BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
      02-04-2021, 10:55 AM   #1079
wifes first bimmer
Drives: 330i, i3, '82 R65LS
Originally Posted by GreenF30N26 View Post
Other than part vendors(non-tuning vendors) and folklore who is recommending adding a charge pipe to the N20/N26 or B46/B48? I never heard of anyone blowing a charge pipe on this platform with a stock turbo.
Save your money.
THANK YOU!! My thoughts exactly.
I have personally seen rubber charge pipes expand on engine dyno - that is not a problem with plastic charge pipes. If you suspect the pipes are cracked, or if the seals are leaking; then you could upgrade the charge pipes, but there is no performance to be gained from it.
MODS: Turbo Transformer boost controller, ECO-SPORT auto selector (home brew), Electronic boost gauge vent mounted, RPM based LED Carbon paddles
WISHLIST: BM3, HPFP, Turbo + IC + water ... new car eventually
      02-04-2021, 06:55 PM   #1080
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
if you have extra budget, upgrading charge pipe is worth
but if your on tight budget, i suggest spending that $200-300 on something that provide performance gain, like XHP transmission flash.
Instagram: nightfall.f30
      02-04-2021, 10:06 PM   #1081
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
Any plans for B48E?
      02-08-2021, 09:50 PM   #1082
FlyingWombat24
Australia
Drives: 2020 BMW 530i M Sport
Originally Posted by Kinglagos View Post
Are there OTS maps available for the 20i? I was about to hit the buy button before I noticed only 28i mentioned. I am not inclined to go past 28i levels of performance with my 20i...
did you find out dude? I'm also thinking of buying a 320i m sport
Bimmer Nation
      02-09-2021, 01:11 AM   #1083
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
off course BM3 is available for 320i N20 or B48
      03-16-2021, 11:38 AM   #1084
BMWAutoXer
No Cones
Drives: F31 330 xDrive
I bought their OTS maps, ENET cable, and tuner license for my 2017 F3x, I have BMW's July 2020 DME firmware update. This version of the DME is locked and BM3 flashes fail. I worked with PTF / BM3 support, they said I can't do anything until the DME is bench unlocked and they "won't accept mail in modules to bench unlock due to covid."
Unless you have a local tuner with proven capability for bench unlocking the most recent DME firmware I recommend saving your money and waiting for PTF/BM3 to release a flash unlock.
      03-16-2021, 06:51 PM   #1085
SFV818
Drives: 2016 328i - BM3 Stage 2 FBO
I have a 2016 F30 N26 that I purchased CPO in May 2020.... will I be able to flash? I already purchased BM3 but haven't tried to flash it yet...
      03-16-2021, 09:09 PM   #1086
BMWAutoXer
No Cones
Depends on your firmware, ask PTF - they're responsive and knew right away mine wasn't flashable.
      03-17-2021, 11:34 AM   #1087
SFV818
Ya they got back to me super quick and said shouldn't be a problem. I'm going FBO -next week hopefully- and then will tune as soon as I pull back in the driveway lol
      04-14-2021, 02:02 PM   #1088
hagan32
Drives: BMW 328
I’ve got a BM3 (bootmod3) License for sell.
Bootmod3 N20 N26 - BMW F10 F20 F21 F22 F30 F32 125i 220i 228i 320i 328i 420i 428i 520i 528i X3 X4 TUNE
Comes with the bootmod3 OTS maps bundle.
License originally $595
OTS map bundle $50
Total - $645
SELLING FOR $450
      04-14-2021, 02:14 PM   #1089
chowser51
chowser51's Avatar
There’s a classified section and OTS map bundles do not transfer.
      04-14-2021, 08:05 PM   #1090
elborczi
Poland
35
Drives: F30 2018 320i
OTS map bundle $50
Total - $645
SELLING FOR $450
how does it work? can you transfer bm3 license to another person?
Thanks
      04-14-2021, 09:44 PM   #1091
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
i knew that way before i buy bm3
maybe you quoted a wrong person?
      04-19-2021, 10:10 AM   #1092
r0b3r
Drives: Bmw F
Hello!
I am a user with a Mini cooper s f56 from 2014-06 with B48 engine, currently it has 45000km the car has automatic transmission
It currently has Wagner intercoolers, NGK IRIDIO spark plugs, Coils replaced by the last original reference available, Remus V2 exhaust pipe, k & n panel filter, Ravenol RSP 5W30 oil, Ravenol OTC g12 + coolant, Redline ATF D6 automatic gearbox oil and I think I do not forget anything, at the moment the electronics is standard.
I am somewhat concerned about the pistons since I read that there are many B48 breaks both from stock and with reassignments, some say it is due to LSPI, others that due to injection, etc ...
Is there a way to mitigate or improve these problems without having to change the pistons (I would hate to disassemble my engine completely, if this engine could be changed from the bottom without removing the engine from the car, I would do it immediately, but since it is not like that. .) They say that using an oil with lspi formula mitigates these problems as well, such as amsoil 5w30 or similar, what can you tell me about all that? First of all thanks for reading!
The question is, in the 2014-06 B48 engines like mine, how to mitigate the breakage of the pistons in some way, without having to replace them, the engine now has 45000km and electronics as standard, but soon I will reassign to 280cv // 400nm and I want the motor to be safe and not have breakage problems as I have seen previously in others. Some say that the problem is mitigated with LSPI oil, others that the problem is injection, I also want to know what is the origin of the piston breaks.
will it be possible to install bootmod3?
A hug!
      04-19-2021, 11:58 AM   #1093
frchdragon
frchdragon's Avatar
338
Drives: 2016 BMW M4
The used license I purchased had the OTS map bundled transferred.
Or maybe it doesn't transfer cross platform?
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD)
'85 635csi M30 turbo race car (SOLD)
      04-19-2021, 08:43 PM   #1094
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
Originally Posted by r0b3r View Post
Hello!
A hug!
many factors can lead up to engine failure, we cannot say one for sure.
Bad fuel quality, bad oil quality, bad plugs, bad injectors, overboost, and the list can go on and on.
what we can do is to do preventive maintenance, such as using good fuel quality, good oil spec and quality. I heard some of oil brand had obtain SN plus certification, which increase protection to LSPI.
i'm myself, using B48 engine for 1.5 years with Stage 2 BM3, which deliver over 400nm and 300hp. My car is working flawlessly until now, which already run 10k miles with those power figures.
      04-20-2021, 05:09 AM   #1095
r0b3r
Drives: Bmw F
Thank you very much for your answer, it seems that the mini B48A20A is somewhat different and does not share reference of the pistons among other things with BMW, so it seems that the rear-wheel drive BMW B48 is better or more reliable than the front-wheel drive Mini , also mine was one of the first B48A20A from 2014-06, then in 03-2015 they changed the piston reference (I don't know the change very well or the reason why bmw updated this in their ETK)
I normally use all the best for my car, good gasoline, good oil, good maintenance, good care, etc ... But I am somewhat scared with as much piston breakage as I see daily.
      04-24-2021, 12:27 AM   #1096
Dazznz
Drives: 2013 428i f32
Hi guys
New to the BMW and bm3 world.
This was my 1st flash attempt.
I got my ots map and went to flash, got the error
"flash successful but coding failed to apply"
I tied to revert to the original tune but having the same results
I now have a dash full of errors and malfunctions, and the car won't start.
I have launched a ticked with PTF and super confident they can sort me out but unfortunately I'm in Australia and they are not available until 11pm my time Monday at the earliest.
I'm wondering if anyone has had the same issue and how it was resolved?
Car is a 2013 f32 428i with the n20
Lights and fan were off,
Seatbelt plugged in,
25amp charger connected to a brand new battery (to be safe and as per instructions)
I apologize in advance if I've posted this in the incorrect place, very new at forums as well lol
Thanks in advance for any advice
      04-26-2021, 05:54 PM   #1097
chowser51
chowser51's Avatar
weird? ots maps were an additional $50 after license purchase.
you can't sell it anymore if you bought it used.
it's allowed to be transferred once.
      04-26-2021, 07:12 PM   #1098
frchdragon
frchdragon's Avatar
338
Drives: 2016 BMW M4
I meant I bought a used license and it came with the OTS maps.
'16 M4 bone stock
      04-26-2021, 07:23 PM   #1099
chowser51
chowser51's Avatar
Thanks
if you're the original owner (first time license) then you can flash your car back to stock and lock it, then contact ptf to do a transfer.
they let you sell it once.
or you can transfer it to your next car.
      08-13-2021, 02:56 PM   #1100
gameson
Drives: 2015 BMW 320i N20
what would be a good combo of downpipe and FMIC to get to stage 2?
Thanks.
bm3, bootmod3
