06-04-2018, 10:39 PM | #133 | |
Rep 10,473
06-04-2018, 11:56 PM | #134 |
587
Rep 898
I believe vigilante actually got his DME updated before activating BM3. Unfortunately I can't tell via BM3... as their rom version identifier is a bit different than what's in the actual HEX files.
With that said... My channel to Halim went through and he got the maps updated. Sending him the Burble map now
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
06-05-2018, 12:44 AM | #135 | |
Rep 10,473
06-05-2018, 10:43 AM | #136 |
Rep 488
I believe I'm currently on iStep F020-17-03-505 (maybe slightly newer). I update with ISTA semi-regularly.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
IK6SPEED4488.00 |
06-05-2018, 06:18 PM | #137 |
Rep 74
I finally got the Burble... yay 😁
first off thanks to Cookiesown and BM3 support. my car had the old DME version not supported by BM3 but they hooked me up to Mark Rice.. great guy he did the update on my DME and then I was able to activate my car on BM3 but then it turned out that there were some issues with the tables but amazing support from BM3 and Cookiesown I had a map overnight. I think this is a good start and after fine tunnig the Burble we can move towards a tune soon. BM3 flashing is fun 😀 Thanks guys |
06-05-2018, 10:43 PM | #139 | |
Rep 10,473
06-06-2018, 12:37 AM | #140 |
Rep 110
So I found out that my front left strut is leaking and the replacement part is almost $600. I was wondering if anyone here has had to replace their struts and if there is a less expensive alternative.
06-06-2018, 08:14 AM | #142 | |
Rep 10,473
On main screen. Old, but shows where it is. Last edited by IK6SPEED; 06-06-2018 at 06:28 PM.. |
06-06-2018, 08:47 AM | #143 | |
Rep 488
$5 cheaper on FCP with that lifetime replacement guarantee: https://www.fcpeuro.com/products/bmw...mw-31316874378 That is assuming you're actually talking about the strut, which is part #1 in this diagram: http://www.realoem.com/bmw/enUS/show...diagId=31_0972
06-06-2018, 12:03 PM | #144 | |
Rep 10,473
http://www.realoem.com/bmw/enUS/show...diagId=31_0956 |
afranke207.00 |
06-06-2018, 12:16 PM | #145 | ||
Rep 110
06-06-2018, 04:52 PM | #146 |
Rep 74
Here is the exhaust sound clip Thanks to CookiesOwn |
cookiesowns587.00 |
06-06-2018, 06:39 PM | #147 |
Rep 10,473
Bootmod 3 for $475 new today with eBay Coupon today
Guess I can give cookiesowns a unmodified AH3 file if he’s interested and then start making mods. Guess from that standpoint it’s good I didn’t even install my ER CP yet so I really have an unmodified 2013 PWG I can log for him first. |
06-06-2018, 11:58 PM | #148 | |
587
Rep 898
So.... that burbles is definitely not a representation of how I usually do mine. We're missing a few switches for "burble" settings that really change how they work & sound... Halim is working on porting out some of the AH3 and older PWG ROMs, so this should come soon enough.
Update: It appears Halim updated some tables... sent him a new revision Update2: Those burbles actually seem a tiny bit tinny due to the fact that he has an aggressive exhaust setup and decat I believe. So I can probably tune it back and mess with durations to make it sound a bit better. Quote:
I have 2 different ROM's already for AH3. One from franke, and one from vigilante. It would be great if we can start with a totally unmodified car, and work up from there slowly increasing power and etc.
06-07-2018, 02:55 AM | #149 | |
Rep 74
Very excited to try out the new revision. Will flash and hopefully try to upload sound clips tonite. Its a great thing that Cookiesown and BM3 are coming up with support so quickly. I would like to request all who want to tune to get involved. If we can have an unmodified car and the 2 that are already there maybe we can have OTS maps very soon for our cars. |
06-07-2018, 09:29 AM | #150 |
Rep 488
Hey cookiesowns, could you add those burbles to my stock tune as well? I just got my yearly inspection notice, so I need to flash back to stock for a bit to get the monitors in a ready state. Now that I'm back to work from paternity leave, I'll be able to actually provide you logs as well. Thanks a ton!
06-07-2018, 02:07 PM | #151 | |
Rep 10,473
Not sure when I should get ER CP I have here installed, but one step at a time. My laptop hard drive failed so that’s out of commission at the moment. I have a workstation on my Garage bench with eSys etc. Does computer need to be connected to car in real-time for logging? Last edited by IK6SPEED; 06-07-2018 at 02:15 PM.. |
06-08-2018, 06:33 AM | #153 | ||
587
Rep 898
No, do not run Ethanol mix on high octane maps, as the calibrations are quite different. You will get HPFP dips almost 100%, as the ethanol mixes generally target similar amounts of boost to 93octane ( US Octane ) but with tweaked AFR ( slightly leaner ) and more timing to get the power. Quote:
Just hit Request custom on the "My maps section" And pick my tuner name in there. should be under "JWTuned"
06-08-2018, 08:05 AM | #154 | |
Rep 74
