02-07-2019, 07:31 PM | #89 | |
Rep 225
02-07-2019, 08:24 PM | #90 | |
Rep 964
Also, off the line, I think I could probably do at least a 3.8 sec 0-60. It's just so planted and launches so hard. The weight must help it. I think the extra WTQ makes up for any loss experienced from being heavier. |
02-07-2019, 08:40 PM | #91 |
Rep 1,369
The true weight difference is more in the range of 570 lbs. An X3 M40i is a bit under 4300 lbs and a 340i X-Drive is a bit over 3700.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
02-07-2019, 10:35 PM | #92 |
Rep 1,219
02-07-2019, 10:43 PM | #94 |
Rep 1,219
I’ll take 6 tenths off my 1/4 mile time please
02-08-2019, 06:07 AM | #95 |
Rep 36
Got it! That morning sound of the cold start is back
awilki0101518.50 |
02-08-2019, 08:11 AM | #96 |
Rep 308
02-08-2019, 01:39 PM | #97 |
Rep 62
Tried the new version today.
Ran the car about 10 miles in total so not really a baseline but still... The first 5 miles I ran 2 second burble and 50% aggressiveness. It worked great. On the way back I ran 1 second and 80% aggressiveness. But it was less aggressive. Not logical imo. Or does that have to do with the shorter duration? Flashed 1 second and 100% but didn't test it yet, will do that tomorrow. |
02-08-2019, 02:40 PM | #98 | |
Rep 308
02-09-2019, 02:20 PM | #99 |
Rep 15
Trans flash question.
So I read the user guide and know what I need to do in order to flash my 440. I have my Android device, downloaded the app, and purchased and received the license permission to flash. The only thing I am waiting on is the K+DCAN cable (It gets deliver in 2 days). My question is: If I am flashing to Stage 2, do I need to flash the transmission, if so, how can I do that? I am in Playa Vista, CA and am hoping that I could somehow flash it on my own or have someone around the LA area help with with it.
I would really like to flash to Stage 3 in the future because I have a VRSF catless Downpipe with the MPPSK and a AP air intake. |
02-09-2019, 03:30 PM | #100 | |
Rep 308
02-10-2019, 03:33 PM | #101 |
Rep 15
Borrow K+DCAN Cable?
So my K+DCAN cable is taking way longer to get delivered than expected. Is there anyone in the LA area that I could borrow a cable from or a shop that I can take my car to get it flashed?
02-11-2019, 06:27 AM | #102 |
Rep 36
Here are my results so far with the latest version. I tried both stage 1 and stage 2.
Sports display HP gauge shows 320 max on both stages. TQ gauge shows ~360 ft lbs on both stages. (I am completely stock other than this flash, so TQ limiter could be in play) Exhaust valve always open has worked on both maps. Haven't noticed anything with the burble option yet. My current settings are 50% aggressiveness, 3 sec duration sport, 3 sec duration base. Also tried 30% aggressiveness and setting sport duration to MPPSK. Haven't had the right conditions to test vmax. |
awilki0101518.50 |
02-11-2019, 08:54 AM | #104 |
Rep 36
Butt dyno felt a huge difference initially when I went from stock to stage 2. Stage 1 did feel a little weaker than stage 2 from a stand still, but my TCU hasn't been flashed so I should be plagued by the torque limiter when using stage 2. I couldn't really tell the difference between stage 1 and 2 from a rolling start. I'm going to flash back to stock to see if my butt dyno notices a difference again.
awilki0101518.50 |
02-11-2019, 04:35 PM | #105 |
lurker
24
Rep 130
Tried all the new feature selections on st2, works very nicely.
One thing is I did not see any difference when changing "duration base". Is this because I have MPPSK? Am I correct this setting should adjust / add burble in Comfort Mode? Or what does "duration base" do? Of course had to try 7 seconds duration and 100% aggressive. Wow, that's obnoxious! Many times I will ride in comfort when I want no burble, so 100% aggressive and 3-4 seconds is probably where I will wind up. --MW |
02-11-2019, 06:19 PM | #107 |
Rep 36
Went back to stock for a while and couldn't wait to flash stage 1 again. The pull stage 1 has over stock is great. Need to get my TCU flashed so I can take advantage of stage 2.
02-11-2019, 06:22 PM | #108 |
lurker
24
Rep 130
My THOR is in the mail, I can let you know in a day or two. Are using the THOR for initial DME unlock? It has been recommended only to use the k+dcan cable for that. I hear the THOR is more for flashing maps and future logging. --MW
02-11-2019, 06:38 PM | #109 | |
Rep 36
Also, not sure what type of phone you are using, but there was an option that I disabled on my phone called "switch to mobile data". This option would disconnect me from a wireless network if it didn't have internet access. |
02-11-2019, 06:42 PM | #110 | ||
Rep 198
