BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Cant get 2TB to work
proTUNING Freaks
      02-15-2025, 03:41 PM   #1
Driversaid
Driversaid's Avatar
Lithuania
Drives: F30 320d, E32 735i
Hello, i have done this on several cars successfully, but i’m trying to code 2TB on 2012 318d, changed 205 to 2TB in VO, coded EGS and ICM, nothing still shows “DS” shifts arent fast and paddles doesnt work, checked FDL sportschalter and sportschalter_alt active everything looks good, still only “DS” no “S1” etc, coded paddles in FEM, it works(sport edition so it was probably prewired) but 2TB doesnt work, it comes up in E-sys and ISTA but doesnt work as supposed
      02-15-2025, 07:15 PM   #2
ultimate-tester
Drives: BMW F25 xDrive28i
Did you also code FEM_BODY, ICM, KOMBI and EGS after VO change?
      02-15-2025, 11:32 PM   #3
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
I did mine with Bimmercode. Two steps on two separate ECUs. Two of these: EGS, ICM, KOMBI.
Module -------------- Section -------------- Function ------------Value ------------ Default --------------- Comment
KOMBI ------3000 -------FDS_MENUE_TEXT_1/2/3/4 -------menue_3 -----menue_4 -------- Enables Image of Sport + on KOMBI
KOMBI ------3000 -----FDS_MENUE_SIGNAL_1/2/3/4 -----menue_3 -------menue_4 ------ Enables Image of Sport + on KOMBI
EGS -------3000 -------------Applikation_LC / LC --------aktiv --------nicht_aktiv ------Enable Launch Control (Sport Auto Tranny Required [In VO Coding])
HU_CIC -----------3000 -------------EFF_DYN_SPORT_CID -------------aktiv -------------nicht_aktiv ---------------Enables Sports Displays on non-Navi iDrive. (Doesn't work for diesel.)
HU_CIC -----------3000 -------------EFF_DYN_SPORT_UNIT ------------aktiv-------------- nicht_aktiv ---------------Adds Sports Display units in the Language/Units settings menu
HU_NBT -----------3000 -------------Macro_fds -----------popup_and_config ------------popup_only ----------------Configure sport mode in iDrive (Part 1)
ICM -----------3000 -------------ICMKOD_B_SPORTINDIVIDUALISIERBAR -----------ein (01) -----------aus (00) -----------Configure sport mode in iDrive (Part 2) (Optional for HU_CIC)
ICM------------- 3000 --------------ICMKOD_B_SPORTLENKUNG ----------aktiv -----------nicht_aktiv-------------- Enables Sport+ mode (Not Necessary with Sport Auto Tranny)
Assuming that you did the ESys FA coding correctly:
https://f30.bimmerpost.com/forums/sh....php?t=1219013
      02-16-2025, 07:14 AM   #4
Driversaid
Driversaid's Avatar
Lithuania
Coded EGS and ICM, on other cars i got S1 S2 etc just by coding EGS,
I didnt code kombi as it came with Sport+, havent coded FEM
