BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
proTUNING Freaks
      11-25-2019, 07:52 AM   #199
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
Originally Posted by bacon_45 View Post
http://www.bootmod3.net/log?id=5ddbc833c090c670d017873b
Hey guys, here is my e30 stage 2 log I did! its a long one for best results, thank you!
Looks typical. Like most you're pushing 18+ even though request is 16, so there's some throttle closure as the car tries to compensate. Timing actually looks very high and clean. Higher than others I've seen.
I know some people ask if the AGG maps make more power and have different settings, and it seems like in some cases it does. I added your targets to the OP for everyone's reference.
Instagram @kern417
      11-25-2019, 03:14 PM   #200
OzBMR
OzBMR's Avatar
Australia
535
Drives: BMW M140i
Looks really nice bacon. Interesting that HPFP target is 3169 and actual is even higher.
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s 10.93@127mph
Stock DP, XHP, MHD 95/102 OTS E30 fuel, Hoosier DR2 11.5@121mph about 8.0s 100-200
      11-25-2019, 09:03 PM   #201
InstigatorX
Drives: 2018 440i GC
2018 440i GC w/ MG stage 1 v2.7 93 octane
https://datazap.me/u/instigatorx/log-1574034220
https://datazap.me/u/instigatorx/log-1574034516
https://datazap.me/u/instigatorx/log-1574034421
Thoughts?
      11-25-2019, 09:37 PM   #202
bacon_45
Drives: 2018 340i BM3 FBO
Thanks for looking at it brother, any idea how I can minimize the throttle closures or is it just tune based? Funny how my timing is good when I am in SoCal!
      11-25-2019, 09:39 PM   #203
bacon_45
Thanks for looking at it boss! I am surprised my HPFP is holding out so good on e30.
      11-25-2019, 10:46 PM   #204
kern417
Cheapskate
Yeah it seems to be tune based. If you don't feel anything in the car, I wouldn't worry about it. Seems to be the car's way of controlling boost.
Actually looking at it again, there are several dips. How are you verifying your E30 blend? Are you measuring the pumps actual percentage?
Instagram @kern417
      11-25-2019, 11:28 PM   #205
neonnblack
Drives: 335i 6MT/e46 330xi
Are you logging in 4th, traction control completely off (long press on button) from 2.5k rpm to 6.5k or so?
The logs are a little difficult to read although it could be how mflasher logs. Your first few the timing correction especially on cyl 3 are a little crazy but the last one seems okay.
      11-25-2019, 11:31 PM   #206
neonnblack
And the boost being in hpa is throwing me off as 2200 hPa is equal to about 31 psi.
      11-26-2019, 02:22 AM   #207
SC_B5X
SC_B5X's Avatar
Drives: 2016 BMW 340i
So I got around to buying 100% methanol from my local dragstrip and decided to do a 75/25 Meth/Water mix and test it out with my custom tune (Tuned for E30 + 50/50 Meth/Water). My rail pressure has been dropping pretty bad with E30, so I tried E20 + the 75/25 mix, here are the results.
3rd Gear Log:
https://datazap.me/u/richmichael97/w...54-55-56-57-58
4th Gear Log:
Currently running 504cc ProMeth Nozzles. I just Ordered 755cc ProMeth Nozzles and starting to wonder if i'll even need E85 with the increased methanol concentration.
Instagram: SC_B5X
2016 BMW 340i M-Sport Pkg
Pure 800 Turbo, Dorch Engineering Stage 2 HPFP, VRSF 4.5" Downpipe, Remus Axleback, CTS Turbo Intake, XHP Stage 3 Trans Tune, and Custom E50 Wedge MHD Tune
      11-26-2019, 06:12 AM   #208
Nugget
Nugget's Avatar
Australia
429
Drives: 2017 M140i, 1994 M3, 1997 M3
2011 BMW 135i  [5.00]
My OTS e30 logs generally had very clean timing, consistent between cylinders, but maxed out around 15 degrees.
Boost was very similar.
It is also interesting that 6th gear in the auto maxed out about the same speed as 4th in the manual gearbox.
      11-26-2019, 08:44 AM   #209
kern417
Cheapskate
yeah, took a while for me to get it clear in my head. they do things very differently with their units and logging parameters.
Looks like you have some throttle closures due to overboosting. Again, pretty typical. I guess no B58 tuner has it 100% dialed in for everybody. Also interesting that your boost targets increase to 20-21 psi but the turbo never gets there. It stops between 18-19psi.
3rd Gear Log:
4th Gear Log:
Looks really strong bro. 20+ psi and 16° advance is niiice. I'd just say pay attention to your partial throttle timing and make sure you have nice, progressive mapping on the meth kit. The octane will definitely compensate for less ethanol, but when you spray and how much you spray will keep it happy in scenarios that aren't full-throttle.
Yeah our 4th is ridiculous. I've never had a car where 4th gear went over 120, much less up to 140. It does make logging more difficult.
Instagram @kern417
      11-26-2019, 08:49 AM   #210
kern417
Cheapskate
So I'm trying to wrap my head around our throttle closures. It already seems ridiculous to me that an electronic wastegate can't keep up with DME boost targets, but on top of that its using the throttle angle to compensate. Seems like everyone sees them across all tuners. Not as bad as the JB4 days, but still a factor that's not ideal.
Is it because of VANOS? I mean technically throttle angle is just an interpretation of the intake valve lift, right?
Is it because we don't have an actual diverter valve, so the car uses the intake to bleed off boost in a similar fashion?
Actually it might make sense if the throttle plate itself closes to reduce boost pressure in the manifold, then slowly bleeds air back in while the wastegate is adjusting.
And WHY THE HELL can't an electronic wastegate keep up on it's own?
It's starting to make more senses why big boost went with an aftermarket wastegate + controller combo.
Instagram @kern417
      11-26-2019, 09:23 AM   #211
enemigo13
Drives: F30 340xi
ewg learns, thats why after some tune “run in” you have less throtte closures.
also you can make tune which runs actual load below target in learning
process, not above. you will have 30-40 hp less in the lerning period but
no annoying closures which you can feel with butt
      11-26-2019, 10:34 AM   #212
kern417
Cheapskate
so I know my logs aren't showing anymore, but I definitely remember the main difference between v2.0 and the previous BM3 revision was "improved boost control." When I ran logs, all they did was request 14psi until 3000rpm or whatever, and then as the car overboosted it bumped request up to 16.5. So it looked more like they were chasing the wastegate response time rather than allowing the car to learn.
Personally I've only seen throttle closures in my logs. I've never felt it in the car on an OTS tune. The boost is smooth and consistent, so the actual throttle angle changes play no effect in the butt dyno. It's just weird that the wastegate response is so slow that throttle angle has to come into play. I've never had that issue on previous cars with stock or aftermarket boost control. Even on my stock log, the throttle closes to 60% because boost spike to 10psi when target was 8.
Instagram @kern417
      11-26-2019, 07:42 PM   #213
Nugget
Nugget's Avatar
Australia
429
http://www.bootmod3.net/log?id=5dd53578c090c613cffdf93a
This is an unfinished custom map for 93/98 and pure stage 2.
I never get throttle closures but it's also not overboosting on initial spool up.
I was also experimenting with no lift shifting and it was very effective.
No more throttle closure post shift it just pulled straight away.
So that's an option for those with a manual and little mechanically sympathy.
kern4173135.50
      11-26-2019, 09:49 PM   #214
kern417
Cheapskate
Nice. Who's doing the tune? And what clutch are you using?
For NLS it looks like you're just power shifting. Not fuel cut in the tune since your revs are spiking. But the car is closing throttle to compensate while your foot is flat sorry but this stuff with throttle angle automatically adjusting on it's own is hilarious to me.
I won't judge timing since it's unfinished.
Instagram @kern417
      11-27-2019, 05:53 AM   #215
Nugget
Nugget's Avatar
Australia
429
Cary Jordan is doing the tune, Sachs Performance clutch.
Yeah it's not a proper NLS, I just never let off the pedal.
Not something I will do all the time but Cary was interested to see what happens as I asked him if he can figure out the rev hang issue.
kern4173135.50
      11-27-2019, 06:02 AM   #216
kern417
Cheapskate
The throttle literally closed for you. I don't know if that's a rev limiter thing or what, but way less efficient than cutting spark considering it still jumped 300rpm.
Instagram @kern417
      11-27-2019, 09:04 PM   #217
SC_B5X
SC_B5X's Avatar
So I did some more experimenting since my last post earlier, I tried going with a full tank of 93 octane and half bottle of BOOSTane Professional on my custom E30/Meth tune. Here is the log. No timing corrections or rail pressure drops.
I'm thinking about getting retuned for Boostane until I have the money to drop on the B58TU pump.
Instagram: SC_B5X
kern4173135.50
      11-29-2019, 11:37 AM   #218
joeyb26
Drives: 2016 340i xDrive M-Sport 6MT
Any thoughts on these logs? I had issues with my tune so Support wrote me a custom tune to eliminate clutch slippage i was having. Had a lot of slipping last night but this morning when I went to log it, I couldn't get it to repeat the issue
http://www.bootmod3.net/log?id=5de12f0ac090c6449173fad0
http://www.bootmod3.net/log?id=5de12f3ec090c6449173fad1
http://www.bootmod3.net/log?id=5de1300cc090c6449173fadd
http://www.bootmod3.net/log?id=5de14bb9c090c6449173fb7a
http://www.bootmod3.net/log?id=5de14c5cc090c6449173fb83
2016 340i xDrive 6MT
      11-30-2019, 12:07 PM   #219
kern417
Cheapskate
I'll try to take a look later but just a tip: DON'T TAKE LOGS FOR THAT LONG!
All you need is 1 pull, from 2k-redline. After that, stop the log. If you start a log and realize you can't do a pull, stop the log and delete it later. These long logs with a bunch of partial/no throttle scenarios make it difficult to find a section with useful information.
Glad you got the clutch slip sorted though. I'll be buying a 550i clutch this weekend so I can get a custom tune next year.
Instagram @kern417
joeyb26196.50
      11-30-2019, 02:03 PM   #220
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
Would like to start sharing some logs from JB4 but wanted to see how you guys prefer to see, format etc. Do you prefer to see the graph view instead of the data values? If so, can I just save a screenshot to Imgur and paste the link to my post like this:
Log from 3rd gear, @2500 rpm https://imgur.com/a/f4US1Zj
Also, I can toggle some additional values onto the graph if I'm missing some critical stuff.
FYI, this is JB4 Map 3, MHD E85 BEF running about 40% E85/60% 93 octane.
Any suggestions welcome.
Thx
T.
