BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Update i-step version help.
      02-15-2025, 07:31 AM   #1
triiinh
Drives: 2017 BMW 340ix
I have been experiencing the issues outline in this TIS: https://static.nhtsa.gov/odi/tsbs/20...36333-9999.pdf
I took my car (2017 F30) to an indy shop to get the software updated and they could not connect to the car and perform the update (after trying for almost a week).
So last ditch effort is to try it myself before taking it to the dealer. I'm troubleshooting why the car wouldn't be able to make a connection. What should I be checking? Right now all I can think of is the fuses in the car's OBD port and disconnecting my third party wi-fi antenna.
Any advice or pointers would be appreciated.
      02-15-2025, 09:00 AM   #2
Homersbud
Drives: BMW X1
no info provided as to what you are trying to use to connect to the car - enet? icom? are you trying with ista? esys?
wifi antenna would have nothing to do with obd port. the issue could be the obd port itself but without any valid info, hard to troubleshoot.
      02-15-2025, 10:24 AM   #3
Siki78
Siki78's Avatar
200
Drives: F30,G30
Maybe you should check fuse 12 on FEM
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      02-15-2025, 02:16 PM   #4
triiinh
Yes, sorry. I am connecting using ENET cable. Esys + ISTA (full) for the install.
      02-15-2025, 02:16 PM   #5
triiinh
I'll take a look, thanks!
