01-22-2024, 01:10 AM | #1 |
![]() ![]() 157
Rep 238
Drives: 340i xDrive Stage 1
Mechanical Turn Signal Stalk Retrofit Guide F30
Hi all!
I don't know about yall, but I prefer a normal turn signal stalk. Just fitted my 2016 340i xDrive with a 2018 MY mechanical turn signal stalk steering column switch unit(SZL). The new one feels less plasticy and more premium actually. Quite an extensive DIY, I will be documenting it here. Before you start, buy a column switch unit that matches your car's option, ie. heated steering wheel, rain sensor, HBA, etc. Then make sure it is from F30, F20, F8X, compatible platforms. If not, you might need to transfer additional switch units which can be a hassle. First, you can't just put it in. If your did not came with the "normal" turn signal stalk, then chances are your FEM module's firmware does not support the newer stalk. A firmware update is necessary. So, both FEM_Body and FEM_GW need to be updated to at least late 2018 I-Step using E-Sys. I went from a I-Step of 2016 ish to 2023(only flashed FEM). Shawn has extensive E-Sys guides on how to update firmware, follow his instructions carefully, flashing modules can be dangerous. I used both an ICOM and a PSU. Secondly, once you flashed the FEM, now you have additional coding options to choose from in SZL_VARIANTE list. This can be done easily in Bimmercode. Here are the coding changes: - FS_TYP_SZL to rastend - WW_SZL_TYPE to rastend - LIN_VARIANTE_SZL to same as you have but with _r_ in name. For those of us in the US of A, you also need to find the variant that has "_us_" in it as well. BTW, "rastend" means resting. Lastly, to install it, there's plenty of YT videos showing how to take apart the steering column. However, there are two things I'd like to stress, if u have heated steering wheel, then there will be a white plug on the back of the column switch, it is very difficult to remove, you probably need a needle plier to get it out, just be careful with it. There's also a main plug that has a latch on it, similar to the DME plugs, it has to be plugged in while the column switch has not been mounted yet, also the latch needs to be fully up while you plug it in. Hope this helps! |
02-06-2024, 02:35 PM | #2 | |
![]() 106
Rep 228
02-06-2024, 05:49 PM | #3 |
![]() ![]() 157
Rep 238
Yep, you should have all the coding values in your bimmercode app. Like this was my self centering coding value originally.
02-06-2024, 05:52 PM | #4 |
![]() 106
Rep 228
You are a hero! I have a fellow member here with an LCI and me (prelci w/latest iStep) are trying to swap configurations.
I don’t suppose you know if this setup also codes the mechanical wiper stalk would you? |
02-06-2024, 08:04 PM | #5 | |
![]() ![]() 157
Rep 238
For your case: - FS_TYP_SZL from rastend to none - WW_SZL_TYPE from rastend to none - LIN_VARIANTE_SZL to same as you have but without _r_ or _us_ in name. Like the iPhone screenshot I showed before, that is for the self-returning coding for this variable in my car. |
01-16-2025, 05:33 AM | #6 | |
Rep 15
Can you give me the szl value? my szl_aic_4Band_fla wert 08 lci szl_r_aic_FLA_4BAND wert ?? Because it appears as an Unknown Parameters in FEM BODY . That's why I can't choose I will code according to wert value thank you. |
02-15-2025, 01:07 PM | #7 |
![]() ![]() ![]() ![]() 596
Rep 684
Drives: Break My Wallet
I'm thinking of doing this retrofit for a base F30 320i. Slick top ftw.
What are the part numbers necessary for the job? |
02-16-2025, 06:25 PM | #8 |
![]() ![]() 157
Rep 238
Without knowing your car’s current options, I really don’t know which part number is right for you. If you do a couple of google searches you can find a couple of threads detailing different part numbers required for different options.
