01-01-2022, 08:20 PM | #1 |
Rep 3
Bmw N55 F30 oil consuptiom
Hi there, wishing a happy new year for everyone, as tittle says i own an bmw f30 335, and im having troubles with bad oil consuptiom, i did replace the valve cover thinking that the problemas the pcv , the car got checked for oil leaks, everything seems to be ok on that way, so after replacing the valve cover the car still with the oil consuptiom , it requires 1 quart every 200 miles, i just want to know whats wrong, the car have mid pipe,charge pipe,down pipe, intercoolerbms, and its on stage 1 MHD tuning.
i just want to know if someone here have the same experience, any solution? thank you very much |
01-02-2022, 04:32 PM | #3 |
Rep 1,483
1qt every 200 miles is A LOT even if you had leaks!
Turbo? All PCV connected properly? Any oil in intake? How is coolant looking? Any milkshake? Smoke? |
01-02-2022, 05:36 PM | #4 | |
Rep 5,393
01-03-2022, 12:27 PM | #5 |
Rep 7,598
Yeah 1 quart in 200 miles would either show up as a big leak or should show evidence of being burned. Check your CP for oil to see if it is making it through the inlet/turbo/TIC/IC/CP.
01-03-2022, 04:17 PM | #6 |
Rep 16,075
If it's a leak there should be oil on your garage floor or driveway. Burning that much should be seen as smoke in the exhaust, especially at start up.
