BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
proTUNING Freaks
      07-20-2020, 02:38 PM   #1343
designatedposter
Drives: m235i
Originally Posted by N420i View Post
These logs that M140_BCS just posted seem to have pretty f'n impeccable timing...
https://datazap.me/u/m140bcs/log-159...&data=5-23
According to his signature he's only running DP and HPFP on straight 98RON pump gas
Logs were taken with 11ļC ambient temperature and IATs are therefore suitably low at around 22-25ļC though.
how does the STFT parameter work? it varies from +10 to -0.6.. i am more accustomed to BM3 logs where a .85 STFT means that fuel system needs to pull back 15% fuel.
M235i rwd 6mt
      07-20-2020, 03:01 PM   #1344
M140_BCS
M140_BCS's Avatar
83
Drives: 440i Gran Coupe
Originally Posted by eeee36M3 View Post
Thanks for that reply, this is what I was thinking of trying as well. It's interesting you have different SW (MHD), and still see similar results that I have. I guess it's not a BM3 only issue. I was going to try to run higher octane, or try to find some octane boost to dump in. I haven't looked to see the best way to try it yet.
Do any clean logs exist for B58 motor that do not pull timing? Seems like even stock tunes have some amount of pull. Trying to get a feel for how much timing pull is too much, etc... I've heard the E30 maps work well (I don't have E30 near me), but I wonder what the timing looks like. I'll try to find one.
Logs were taken with 11ºC ambient temperature and IATs are therefore suitably low at around 22-25ºC though.
Wish all my logs were that clean!
Plugs are gapped to 0.022" which has also helped.
This is another log on the same day, same 99RON fuel.
Small corrections in the mid range are ok but should disappear as you near the redline.
2016 F36 440i | MPPSK | BBS CH-R | xHP Stage 3 | MHD Stage 2 | BCS 100 Cell DP | B58TU1 HPFP | Bilstein B6 Damptronics | Eibach Pros | AFE Drop In
      07-20-2020, 04:40 PM   #1345
340iNL
Drives: F31 BMW 340xi
Originally Posted by alyabiev View Post
Yeah, this is due to excessive ignition retard when most of combustion happens on the exhaust stroke. DME has a failsafe for that - forced load reduction if EGTs are over a certain limit. The question is: had tuner left that limit intact or raised it to allow all of the performance at any cost.
Hm. Actually I have also on the stock tune *mppsk* some retarded ignition timing (plugs almost new).
Wonder how long BMW's MPPSK cars will last.
https://www.bootmod3.net/log?id=5f14...90c66625c37cf8
Is running ethanol with upgraded fuel pump maybe the solution ??
      07-20-2020, 05:54 PM   #1346
alpinweiss340
Drives: 340i
Originally Posted by alpinweiss340 View Post
Hey guys was wondering if someone can look at this log I did. (Previous one I posted was a third gear pull this is a fourth gear)
I had a problem with the wastegate rattling last week. Tried to tighten it and ended up throwing a check engine/drive train malfunction/limp mode. I tried my best to adjust it back to where I thought it was before. When I started it in the morning no check engine was on, drove like a grandma for three days, until I decided to do a little pull before the log and it seemed semi decent. (I made a appointment with a local shop to check out the wastegate on Wednesday) Not sure if itís all in my head but I think something might be slightly off. (Spark plugs gapped to 0.022)
https://www.bootmod3.net/log?id=5f15...90c66625c37ee6
Thanks guys
*ps. Low end feels fine to me, mid to high seems to fall flat?
Hey guys update. Installed the stock tune. Drive around for a bit. Did a log/pull.
Here it is.
https://www.bootmod3.net/log?id=5f15...729b5e414d5bed
Deleted the stage 2 ACN tune and re-downloaded it/installed it.
It feels a bit better, hereís the reinstalled log/pull
https://www.bootmod3.net/log?id=5f16...90c66591bb9a9d
Apparently it didnít stop recording ha. Any input?
      07-20-2020, 06:02 PM   #1347
OzBMR
OzBMR's Avatar
Australia
535
Drives: BMW M140i
Originally Posted by M140_BCS View Post
Hi OzBMR
Please could you plot the virtual dyno on this log.
https://datazap.me/u/m140bcs/log-159...og=0&data=5-23
440i Gran Coupe RWD - ZF8
Thanks.
Hi, as alyabiev said, no good for Virtual Dyno. Looks like you you went through a wormhole at 4880 RPM.
Your log itself looks like the car is happy. What fuel are you using now?
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s 10.93@127mph
Stock DP, XHP, MHD 95/102 OTS E30 fuel, Hoosier DR2 11.5@121mph about 8.0s 100-200
      07-20-2020, 06:53 PM   #1348
OzBMR
OzBMR's Avatar
Australia
535
Drives: BMW M140i
This one was OK though. Looks more like a Stage 2 E30 result, pretty good.
      07-20-2020, 10:52 PM   #1349
alpinweiss340
Drives: 340i
https://www.bootmod3.net/log?id=5f16...90c66625c382dc
* another update:/
Used Boostane to get ď98 octaneĒ this is after driving it around for 40 min
Iím trying to learn how to read logs, so excuse my questions. Something seems wrong with cylinder no.4?
How bad is my timing still? Would a custom tune fix the issue?
Thanks guys
      07-21-2020, 01:05 AM   #1350
OzBMR
OzBMR's Avatar
Australia
535
Drives: BMW M140i
* another update:/
Used Boostane to get “98 octane” this is after driving it around for 40 min
I’m trying to learn how to read logs, so excuse my questions. Something seems wrong with cylinder no.4?
Thanks guys
Doesn't look good. Double or triple the amount of Boostane and try again?
Have you considered buying a drum E85? I understand pump E85 is scarce in Nor Cal, but you should still be able to get it by the drum for a reasonable price.
The stock tune log you listed earlier looks OK. More than 12 PSI from spool through mid-range and 10 - 11 PSI up top and timing starts to go bad.
Do you have the Stage 1 ACN91 map? If so maybe try that.
      07-21-2020, 01:24 AM   #1351
alpinweiss340
Drives: 340i
Iíll be going back to stage 1 first thing in the morning. Iíll have to do some research on getting e85 as the nearest station is about a hour and a half away from me.
A locally owned gas station does sell VP 5 gallon drums of race gas though, I can definitely see that getting expensive though.
Thanks a lot man I really appreciate your help
      07-21-2020, 03:23 AM   #1352
M140_BCS
M140_BCS's Avatar
83
Still using UK 99RON but I think the fuel quality is better than earlier in the year.
Been running this 93Oct Stage 2 tune for a good few hundred miles.
Only other changes I've made recently is replaced the stock mid pipe and silencer for the BCS mid pipe and M Performance silencer.
Also added AFE dry drop in and scoop.
It sounds so much better now and pulls well.
Without access to ethanol its probably the best I'm going to get.
Last mod now will be the Quaife or Drexler not many used ones around at the minute.
OzBMR535.00
      07-21-2020, 04:09 AM   #1353
theone1973
Drives: M140 -18
Only other changes I've made is replaced the stock mid pipe and silencer for the BCS mid pipe and M Performance silencer.
and you have DP I guess ?
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35)
https://theone1973.imgbb.com/
      07-21-2020, 05:06 AM   #1354
M140_BCS
M140_BCS's Avatar
83
Yes, installed 100 Cell DP a while back.
      07-21-2020, 05:35 AM   #1355
Stu101
Drives: Bmw
What Uk fuel you running. V power is making mine real rough heard back from bm3 and they say the momentum 99 is much better.
      07-21-2020, 06:28 AM   #1356
M140_BCS
M140_BCS's Avatar
83
I always run the momentum 99 but recently the quality seems to be better as I have alot less timing corrections on the MHD 93 Oct map.
I've also tried a 2 full tanks of Shell V Power over the last few months but didn't see any difference in the logs, still poor timing etc.
The fuel quality seems to vary week to week.
      07-21-2020, 02:36 PM   #1357
Devil doc
Drives: M240ix
I just threw in a fresh set of .022 plugs, I also put some E30 in my tank. Iím going to log a run or two later. Hopefully the timing is better.
      07-21-2020, 04:23 PM   #1358
Stu101
Drives: Bmw
Just tried new 94 fuel running the 91 map and timing seems a bit off still in cyclinders 1 and 2. Should I be getting aiming for more that 10.5 degrees of timing. Also seem to have a knock even just as I am lifting off any ideas on this and if itís a problem.
May have to try a small amount of e85.
https://www.bootmod3.net/log?id=5f17...0b432a4784fa9a
      07-21-2020, 04:28 PM   #1359
Stu101
Drives: Bmw
Send log take a few mins apart on a flatter road just seems to be more cyclinder 1
https://www.bootmod3.net/log?id=5f17...729b5ec78a7b60
      07-21-2020, 07:43 PM   #1360
Devil doc
Drives: M240ix
First pass on OTS stage 2 map, E30 and fresh plugs.
https://datazap.me/u/devil-doc/ots-s...36-37-38-39-43
Second pass on OTS stage 2 map, E30 and fresh plugs.
https://datazap.me/u/devil-doc/ots-s...35-36-37-38-39
Seems like the first run was WAY better than the second one
      07-21-2020, 07:59 PM   #1361
alpinweiss340
Drives: 340i
Weíll, went back to stage one and the car seemed off still.
Checked the plugs, threw the stock plugs back on after noticing the ngkís seemed a bit shot. Here a log with factory plugs, on stage 2
https://www.bootmod3.net/log?id=5f17...0b436abcb77602
Opened up a ticket with BM3 and theyíre currently looking at my logs, hope to get the issue fixed. Again, thanks for the help guys, appreciate it.
      07-22-2020, 04:40 AM   #1362
M140_BCS
M140_BCS's Avatar
83
Have you looked at using the E98 from Trackstuff.co.uk - 19L for £64
How much E98 would you need to add to 93Oct/99RON to make a 60 Litre tank of E30?
      07-22-2020, 04:58 AM   #1363
Stu101
Drives: Bmw
Iím going down there after lunch to
Pick some ethonal up called Alex this morning. Iím going to try e15 to start that way a tin will last 3 full ups. E30 would be a Tin per tank so not really feasible.
      07-22-2020, 05:00 AM   #1364
M140_BCS
M140_BCS's Avatar
83
You buying the E85 or E98?
