12-15-2016, 10:43 PM | #1 |
Rep 1,035
Adding extra Bavsound Tweeters to Rear Doors on F30 HiFi system
I know this mod is a little controversial, but to each his own - so no flames please
After installing the BSW Stage-1 upgrades for my F30 Hi-Fi base system (along with an upgraded JL XD800/8 amp - 100w to each of the 7-channels - to replace OEM HiFi amp), i also added dual JL w3v3 500w subwoofers for the trunk (along with a JL JX500/1D 500w mono-amp). The 9 speakers that now cover the mid-range/bass tones and the low thumping sub-bass are spectacular, but frankly, i feel they completely overwhelm the two tweeters in the HiFi system (HiFi system includes tweeters only on the front doors - the center channel and rear speakers are mid-ranges only) So to bring a little more balance to the overall system, i wanted to add a couple of extra BSW S-1 tweeters to the mid-range speakers in the rear doors (similar to how the HK system is laid out with tweeters accompanying every mid-range in the system). Thanks to MSportTune2 who provided me the initial info and pics over a year ago that gave me the confidence to go through with the upgrade ... just finally got around to doing the work Here's how the finished additional tweeter looks on one of the rear doors: An obvious pre-requisite for doing this work is that you should have already upgraded your base HiFi speakers with the Bavsound Stage-1 speakers. I also am of the opinion that unless you've also upgraded your OEM amp, this upgrade is likely not going to be all that effective. Like I mentioned earlier, I only did this addition because with an upgraded amp (800watt XD800/8, which sends 100w to each channel) to replace the OEM amp for the S-1's, and a 500w trunk sub/mono-amp, this system really does overwhelm the tweeters in the system. So with all that out of the way, this work is a really easy upgrade that can be done in a couple of hours, and the work will look amazingly OEM clean when its done. While there is one hole that will need to be drilled in each rear door panel to place the extra tweeter (on each side), there are pre-marked outlines/templates in the door panels that allows for a perfect hole to be positioned / drilled. Other than that, there is no extra wiring, cutting, splicing on the OEM electrical system that will need to be done. Everything will look perfectly OEM when its done, and to BMW's exact positioning specifications for the tweeter. There is no guess work (or extra skill) involved in doing this DIY. And as a bonus, there is also no coding involved with this upgrade. Here are the parts you need:
UPDATE: The whole cabin is a lot more "lively" and balanced now with the extra tweeters. There is great detail, clarity, and sparkling precision in the overall tonality. But now, there just seems like there's more of it. With 75w-100w of clean power going to each BSW S-1 channel, adding these extra tweeters makes a huge difference and brings a fuller, more balanced, and a more complete sound across the entire cabin of the car. The biggest difference to the system, however, has been adding the trunk subs last month. I was completely oblivious to what i was missing until i added them recently (and did A/B comparisons with them on and with them off). It was like discovering jelly for the first time, after eating peanut-butter only sandwiches your whole life. I feel like the whole "bottom half" of my music has been missing this entire time (I guess you don't know what you don't know ). After the addition of the trunk subs, the sound now is just damn rich, full-bodied, and silky smooth ... befitting of how a BMW sound system should be. The need for the extra tweeters IMO was not even necessary until i added the subwoofers, and discovered how over-powering they were. Last edited by squidlyboy; 12-29-2016 at 05:44 PM.. |
12-16-2016, 08:32 AM | #3 | ||
Rep 16,069
An alternative for those with the stock hi-fi system is to add a pair of these. They include a high pass capacitor, so tying them to the stock system isn't difficult: http://www.parts-express.com/pioneer...-pair--267-288 Update: I installed a pair of these in my rear doors, they work perfectly. I wrapped the bezel in silver vinyl to match the rest of the trim. https://www.amazon.com/JBL-GTO19T-Pr...sr=1-3-catcorr Last edited by Billfitz; 02-15-2019 at 07:52 AM.. |
12-16-2016, 12:58 PM | #4 | ||
Rep 1,035
Practically speaking though, that would be difficult to do without some creative and major re-work relocating, mounting, and securing the tweeter mounting bracket - using completely new mechanisms. The OEM door panel has 3 fixed posts that the bracket just slips over, not to mention a pre-marked speaker template for drilling reference. These posts are built right into the door panel, and permanently fixed, so they don't move and can't be re-located. The tweeter was designed to go there. Thats why this install was so easy - its all there for you to just drop in... literally. FWIW, I actually don't attenuate the back tweeters personally, despite what BSW told me. I don't think its too much or too close Quote:
On a slightly different note, i have a brand new JBL MS-8 sitting in a box because about a year ago, it took me over 2 weekends (about 6 total hours) trying to get the calibration sweeps to make the audio sound as good as just my plain JL XD800 does. I could get it 99% of the way there, but I soon realized i was spending more time tweaking than i was enjoying music that sounded perfect as-is with just the JL amp alone. To me, its all about the ROI. Last edited by squidlyboy; 12-16-2016 at 03:04 PM.. |
12-16-2016, 03:07 PM | #5 |
Rep 169
Excellent write-up!
It looks like the standard JL sub gain knob you installed (next to the shifter) was replaced by a custom silver knob? Can you give a little insight on it - where did you find it, was it a direct fit replacement? Really nice finishing touch! Thanks! |
12-16-2016, 03:14 PM | #6 |
Rep 16,069
That I was unaware of, as I haven't looked inside my doors yet. In that case a tweeter that can be aimed back towards the rear passengers would accomplish the same thing.
12-16-2016, 04:53 PM | #7 | |
Rep 1,035
I was perfectly happy with the default plain black knob from the rbc-1 remote volume controller, until i saw this picture in some subwoofer article on the net. I was absolutely stunned how sharp, stylish, OEM, and high-class it looked ... very befitting of the BMW brand After getting my audio to sound exactly the way i want it to now, i thought, i have to find something as cool as that. Plus, i find that i use that knob for just about every song i listen to to get the right mix of low bass, so i'm always tweaking it. My hand is almost permanently resting on it when i'm driving. That plus the fact that when that pot dial turns, it feels so solid, and it feels so "quality", i figured i have find something that looks as good and is befitting of how good everything feels. So i went searching high and low (went a little crazy tbh), and got a bunch of really sick, blinged-out knobs. Here's a bunch of them from asia that are currently on their way to me, so i don't have them in hand yet (the one you saw was the first one that arrived, so i included that pic). Btw, the black one on the bottom right is the same one as installed in the BMW above. I have 10 pcs of each coming to me, so if you are interested for $1, i can send you one. Or maybe for $5, i can send you one of each, PM me if you are interested. Here are a few other onesies, twosies i purchased domestically. Getting them here is a lot more expensive. They ranged anywhere from $2 - $10 each. The one on the bottom right is the one i just received that you see installed in the picture. I got most of these from Small Bear Electronics in NY. I got another one from DIY Guitar Pedals. Because of where i installed the controller unit in the shift trim area, i can only use 15mm diameter knobs (max). The thing to look for is to make sure they are compatible with 6mm potentiometer shafts (internally) if you are using the JL RBC-1 remote control knob. They will usually say this in the description what they are compatible with. If you really like the knob, and its a little off (like the one in my pic), i just used a dremel tool with a thin sanding bit, and clear it out a little to make it fit. I'm planning on keeping a small bag of all of them in my glove box and change it out like how people change out jewelry or shoes (daily? weekly?). Life is short. Keep it real... |
12-16-2016, 08:25 PM | #8 |
Rep 169
Wow! Thank-you for the great update, especially the details on the sizes and the links! I am going to save this post so when I'm ready for my audio install, I may take you up on your offer. I really like the one you have installed now in your picture, it looks so high quality compared to the basic JL version. I also like the placement; in my past (aftermarket) audio set-ups, I was constantly adjusting the sub bass gain on every song. Thanks again!
01-07-2017, 01:06 AM | #9 | |
Rep 32
how do you get the Bavsound tweeters? because I can't only buy tweeters from Basvound's website.... What can I do? |
01-07-2017, 01:08 AM | #10 |
Rep 1,035
You can't order it off their website. You have to contact them directly. I spoke with Jeremy W. at Bavsound. He sold me the pair for $120.
01-10-2017, 08:35 PM | #12 |
Rep 32
01-11-2017, 11:14 AM | #13 | |
Rep 1,035
Jeremy Whittle / BAVSOUND jeremyw@bavsound.com 619.489.5770 Ext 804 Try talking to him directly, and you can say that he sold me a pair. He was getting ready to sell me a center channel tweeter also for $99 (they are a little bit more as they don't purchase as much quantity for these tweeters from their supplier) |
01-12-2017, 10:00 AM | #14 | |
Rep 32
01-24-2017, 04:40 AM | #15 |
Rep 346
Hi Ben, great write up and I am glad you have gotten this out of the way. You took it to another level and your DIY
looks very professional. I took my system a step further by having all four doors and trunk soundproof with STP and then added a Hertz active sub DBA 200.3 as I wanted to maximize the trunk space. I also had the system professionally tuned. I am very happy with the outcome and will retire from adding anything else for now. Did you add the rear parcel shelf speakers too? Thanks for sharing. |
squidlyboy568.00 |
01-25-2017, 12:30 PM | #16 | |
Rep 1,035
I went ahead with this mod for three reasons:
With that said, i'm toying with adding the extra tweeter to the center channel (which is even more controversial than adding the tweeters to the rear doors). But the cost ($99) and effort (pull speaker cover and snap in tweeter) are negligible. My only concern is that i'm thinking of eventually putting in BSW Ghosts in the under-seats, and if i do that, i want to beef up the power to them (200W) by bridging two channels from the XD800 to each of them. Since i don't have enough spare amp channels, i would have to delete the center channel in order to do it. So getting a tweeter for the center would be a waste if i went that route. After that, I think i'm done as well with my audio. I have a Bimmertech Rear-Cam system arriving soon, so that will (hopefully) be the last thing i do to the car. Its time to just enjoy the car! |
01-25-2017, 12:46 PM | #17 |
Rep 558
squidlyboy , where did you put the JL XD800 amp? did you run the pair of SUBs in 2 ohms? ... and did you use any processor?
squidlyboy568.00 |
01-25-2017, 04:06 PM | #18 | ||
Rep 346
Yup, I have been enjoying the ride with much better music but I made a mistake of upgrading my wife's new car with Focal Be Utopia 3 way system and it blows what i have out of the door. Anyway, I am done and won't be tempted further to mod my ride. |
01-26-2017, 12:02 AM | #19 | ||
Rep 1,035
My main xd800 amp is located under the cubby hole cover on the left side where the OEM amp/ASD amp are/were located. I did have an MS-8 Logic7 processor originally, but i spent so much time putzing around and endlessly tweaking it to get it just right, i was getting frustrated and not enjoying the music - we're talking weeks. In the end, i couldn't get any better sound with the MS-8, than with just the XD800 alone (which sounded pretty damn near perfect to me), so i ended up selling it recently. The dual JL W3V3's come configured at 2 ohms by JL in their enclosure. Quote:
01-26-2017, 01:17 AM | #20 | |||
Rep 346
Over here cars are just too expensive so I rather not discuss a sore point. |
02-14-2019, 10:32 PM | #21 |
Rep 9
F30 Rear shelf speaker cut out of factory absent
Has anyone cut the rear shelf speaker holes, since my rear shelf is the HiFi system with no speaker cut-outs, to add midrange and tweeter pairs, just like the HK audio system comes with?
I am in the process of doing this, using the BimmerTech Alpha One Speakers with their Audiotec Fisher Match PP-86DSP amp and curious if anyone has experience in this. Update: rear shelf speaker cutout completed. thnx. -dd Last edited by dembinsk; 02-16-2019 at 10:12 AM.. Reason: Update on project |
07-30-2019, 10:10 AM | #22 |
Rep 45
Very nice! I bought my F30 with Bavsound Stage 1 already installed. And I am planning on further upgrades with a 12w6 and 600/1v3 slash series amp. I’m also going the xd800/8 route and I have a Rockford DSR1 DSP. But I’ve been afraid about having enough highs and I’ve been tinkering with the idea of installing a set of Hertz Mille tweets I have from my last system. This sounds much better provided Bavsound will sell me the tweeters. Thanks so much for the write up! One question: the crossovers for the kids are already installed next to the rear mids?
