07-22-2018, 10:49 AM | #1 |
Rep 640
Drives: 2008 M3 (E93)
Can someone please explain the difference flash vs JB4
Hi, can someone please explain how the mission performance flash is different in comparison to just adding a JB4? Sorry but I’m new to the whole tuning game and this would be the first car I’ve done in a very long time. Just trying to understand how it works and get in on the group buy if it makes sense.
Also, can it be run On a mostly stock 340? I don’t want to half ass anything and since I’m leasing the Only upgrades I planned on doing were dinan midpipe, bms Intake and the tune (if I can) when I take delivery of my car. I just don’t want to do the tune for example and have things breaking/have issues because I didn’t do a full exhaust or change the DP. Any feedback would be really appreciated, thank you. |
07-22-2018, 10:59 AM | #2 |
Sedan Driver
389
Rep 1,018
No flash available for b58 engine made available yet. But protuning freaks cracked the ecu a couple months ago.
Savageenterprise980.50 |
07-22-2018, 11:02 AM | #3 |
Rep 640
07-22-2018, 11:49 AM | #4 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
JB4 will run on a pure stock car. More performance parts more power. JB4 is a piggy back. Intercepts the sensor readings & converts them before passing them on to the CPU.
A flash re-codes the ECU itself with new parameters. Have not fooled with it since 335is but the JB4 was invisible to BMW when it was removed. With a flash the ECU had a counter that recorded the number of updates. BMW could use the counter to recognize that the car had run a tune even after it was removed. Would be an issue on a major warranty claim. Both had their advantages & disadvantages. In the bad old days we ran what was know as a "stacked" system. A piggy back with a flash tune of the ECU. At the time it created the most power you could get from the engine.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
07-22-2018, 12:06 PM | #5 |
3127
Rep 5,264
You are correct. That said they make a claim but don't show any dyno runs that I saw. Not sure what the 380 HP means. Is in crank or WHP. There will always be a spread between crank & wheel with crank producing the higher number.
Kevin
07-22-2018, 12:09 PM | #6 | |
Rep 640
I see....thanks for the breakdown. Sounds like a JB4 would serve me well enough then, just figured if costs were comparable and the flash would get more out of the car I would consider it. Car will be a lease and likely will give it in after the 3 years and don’t want a lot of headaches lol. From what I’ve gathered the JB4 seems to be pretty reliable for most as well |
07-23-2018, 12:30 PM | #7 |
Cheapskate
4447
Rep 4,993
I have some time and bored on my lunch break, so here's a breakdown from my experience.
Flash Tune = ECU program JB4 = Piggyback ECU Program = Defines how the car will run Piggyback = Plugs into existing engine harness with a control module that intercepts the input signals and modifies them before they are read by the ECU program, allowing the car to run outside it's original parameters without detection. Pros Flash Tune = more seamless integration with the car, writes to the ECU like the OEM stock or MPPSK tune, no added clutter to the engine bay, can be specifically written for your car/setup/region, fail-safes will react more quickly Piggyback = cheaper, easier to develop (so it gets to the market quicker), easier to install/remove, virtually invisible to ECU Cons Flash Tune = Can be seen by dealer/may affect warranty work, typically costs more, need to make sure your ECU tune is safe and from a reputable vendor (a lot of risk going cheap), need a professional to install or additional cost for installation hardware Piggyback = Worse driveability especially at the limit, adds an extra step before fail safes respond so more dangerous way of doing things, less efficient/less power since still held back by some OEM limitations. Personally I will never run a piggyback. I've seen the logs and how choppy it can look, and I've heard enough stories of cars working great one minute and falling on it's face the next. Your car is already analyzing a lot of data in order to control what it does the next moment safely, and you're adding another step in that process. So it's constantly tugging back and forth. A proper flash tune completely rewrites how the car will behave and will respond as seemlessly as OEM when developed properly. Just be weary of fly by night operations, because a lot of people try tune sell tunes on facebook/instagram and can be hit or miss on reliability. |
07-23-2018, 01:08 PM | #8 | |
Rep 640
kern4174446.50 |
07-23-2018, 01:16 PM | #9 | |
Rep 10,473
I’d go with them before a JB4. |
07-23-2018, 01:16 PM | #10 | |
3127
Rep 5,264
That said if its an ordered lease car the MPPSK is a viable cost alternative when included in the lease
Kevin
07-23-2018, 01:20 PM | #11 | |
Rep 640
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
07-23-2018, 01:24 PM | #12 | |
Rep 463
kern4174446.50 |
