BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      09-16-2020, 04:46 AM   #1607
N420i
Drives: 2016 420i lightly modded
Originally Posted by Bigjakk View Post
Hey Guys, new to reading logs, and trying to make sure the engine is healthy while tuned as I live on the west coast with horrid gas. Sadly no E in my area either.
Stage 2 91 had my timing all over the place so I tried the Stage 2 91 ACN tune. Now Cyl 1 has 6 degrees of correction? Just wanting some experts to confirm and let me know what you think may cause that.
Stage 2 91:
https://www.bootmod3.net/log?id=5f5e...0b4330d2388e98
Stage 2 91 ACNSorry I know this log is a bit messy as I didn't stop the log in time, pull is in the beginning of the log.)
https://www.bootmod3.net/log?id=5f61...0b43415b7e0108
timing looks a lot better with the ACNI map. Also there's something wrong with the fuel pressure on the first log. It looks like a roller coaster, that will probably have something to do with the crappy timing, as well as the gas.
Perhaps someone else with more knowledge can comment, but isn't 17psi boost a little low for a stage2 map?
      09-23-2020, 10:33 AM   #1608
Porterf30
Drives: 2016 340i
Im not even sure what I'm looking at here. Im still learning. I know there are parameters that I need to turn off for next time. Is there anything jumping out at anyone that I should be concerned about? I'm currently running Bootmod3 stage 1 E30. My charge pipe, down pipe, and intake should be here any day now. Then, ill be switching to stage 2 E30.
Thanks for any info you might be able to share with me about this
https://www.bootmod3.net/log?id=5f6a...90c60f5fef79ef
      09-24-2020, 03:52 AM   #1609
alpinweiss340
Drives: 340i
https://www.bootmod3.net/log?id=5f6c...0b434060e1f344
How does this look?
      09-24-2020, 07:31 AM   #1610
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
Looks very good. Just be aware than Stage 2 E30 will require you to get your mix right. It's a little more sensitive than the Stage 1 E30 tune. But looks like you have it good now and timing is clean.
Originally Posted by alpinweiss340 View Post
Your fuel pressure is dipping really low. It says you're running Stage 2 93, is that correct?
Instagram @kern417
      09-24-2020, 11:38 AM   #1611
alpinweiss340
Drives: 340i
Yea that is correct. I noticed it dropped fairly low and picked back up the last 1/4 of the pull. What could be the cause of this?
** I was looking at my previous logs when I had a major timing issue and I noticed the fuel pressure dropping at the same moment as well. Not as this severe though.
I even put in a ticket with bootmod3 to help with timing, and they said everything looked good?
      09-25-2020, 06:34 AM   #1612
T_H_O_M_A_S
Drives: M135xi
https://datazap.me/u/thomas/mhd-ots-...yasWWORqSkSmlo
MHD stage 1 93oct dsc off xhp stg3
stock car with opf
M140i opf stock , xhp stg3
IMS-340MP137.50
      09-25-2020, 08:22 AM   #1613
IMS-340MP
IMS-340MP's Avatar
Egypt
138
Drives: 2018 340i MPPSK
Decent log
stock car with opf
2018 LCI 340i MPPSK Catless AT RWD - M Sport Shadow Edition
Fuel: 92 RON - Self Tuned - Pure Boost Custom Tune - MHD Stage 1 - MHD Stage 2
      09-25-2020, 08:57 PM   #1614
Jay5k
Jay5k's Avatar
Drives: 2017 BMW 340i
What is a good safe zone for rail pressure? If it dipping down to 2000psi is that okay?
Mods
- VTT GC Turbo
- Dorch Stage 1 HPFP
- VRSF Catless Downpipe
- MST Intake
      09-25-2020, 10:34 PM   #1615
Glemm1970
Glemm1970's Avatar
Russia
126
Drives: BMW M140IX.
The fuel cut will kick in at 1600psi. Up to 2000psi is not good, but the car will keep going.
M140IX. Turbo VTT GС,Flash Wedge Steven.
xHP stage 3. CSF. Dorch 2. 100ron+WMI. 1620kg.
Jay5k6.00
eluded2437.00
      10-07-2020, 12:18 PM   #1616
Nik440
Drives: BMW 440i GC
could someone look at my Log?
I did a pull in 3rd gear and something just is not right. There are lots of timing corrections across all cylinders. And the throttle dropped around 3000 RPM. I think there are several problems.
I run Shell VPower here in Germany, that's around 100 ron. And the current map is -> stage 1 98ron
The car is completely stock, but has a muffler delete!
Link:
https://datazap.me/u/endras44/dd-440...g=0&data=20-22
Regards
Nik
      10-09-2020, 11:35 AM   #1617
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
New logs are up for Rev 19. We've turned things up quite a bit, car feels very fast. I don't think I'll run any more boost than this, I'm probably right at the limit of safe power, or maybe a couple toes over that line...
Logs look OK to me, some smallish timing corrections on C2
https://datazap.me/u/tnilson/pure800...og=0&data=3-21
Oz you mind running another VD graph for these logs?
2016 340i xDrive M-Sport MPPSK
Pure800; Dorch Stg2 hpfp; VRSF DP; AP intake
MHD; Wedge Performance E50 tune; xHP Stage 3
Forgestar wheels & KW coilovers
      10-09-2020, 05:51 PM   #1618
Foriegnmonkey1
Drives: BMW 340i RWD
https://datazap.me/u/foreignmonkey/l...&data=3-16
Can anyone check these logs for me, I'm in California running MHD stage 2 with a 1.5 Gallon e85 mix with the rest 91 because MHD advised me to do so.
Akropovic downpipe and dinan cold air intake is installed as well.
      10-09-2020, 06:16 PM   #1619
M140_BCS
M140_BCS's Avatar
83
Drives: 440i Gran Coupe
You need to ideally log from 2500 - 6800 in 4th gear. WOT, Transmission in manual with traction off.
Use the MHD auto logging function.
2016 F36 440i | MPPSK | BBS CH-R | xHP Stage 3 | MHD Stage 2 | BCS 100 Cell DP | B58TU1 HPFP | Bilstein B6 Damptronics | Eibach Pros | AFE Drop In
      10-09-2020, 06:43 PM   #1620
Foriegnmonkey1
I did.
      10-10-2020, 12:05 AM   #1621
M140_BCS
M140_BCS's Avatar
83
Both logs don't pass 5800 rpm...
This is a Stage 2 91Oct tune with 93Oct/99RON fuel to compare against yours.
You can expect small timing corrections lower down the rev range but as you head towards the redline they should be minimal.
https://datazap.me/u/m140bcs/mhd-sta...46-47-48-49-53
      10-10-2020, 05:45 AM   #1622
RMMAGA
Drives: 120i
Damn you hit 32 psi and 250 load with a fully open throttle, at 3500rpm looks like these rod's are pretty strong! Also there is a concerning drop in your HPFP at that point, which is expected at that load.
But seriously you need to get that looked at, if you do over boost like that (5psi above target) it should close the throttle to control the load, I would not feel safe without any throttle action to rescue me form over boost
Supr3me448.00
      10-11-2020, 09:18 AM   #1623
dawidd3
Drives: F30 340Xi B58
Hi,
Please check the log.
BMW F30 340Xi Stage 2 RON93/98 (Custom mod, DP 4 ")
http://www.autotuner-tool.com/en/log...9f58acda3e73a0
Dragy:
100-200 9.66s
1/4 12.14s
0-100 4.38s
0-100 (1ft) 4.00s
I feel momentary hesitations after gear changes
      10-15-2020, 10:44 AM   #1624
Cobra358
Drives: bmw 335i
BM3 Stage 2+ map, I think it looks pretty good, other than it is not holding boost target at high RPM, any thoughts? https://www.bootmod3.net/log?id=5f88...90c63d0074eca0
      10-15-2020, 01:18 PM   #1625
dawidd3
The log looks very good, the serial turbocharger is not able to keep 21.8psi to the end.
      10-15-2020, 07:37 PM   #1626
Ictus
Russian Federation
35
Drives: BMW G30
Hi guys! Iím not with F30, but with B58 engine.
Trying to make my G30 540ix faster but itís seems to be a long long road to the goal)))
So, my 540 is now with VTT GC turbocharger and Dorch Stage 2 HPFP. Wedge sent me second revision of 98 Ron map, after I flashed xHP Stage 3 to get around torque limiters.
https://datazap.me/u/akhmed/wedge-12...og=0&data=3-19
Canít understand why the rail pressure jumps that way.
Sent logs to Steven. Hope he fix it.
      10-16-2020, 03:05 PM   #1627
xzentrk
Drives: F30 340i M sport 8ZF BM3 Stg 1
340i stg 1 93 oct
Hey gang. Noob to tuning here. Old timer when it comes to BMW. On my 4th one (including e92m3 and f83 m4). Would one of the learned take a look at my log and lmk if anything sticks out. Stg 1 BM3 93 oct; afe CAI; NGK plugs gapped to .022. TIA
https://www.bootmod3.net/log?id=5f80...0b437a26c2f2dd
      10-17-2020, 07:58 AM   #1628
BimmerBoy302
BimmerBoy302's Avatar
Drives: 2013 BMW 335i
Hey guys! Completed my first data logs and wanted to field some feedback. Please let me know if anything sticks out. I'm running Stage 1 93 and these were 4th gear runs from 2500rpm to just about redline. Any help would be greatly appreciated. Thanks.
https://www.bootmod3.net/log?id=5f8a...0b43676892a025
https://www.bootmod3.net/log?id=5f8a...729b488dc3df8d
https://www.bootmod3.net/log?id=5f8a...90c63d910a4e9d
