10-08-2018, 09:42 AM | #1 |
Rep 397
Removing light holograms
In short I have leftover holograms and I realized I did not work the polish correctly and used too much force.
I need to get these out but I already applied Gtechniq c2v3 spray on. (Not the lacquer) Question is do I need to remove the Gtechniq first? Or can I just re polish again to get the holograms out? |
10-10-2018, 03:49 PM | #3 |
Rep 20
I would wash the car and then do an IPA wipe down to get as much of the sealant off as possible. Carpro Eraser or Gyeon Prep would work as well. I wouldn't worry about marring the paint since you'll need to polish anyway.
Then a light polishing should take care of the holograms. |
Tribalpinoy91193.00 |
10-10-2018, 07:34 PM | #4 | |
Rep 397
10-11-2018, 10:54 AM | #5 |
Rep 20
Spray the IPA or prep solution liberally and wipe down with towels until it's dry. The point of this is to remove as much of the sealant as possible prior to polishing. You likely will not be able to remove all of it if you applied c2v3 recently, so don't stress and over wipe.
Less sealant on the paint will lead to less residue on the polishing pad, which will make each polishing pass more effective. |
10-11-2018, 11:10 AM | #6 | |
Rep 397
I have a random orbital which i used initially but i used it very fast and very lightly just to get the product on. Since I put holograms in with the machine I'm afraid to use it again so I plan on doing it by hand. Thoughts? |
10-11-2018, 02:59 PM | #7 | |
Rep 1,033
You'll need a decon wash, clay then use an IPA wipe down to remove the residual. |
10-11-2018, 03:49 PM | #8 | |
Rep 20
There's no need to clay this car since it was polished and decontaminated recently. Claying does not remove sealant, and it would just be an extra, time-consuming step. Personally, I would wash the car normally with whatever soap you have on hand, not a decon soap, and do an IPA wipe down per my previous post. While it won't remove freshly applied sealant, it will have a weakening effect. IPA will most definitely remove sealant that's been on the car for several months. Furthermore, wiping the car down with IPA or some other prep solution allows you to wipe dust off the car prior to polishing without excessive marring. With all that said, you can go straight from wash to polishing if you choose. The IPA wipe could be an extra step that may not be worth your time. |
10-11-2018, 04:01 PM | #9 | |
Rep 20
Doing this by hand will likely result in more holograms due to pressure points created by your hand. It will also take forever so don't do that. Good luck! |
10-11-2018, 05:58 PM | #10 | |
Rep 1,033
Do you have links for these tests? |
10-14-2018, 11:31 AM | #11 |
Rep 397
EDIT: It took roughly 2 applications of the polish and terry cloth pad using random orbital buffer to get 75% of the holograms out.
After further inspection Using my iphones flashlight feature later today I found more holograms. I don't understand how because i used an led flashlight in a pitch black garage and couldn't spot a single hologram. Is another polishing process all that is needed? Should i switch my pad out to something else? EDIT: I polished again this time using a dual action with megs m82 swirl free polish instead of the ultimate polish. Using a blacking finishing foam pad. It initially looked like i instilled more holograms but i found out that it was just left over polish oils. Wiping down with wet microfiber and drying resolved the "holograms" |
11-05-2018, 09:43 AM | #12 |
Rep 397
Edit: The previous post i used led lights point at different angles to find the swirls in a garage could not find any. Under sunlight however, I noticed very faint holograms in a straight vertical pattern that would move across the surface evenly.
After some research I bought Menzerna 3800 polish and went to work. I checked before and after to see what the results were going to be. The menzernas helped a lot on this very soft paint BSM I have. HOWEVER, This time when i pulled the car out into the sun I noticed deep looking holograms. This was due to the gtechnic csv3 i applied right after the polishing. I sprayed with IPA and the hologram like reflections were removed. I saw some holograms still on the car and now I'm completely puzzled. The hood is fawless no holos, i used a 4 in white polishing pad. The doors i used a 6.5 pad and i think that was caused the marks. My white LC polishing pad i noticed was very dense and stiff like an orange pad unlike my 4in white polishing pad that was very soft and squishy. I'm thinking I was mistakenly sent a heavy duty pad. I ordered a astro pneumatic 50sl light thats supposed to match the sunlight so i can spot these without needing the suns light. In a panic i hid the holos using a wax. I plan on wiping down with an IPA this weekend and re assessing followed by utilizing my white 4in pad with the menzernas, if that doesn't work out perfectly I'll step up to a 4in black finishing pad |
