11-03-2018, 04:28 PM | #1 |
Rep 32
PP82DSP won't connect to software
I had the PP82 installed this week to my F30 along with the BSW S1 and Ghost subs kit. I had my installer connect a 10ft USB cable to it so I could access it easily with my laptop.
With the stereo on (and volume down), I connect the USB cable from the amp to my laptop and then start the DSP - PC Tool app. The amp is not being recognized as connected. I downloaded v4.31 of the app from BimmerTech's site. Should I try an older version of the app? I didn't think it would matter as the manual says that if the software detects an older firmware version, it would automatically update to the newer version. Any suggestions? |
11-03-2018, 07:26 PM | #2 |
Rep 1,906
Sorry I can't help...I just finished installing the same model amp in my X3 (F25). I haven't yet got to tuning business.
But, maybe you can help me out? I need a users manual for the amp...can you post the PDF or link to where it can be found online? Good luck, Thanks/Bill Last edited by Wgosma; 11-03-2018 at 09:12 PM.. |
11-03-2018, 07:58 PM | #3 | |
Rep 2,180
11-03-2018, 08:00 PM | #4 | |
Rep 2,180
Try reinstalling the USB driver or use another USB cable.
11-03-2018, 09:07 PM | #5 | |
Rep 10,473
11-04-2018, 08:03 AM | #6 |
Rep 32
11-04-2018, 08:54 AM | #7 |
Rep 10,473
11-04-2018, 08:59 AM | #9 | |
Rep 10,473
Obviously SHOULD is not working. http://bfy.tw/KgqJ |
flysmith8.00 |
11-04-2018, 11:43 AM | #10 | |
Rep 2,180
Try any other USB cable. I also used to have quite a few bad USB cables -especially the cheapo eBay ones. |
11-04-2018, 01:23 PM | #11 | |
Rep 32
The car doesn't need to be running, right? Just the accessory power for the stereo to be on? |
11-04-2018, 03:14 PM | #12 |
Rep 32
UPDATE - I downloaded version 3.xx of the DSP software, this version of the software included a separate USB Driver (you called it, IK6SPEED). I must have missed it in the documentation and assumed all drivers were part of the main DSP Tool install .exe file. The amp connected without a problem to the software. I presume it will now also connect to v4.3x as well, but didn't have time to test it as it's sitting parked outside of my local shop for major service.
I made the profile update which made an immediate change to the overall tone - SO much better. I still have to do some tweaking as the dash-mounted center just sounds a bit off (I have to notch a couple frequencies downward in the tool), but it's almost there. Thanks, folks, for your replies and help. |
