02-26-2018, 09:42 PM | #23 |
Rep 61
Thanks for the help bro!!
Does the 235/35/20 and 275/30/20Â*have the same rolling diameter? Im still learning all these tire spec stuff for Xdrive lol. Now, all I need to do is look for a good price on some 666MS!! |
02-26-2018, 09:51 PM | #24 |
Rep 1,500
Yeah I’m not too sure either since I have RWD, you can also go for 265/30/20 on the rear. Check the f80 forums for them but you are looking to pay between 2500-3000 for them, depending if you want the silver or the black ones.
02-26-2018, 09:52 PM | #25 | |
Rep 3,030
If the 666's were more affordable I would have totally jumped on them.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
02-27-2018, 12:03 AM | #27 | |
Rep 274
I won't even get started on offsets and camber angles. : Seriously keep searching and reading the forum and you will find the info you need. I was considering the same wheels for an xdrive car and the info is readily available, and too much to go into here. If you are committed and want to do it they will work, keep learning!
2017 F15 40i ePerformance -M Sport
02-27-2018, 01:49 PM | #28 |
Rep 1,876
Holy shit, that's direct bolt on with M sport suspension? That's literally a perfect fitment!
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport |
02-27-2018, 05:51 PM | #29 |
Rep 1,500
02-27-2018, 06:35 PM | #30 |
Rep 1,876
Ahh because they're 20s. That makes sense since it filled in the wheel gap without any suspension work.
02-27-2018, 06:42 PM | #31 |
Rep 1,934
So do these 666M wheels only come in a 20" wheel when OEM? I can't find any at 19", they all seem to be Replicas.
02-27-2018, 08:52 PM | #32 |
Rep 1,500
