding a few additional wires to power the seat functions and to connect them to the K-CAN2/LIN bus. After that you'd just need to code them to the car by amending the VO using E-SYS and potentially injecting the CAFD.
I've gone from manual heated sport seats to fully electric with memory with success. I'm really pleased with the retrofit, it's a nice upgrade. Take a look at these threads if you want further info: - https://f30.bimmerpost.com/forums/sh...1068546&page=5 - https://www.bimmerfest.com/threads/f...trofit.891713/ |
05-27-2023, 09:10 AM | #5 | |
Rep 38
05-28-2023, 03:24 PM | #6 |
Rep 57
Sure I don’t think there will any issue doing that. In effect those pins you connect in to the yellow connector will just not be connected to anything. When you find the seats though they should then just be plug and play, bearing in mind you may need to do code them in.
05-29-2023, 02:27 AM | #7 | |
Rep 38
09-29-2023, 04:27 AM | #9 | |
Rep 38
12-14-2023, 10:34 AM | #10 |
Rep 38
I haven't found a good pair of seats that match my black interior so far (the seats I found a few months ago on my last message were actually brown), but I just found a very good used black set. The only question is, since the set is coming from an F36 model, is the back seat compatible with my F30?
12-19-2023, 03:05 AM | #11 | |
Newbie with some skills
22
Rep 70
Drives: BMW F30 318D Luxury
Retrofit : S676A, S3AGA, S481A, S488A, S459A, S5ACA, S5DCA, S6NKA, S8THA (emulator), S710A |
12-23-2023, 05:22 AM | #12 |
Rep 38
Hi, thanks for the reply ReMiii40, I know the front seats are compatible, but I was actually interested in the rear seat instead, since it's coming from a 4 series Gran Coupe.
01-02-2024, 03:47 AM | #13 | |
22
Rep 70
Lateral trim panel left : F30/F35 only (n°9) Right cloth/leather backrest cover : F30 only (n°8) Cloth/leather seat cover : F30/F31 only (n°5)
br4to925.50 |
