09-29-2018, 06:10 AM | #23 |
![]() 7
Rep 58
Hi again Shawn, I did a retrofit in my bmw i3 adding 5at. I installed the kafas ecu and changed the windscreen. A friend got a fsc code from a russian guy and the 5at worked fine. Can i export the fsc code to avoid losing it after dealer programming? using esys? thanks.
F33 420d, E34 525 tds
09-29-2018, 08:30 AM | #24 | |
![]() ![]() ![]() ![]() ![]() ![]() 11844
Rep 45,705
![]() 2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
10-05-2018, 03:07 PM | #26 |
Rep 45,705
PM sent.
01-09-2019, 02:52 AM | #27 | |
Rep 21
I understood that ISTA/P doesn't delete the FSC code but rather cancels it, and according to you there's some "repair" process to get its status from "cancelled" to "accepted". So I guess that status is at the Car/ECU level and has nothing to do with BMW AG's servers, because the Car doesn't connect to a server in real time to check the FSC codes (it happens only during the Measures Plan). You say that some people can generate FSC codes regardless of the Car's original factory options. But what I still don't understand is where these FSC codes come from. Are they coming somehow through BMW or are there people who managed to "reverse engineer" the generators and can generate the FSC Codes independently from BMW? Let's say I purchase a CarPlay activation somewhere (since anyhow in my country the option isn't available even with the S609), would that code somehow come from BMW? I'm asking because many of the guys selling FSC Code in eBay ask you to send the correct VIN and say that they would have purchased the code even if you send a incorrect VIN, and thus cannot generate it back for you since they already paid it? So, from whom do they get it? Also, I have read somewhere in the forums that dealers/BMW do not use FSC codes but rather use provisioning, which contradicts the fact that my dealer will use an FSC code to enable Navigation once I chose which one I want (Europe or North Africa) and the information and PDF in this thread. So I believe what they meant by provisioning is the fact the dealer provisions the FSC code purchase in BMW's ASAP portal as opposed to external sources that generate the codes without provisioning them into BMW's systems? Last edited by Soussef24; 01-09-2019 at 03:12 AM.. Reason: precision |
chr12.00 |
01-09-2019, 02:57 PM | #28 | |
Rep 45,705
That said, in general, you can get new OEM FSC Codes issued for your car's VIN from BMW AG, if you are willing to pay insanely high prices for them. You can always use already issued OEM FSC Codes from another VIN, and then use Emulator hardware to trick car into thinking Donor FSC Code VIN matches car VIN. Beyond that, for some Head Units such as CIC, NBT, and NBT2, it is possible to "patch" head unit to accept generated non-OEM FSC Codes. When you deal with sellers, many of which are simply re-sellers, they have costs and or labor on their side. If one provides Seller wrong VIN and they deliver their product, they should not expect free replacement as whatever cost structure they have on their side will be repeated to make a replacement. As for Provisioning in lieu of FSC Codes, this is applicable only for BMW Apps and CarPlay and in certain Head Units, not all. Cars with factory Option 6AK Connected Drive Services (BMW Apps) and 6CP CarPlay get enabled by BMW AG via Provisioning, not FSC Code. For non-factory solution, FSC Codes can be used in lieu of the Provisioning. In the case of BMW Apps, that FSC Code can be either OEM or non-OEM; however, in case of CarPlay, that FSC Code is almost always non-OEM, as BMW AG will not sell CarPlay FSC Code.
10-30-2019, 03:38 PM | #30 |
Rep 45,705
PM sent.
jimmy8904564.50 |
10-30-2019, 09:11 PM | #31 |
![]() ![]() 301
Rep 2,215
Hi Shawn, I have same request for Car Play in my car as well. Send a PM please.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
10-30-2019, 09:59 PM | #32 |
Rep 45,705
PM sent.
10-30-2019, 11:35 PM | #33 |
![]() 4529
Rep 10,472
What is the most cost efficient way to replace all the OEM FSC codes for a specific NBT EVO HU that has lost its provisioning without going to a Dealer?
10-30-2019, 11:42 PM | #34 |
Rep 45,705
Provisioning of SIM is Telematic Function, and has nothing to do with any FSC Codes.
IK6SPEED4528.50 |
10-30-2019, 11:43 PM | #35 | |
![]() 4529
Rep 10,472
![]() Let me ask it another way.... Car's NBT EVO HU has gone out. One purchases a replacement unit and changes the VIN to match original VIN. Car OEM has: S609A Navigation System Professional S610A HEADUP DISPLAY S655A Radio Bavaria C Business S688A HARMANKARDON SURROUND SOUND SYSTEM S697A AreaCode 1 For DVD S6ACA INTELLIGENTER NOTRUF S6AEA TELESERVICES S6AKA CONNECTEDDRIVE SERVICES S6AMA REAL TIME TRAFFIC INFORMATION S6APA REMOTE SERVICES S645A BMW US Radio The esim in the ATM contains the info to reactivate these features with no other intervention? Last edited by IK6SPEED; 11-23-2019 at 01:12 AM.. |
10-31-2019, 08:59 AM | #36 | |
Rep 45,705
IK6SPEED4528.50 |
10-31-2019, 03:48 PM | #37 | ||
![]() 4529
Rep 10,472
10-31-2019, 05:34 PM | #38 |
Rep 45,705
You do.
Depending on your vehicle’s Model Year and Make, navigate to “BMW Assist”, “ConnectedDrive” or “Apps” using your iDrive controller. Under BMW Assist or ConnectedDrive: - Open “Options” (physical button surrounding your iDrive controller). - Click on “Update BMW Assist”. Under Apps: - Click on “All Apps”. - Open “Options” (physical button surrounding your iDrive controller) - Click on “Update apps and services” Then allow time for car to receive Provisioning Signal.
IK6SPEED4528.50 |
01-22-2020, 05:01 PM | #39 |
![]() ![]() ![]() 186
Rep 476
Do you know if say 6CP was VO coded and then you updated the services on your idrive, would carplay show up in connected drive store for sale? ( Currently showing "not available for your vehicle")
Thanks |
01-22-2020, 05:11 PM | #40 |
Rep 45,705
It won't have any affect on what appears in store.
xpro186.00 |
03-09-2020, 06:01 PM | #42 |
Rep 45,705
PM sent.
03-10-2020, 02:14 AM | #43 |
Rep 476
Shawn,
Could you please tell me how to enable CP to full screen? I have older firmware and I will flash to the latest one. Will this alone make it go full screen or is there an additional coding required to get it full screen? Many Thanks Phil |
06-04-2020, 04:31 PM | #44 |
Rep 7
