BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      11-20-2019, 05:56 AM   #177
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
Originally Posted by neonnblack View Post
A little late to this party.. Kern, at least for MHD any bit of boost above target will get you throttle closer, and no, you shouldn't feel it at all. My car does it frequently when reviewing logs.
My most recent log. MHD stage 2, revised 91 octane map. Max requested boost 18.1. Timing advance 9.5. 12.5 AFR
https://datazap.me/u/neonnblack/log-...ta=4-5-6-20-23
Thanks for the data. I updated the original post.
It looks like you have poor timing on cylinder 1. I have some of the same problems. Have you gapped your plugs or swapped plugs?
Instagram @kern417
      11-20-2019, 09:18 AM   #178
neonnblack
Drives: 335i 6MT/e46 330xi
I haven't. I will at some point. MHD seems un concerned with it, as long as larger corrections aren't on adjacent cylinders.
kern4173137.00
      11-20-2019, 09:29 AM   #179
kern417
Cheapskate
Yeah, I'm curious. I think it's interesting because usually it's the cylinder that's farthest away from the throttle body getting timing pull, not the closest. I wonder if air is having difficulty navigating around that sharp turn.
Instagram @kern417
      11-20-2019, 04:46 PM   #180
GT500R
Drives: BMW X3M
And 4?
X3M Alpine White
Mission Tuning <- 10.6@130 (Dragy) (+820 DA)
10.84@127.43 / +1912 DA NH Dragway
Mission Performance E50 Tune Only
kern4173137.00
      11-20-2019, 06:30 PM   #181
neonnblack
Also don't forget im running acn91 fuel and it's shit. could have a bit of a factor.
kern4173137.00
      11-21-2019, 02:13 AM   #182
enemigo13
Drives: F30 340xi
everybody has timing corrections on 1st cylinder. you need to tune it out with a bit rising knock detection threshold, then it is ok.
kern4173137.00
      11-21-2019, 06:04 AM   #183
kern417
Cheapskate
Originally Posted by GT500R View Post
And 4?
Yep 4 too, but it looked like it started to catch up by the time it got to redline. Whereas Cyl 1 couldn't go above 4į-5į
Yeah, definitely could be. Does MHD have an ACN tune?
From what I see it's 50/50. Some people have clean timing across the board. I just want to know why cyl 1 tends to pull timing and I'll feel better about it.
Instagram @kern417
      11-21-2019, 10:43 AM   #184
neonnblack
MHD doesn't have a labeled acn91. there most recent b58 update changed their regular 91 map to work with the fuel better though.
i.e. before the update i had to use octane booster and with the update i no longer need it.
kern4173137.00
      11-23-2019, 10:17 AM   #185
Boomsatty
Boomsatty's Avatar
Drives: 2016 M3
Here's one
Take a look and see what you think. MHD stage 2 on stock DP and intake. 93oct
https://datazap.me/u/boomscatty/stag...25-26-27-28-29
https://datazap.me/u/boomscatty/mhd-...25-26-27-28-29
2016 340I M Sport MHD, VRSF DP
Sold - F80 M3 FBO
Sold - 2016 BMW I8
Sold - 2013 535i M Sport
kern4173137.00
OzBMR535.00
      11-23-2019, 07:57 PM   #186
Boomsatty
Boomsatty's Avatar
Drives: 2016 M3
So one of the reasons I made this thread is being shown. I'm having trouble seeing the difference between Stage 1 and Stage 2. Are there any other stage 2 logs out there? I thought it had a higher boost target. And I don't really see how it's taking advantage of a downpipe or why it's needed.
I just posted 3 Stage 2 MHD logs here.
Sold - F80 M3 FBO
Sold - 2016 BMW I8
      11-23-2019, 08:21 PM   #187
kern417
Cheapskate
Originally Posted by Boomsatty View Post
thank for posting. it looks like yours is only targetting 16.5-17psi compared to others that target 18+. But everything looks good compared to target values. I wonder why yours has a lower boost target? I don't think it would have anything to do with the downpipe. Did you run it for a while and let everything adapt?
Instagram @kern417
      11-23-2019, 08:57 PM   #188
kern417
Cheapskate
So I had to get my Bootmod3 account reset, and it ended up erasing all of my old logs. Even the links in here don't work anymore. That + enjoying the datazap interface has motivated me to start backing up my logs on there. For any other BM3 users, I highly recommend it. Export the CSV, upload to datazap, and it does everything for you.
This are my stock log. Just reposting for future reference.
https://datazap.me/u/kern4179/stock-191109?log=0&data=3
Also, if you guys think it would be helpful to copy a link of a clean log under each tune, let me know.
Instagram @kern417
      11-23-2019, 09:41 PM   #189
Boomsatty
Boomsatty's Avatar
Drives: 2016 M3
Iíve had it in the car for a couple days now but havenít done many WOT pulls yet. How many pulls or how much time does it usually take to get in the zone?
      11-23-2019, 10:47 PM   #190
kern417
Cheapskate
Just 2-3
Instagram @kern417
      11-23-2019, 11:40 PM   #191
OzBMR
OzBMR's Avatar
Australia
535
Drives: BMW M140i
Low ambient temps close to freezing likely explain the lower boost levels. Engine management is Load/Torque based. Load target looks about right for a 93 map at 180 peak tapering to 160 up top. Cold air is more dense achieving cylinder fill target at a lower boost level.
Agree, everything looks good in the logs.
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s 10.93@127mph
Stock DP, XHP, MHD 95/102 OTS E30 fuel, Hoosier DR2 11.5@121mph about 8.0s 100-200
kern4173137.00
      11-23-2019, 11:43 PM   #192
OzBMR
OzBMR's Avatar
Australia
535
Drives: BMW M140i
That sucks.
4th gear runs would be good, Load targets are typically lower in the first three gears.
      11-23-2019, 11:55 PM   #193
OzBMR
OzBMR's Avatar
Australia
535
Drives: BMW M140i
Looks good. It looks the same as the MHD Stage 2 93 octane Load target profile just lower timing due to reduced octane.
      11-24-2019, 09:18 AM   #194
Boomsatty
Boomsatty's Avatar
Drives: 2016 M3
Thanks for that! Timing and everything look good? Think I should replace/re-gap plugs?
      11-24-2019, 10:25 AM   #195
kern417
Cheapskate
It could help. Your cylinder 1 is lagging behind but a lot of people tend to have that issue. Regapping mine helped, but didn't eliminate the issue.
Instagram @kern417
      11-24-2019, 03:03 PM   #196
Boomsatty
Boomsatty's Avatar
Drives: 2016 M3
Cool. What did you gap to? 22?
      11-25-2019, 06:24 AM   #197
kern417
Cheapskate
Yep gapped the stock plugs to 0.022-0.024. I was good until I updated to BM3's v2.0 tune, then i started getting some knock detected. Regapping got rid of the knock, but I still have lower timing on cylinder 1. It tends to catch up by redline, but in the mid-rpm there's some pull.
Instagram @kern417
      11-25-2019, 07:13 AM   #198
bacon_45
Drives: 2018 340i BM3 FBO
http://www.bootmod3.net/log?id=5ddbc833c090c670d017873b
Hey guys, here is my e30 stage 2 log I did! its a long one for best results, thank you!
kern4173137.00
