12-03-2018, 12:00 PM | #23 | |
Cheapskate
4450
Rep 4,993
12-03-2018, 01:55 PM | #24 |
Rep 1,291
Yes indeed, steering rack only for RWD but also front driving axles for X-drive are extended too much as well.
What I think is important to understand is that many people thought they could swap parts between the F80 and the F30 like they used to with the E9x, but that's not true, the E9x M3 shared the same subframe as its siblings and therefore swapping parts sort of made sense. On the F80 platform the subframes have been completely redesigned and are very different from the F30, sharing only the 4 main frame attachment points, and little else, which means the control arms were designed totally differently for a different subframe. Which leads me to share my conclusion that for your own safety, don't do it and stick to F30 designed parts, OEM or aftermarket, this is your life you're dealing with and possibly that of your passengers/family - sorry to be such a killjoy on that matter
2017 M550i | Sophistograu
kern4174449.50 |
12-03-2018, 02:00 PM | #25 | |
Rep 891
sspade2466.00 |
12-03-2018, 02:01 PM | #26 |
Rep 1,291
MacklinUSOB518.00 |
12-03-2018, 02:04 PM | #27 | ||
Rep 5,457
Example, Im running an F80 connecting support and it fit perfectly. |
12-03-2018, 02:11 PM | #28 |
Rep 1,291
Yeah, perhaps there's something specific to my car that makes it more of an issue, go figure... I just know i'm not going back there, but if it works for you then that's great, just wanted to share that bad experience - which is a shame to be honest because turn in was improved so much by this mod... which is why i'm about to give a try to camber plates now, hoping to find a way to add camber that my chassis will tolerate.
MacklinUSOB518.00 sspade2466.00 |
12-03-2018, 02:51 PM | #29 |
Cheapskate
4450
Rep 4,993
I think the added caster was enough to make me shy away, even on my rwd car. The alignment shouldn't be so far off on a part that is supposed to be an improvement.
12-03-2018, 02:58 PM | #30 |
Rep 5,457
Have you guys looked into any aftermarket arms made for F30?
TRW makes a very nice set of upper/lower (4pc total) arms for F30. Probably made to OEM spec but at the same time... a guaranteed improvement in feel over tired factory arms. Im considering those as well. I like to do a lot of research and contemplation before deciding... What is your guys opinion on when factory arms/bushings wear out and should be replaced? Under normal conditions. Im going to throw some sway bar end links on soon (front). Also interested in aftermarket options... anyone have any? Leaning towards this set from MEYLE. |
12-03-2018, 06:40 PM | #31 | |
Rep 891
Just to clarify, comment wasn't to promote the mod. If it ain't for you, it ain't for you. Only know caster increase isn't something easily escaped when chasing camber increases.
12-04-2018, 07:06 AM | #32 |
Rep 137
12-04-2018, 07:15 AM | #33 | |
Rep 5,457
^this is for one side. Need two of these kits for complete job (L&R) |
12-04-2018, 07:16 AM | #34 | |
Rep 137
12-04-2018, 07:19 AM | #35 | ||
Rep 5,457
Regardless, Im sure a set of these on any car thats 50k miles or older would be a noticeable improvement in tightness of steering feel / stability. |
12-04-2018, 07:38 AM | #36 | |
Cheapskate
4450
Rep 4,993
12-04-2018, 10:20 AM | #37 | ||
Rep 891
kern4174449.50 |
12-04-2018, 11:18 AM | #38 | |||
Rep 5,457
The LCA on a F80 is called a tension strut. And other arm is called a wishbone. Or is it the other way around?! Can you please confirm exactly which part numbers you have installed? Its very easy to loose track of what we are talking about when everyone uses different/incorrect terminology. |
12-04-2018, 11:54 AM | #39 | |
Rep 3,947
I have the M Performance Suspension kit which increased the negative camber a bit to around -0.5. I'm hoping the wheel hub carriers and aftermarket bushings may be able to get it to -1.5. Summit Point Shenandoah Circuit really destroys the outer edges of your tires. |
kern4174449.50 |
12-04-2018, 12:26 PM | #40 | |
Rep 891
Left - 31122284529 Right - 31122284530 #9 is the part referred to as a Tension Strut or Front/Forward Control Arm because it is responsible for suspension tension and is the forwardmost mounted. Left - 31122284531 Right - 31122284532 The term wishbone can be used for either of these and often is. Traditionally, a wishbone is a triangle shaped control arm with three mounting points, like a horseshoe where a control arm has one single axis mounting point with a swivel joint on the other end. Lots of blurred lines with these terms, can't blame anybody for getting mixed up.
sspade2466.00 |
03-05-2019, 12:18 AM | #41 |
Rep 1,291
One year later...
The eccentric bushings don’t hold in place, getting a correct geometry was a nightmare as alignment went off ; Bushings were making a cracking noise (needs lubricant regularly) *and* they were softer than stock for control arms at least. Superpro bushings are gone, replaced with - stock control arms - monoball on tension struts Much better now; so i don’t advise going for these as you can guess. Bottom line is i did not find a reliable way to increase negative camber - other than lowering the car. |
03-05-2019, 11:43 AM | #42 | |
Cheapskate
4450
Rep 4,993
03-05-2019, 07:04 PM | #43 | |
Rep 241
I am looking at addressing the TSs next. can you explain why you did the monoballs vs the F80 TS? also, which monoballs kit did you use? regarding your issues with stability with the LCAs, is it possible you just got a botched alignment? your syptoms sound alot like some toe out may have gotten dialed incombined with increased camber from the LCAs which would make things pretty darty. my experience with the LCAs has been very favorable. |
03-06-2019, 08:12 AM | #44 | ||
Rep 1,291
F80 tension struts are actually the same length as f30, but the bushing is not as wide, so i'd say changing these is a waste of time. The uniball i got is a millway http://www.millway.se/front-control-...w-f2x-f3x.html I like this setup now, more reliable than superpro, crisp feeling too, although still lack negative camber :-/ You may well be right about the alignment being wrong originally with f80 Lower control arms, i also suspect the car's built in cross caster/cross camber could play a role (0.30 each, within tolerance but who knows...) but now with the lower KW suspension with LCAs it leads to rubbing on the wheel pit (right side only) so i gave up...
