12-01-2021, 05:48 PM | #1 |
Rep 59
Odd trembling problem around 2k RPM
Hello guys.
My car has had an issue for the last 50k or so miles and I've never been able to figure it out. Car is at 150k miles now. When accelerating (kind of hard but not full throttle) the car will shake a little at 2k-2.5k rpm then it'll go away and accelerate hard. Occasionally I'll get a "drive train malfunction" but by the time I pull over to try to hook ista up it goes away... No check engine lights. Car is stage 3 tuned and EGR/DEF/SCRA deleted with a buzzkin exhaust. I am running wide tires in the rear but I've had the same issue before swapping tires. I've ran injector test and everything checked out fine. Also an actuator turbo test and it also tested out fine. Fuel mileage is still around 48mpg. Does anyone have any ideas I can check? One other issue I'm having is my keyfob's arent being detected unless I put the key in the cupholder. Both keys have brand new batteries but when I try to turn the car on it'll say remote not detected unless I have the key in the backseat or the front cupholder. Thanks guys. |
12-02-2021, 06:43 AM | #2 |
Rep 1,802
Excessive torque at that rpm will shudder. The tune should be adjusted to keep shudder minimal.
This could be torsional forces on the driveshaft and center support bearing. Alternatively, considering the drivetrain message, you may have other issues that may be hidden. There are ways in diag to read deeper and figure out the conditions it happened under. Unfortunately the tune can easily hide some of these. It all depends how the tune is made. That's a huge can of worms. Regarding the remote battery issues, the first step is to install a very high quality brand name or original BMW battery. This is very well known that the general batteries don't come with enough voltage. They should have over 3.3V on a multimeter when new. Many won't have that. |
12-02-2021, 09:13 AM | #3 | |
Rep 59
I'll just run by the bmw shop then and buy a battery to make sure it's not that. I've tried multiple energizer batteries now. It's weird, when it's cold outside it doesn't do it, only when it's warm Appreciate the help |
12-02-2021, 10:28 AM | #4 |
Rep 1,802
I know of at least 6x 328d that have had higher torque numbers do the tremble. It's all the same. No matter of rwd vs xdrive, stock transmission tune or xhp. No matter whose tune either. No difference. Interestingly, they are earlier ones, with older rubber... leading me to think it's a driveshaft center support cause. Most apparent in 5th gear at 2500rpm and then it stops by 2700ish? Shudder/tremble is kind of mid chassis? Keep the torque lower.
If you have a multimeter, check the battery voltage. It needs at least 3.3V. If it's not that, I would check to see that your in car antennas are still ok. Both key fobs do the same?
12-02-2021, 09:13 PM | #5 | |
Rep 59
Also, will grab a multimeter and check tomorrow. ISTA did show one error one time but it hasnt come back saying to check the "aerial antenna" to which I ran their diagnostic test which was to hold the key to the column and click okay and it said it passed. I'm definitely no ISTA expert though. Its super weird that it works just fine now when its cold though. Whats really odd is my IBS broke so I had to replace it and then this started happening. Not sure if its related or not. I also replaced the cars 12v battery at the same time and coded the battery after. Again, thanks for the help man. I actually told tunemyeuro what you guys said and thats why they agreed to take a look at the tune file. |
12-03-2021, 11:05 AM | #6 |
Rep 8,495
Manual or auto ? I don't know whether the 28d is available in both guises.
12-03-2021, 12:11 PM | #7 |
Rep 1,802
They were all automatic
12-03-2021, 07:00 PM | #9 |
Rep 59
12-07-2021, 08:56 PM | #10 | |
Rep 59
12-08-2021, 07:56 AM | #11 |
Rep 1,802
If you hold the probes and it drops less than 3.3V on a new battery... then the battery is bad.
I would check the multimeter on a known good AA alkaline (~1.5V), but according to the info provided, that battery is bad. It should hold steadily over 3V.
12-13-2021, 06:14 PM | #12 |
Rep 59
Bought a battery directly from BMW dealer, no change at all. Same issue with it. Also, when I shut my door with the key in my pocket and the car on it says remote not detected for about 5-10 seconds then goes away.. any idea what I can check at this point? It's super annoying.
12-16-2021, 09:43 PM | #13 |
Rep 59
Update: I'm on a 4k mile road trip and the car finally popped a code whilst it was trembling! Good news? At least the car finally acknowledged something was wrong... My powergate shows 244D00 which from what I could find is an over charged? Any idea what I could check when I get home?
12-17-2021, 07:43 AM | #14 |
Rep 1,802
0x244D00 Boost pressure control, control deviation: charging pressure too high/negative deviation
This code unfortunately comes from the engine ECU, and is not related to the transmission at all. You should be reading transmission codes from the transmission module. For this you'd need a better scan tool. Overboost codes in tuned cars are usually due to problems with the tune, rarely a boost pressure sensor that reads too high (but there would be additional codes!), or even a MAF sensor that may read too low (but there would be more codes with this as well).
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 12-17-2021 at 07:55 AM.. |
12-17-2021, 08:54 AM | #15 | |
Rep 59
12-17-2021, 09:38 AM | #16 |
Rep 1,802
Yes, ISTA shows transmission codes, and it is the "gold standard" for it.
12-19-2021, 12:10 PM | #17 |
Rep 59
Got it! I installed an afe cold air intake and guess what? When BMW did the EGR recall like 100k miles ago they never hooked the damn crank case vent up correctly so there was air leaking in unregulated. What a damn joke man, they forgot the gasket for the egr too so they messed up two things. I replaced the plastic crap vent hose with a rubber one and it's SOOO smoothe now. The car feels brand new. I'm pissed I didn't figure this out 100k miles ago. I appreciate the help again man, thanks!
12-19-2021, 03:06 PM | #18 |
Rep 88
Same car, same mods, same issue. Well, it's happened twice anyway.
I was thinking it was probably my turbo starting to show its age, but I could see a CSB issue causing the car to trip the alert. Hard to tell how big of an issue this is. Almost seems like you could just ignore it to be honest. I got my 328 cheap and I barely drive it so my inclination is to just let it be, and if it gets significantly worse, then diagnosis will be a lot simpler. |
12-19-2021, 04:04 PM | #19 | |
Rep 59
I just figured my issue out today, check the above post, that might be your issue too! My crank case vent wasn't hooked up. Tried to hook it up and the brittle plastic BMW used just disintegrated. Ended up replacing with a hose and all is FINALLY well! edit: unless you're referring to the remote issue which I still haven't figured out just yet |
12-19-2021, 07:13 PM | #21 |
Rep 59
Unmeasured air coming in right before the turbo . I don't know but I'm finishing the drive home and have gone 400 miles today and ever since fixing that leak I've had zero hesitation. There was also oil all over the sensor at the end of the tube
12-20-2021, 07:55 AM | #22 |
Rep 1,802
Hesitation makes sense yes, but from your description of the problem, the trembling, then no, that wouldn't be related.
You may have inadvertently found another problem while looking for it. I really hope you didn't ingest too much sand and particles, or else your turbo compressor blades will look quite beat up.
