11-02-2020, 04:31 PM | #45 |
Rep 23
They do work they are just a pain to get on right if you go in with the whole bulb. It will be loose if you do it that way and try to install the whole led at once, My best approach was using only the little removable tab from the bulb and the H7 adapter first. Match them together remove the front tire for more work space and visibility and install it making sure both sides are hooked on tight. I did use nose plyers today on each side to make sure they were real tight in there then slide in the led bulb all the way in no need to twist or anything and u should be good to go.
11-18-2020, 12:08 AM | #46 |
Rep 92
Update: ditching the 360 LEDs!
Hey guys, something that's been bugging me about the 360 degree LEDs is that the beam is not focused. So it looks very bright up front and dim in the distance. I decided to try out the Sylvania ZEVO H7 from autozone after watching this:
I must say, even though this LED is a lot lower power, the actual output is better. The beam is focused and on the road it lights up evenly from infront of the car to the distance, which is how it is supposed to be! I put together a few pics, the ones on the right are with the ZEVO led. You can see that the 360 is super bright up front but the brightness drops off in the distance. This caused me a lot of fatigue trying to look ahead when driving for extended periods at night. These videos were super educational as well: 1. About Multi-sided/360 LEDs: 2. General info on why LEDs need to be shaped a certain way: |
11-18-2020, 08:22 AM | #47 |
Rep 16,054
I'm sure the Zevo works well, Sylvania wouldn't sell it otherwise, but I doubt it works better than the LEDs I have that cost 1/3 what the Zevo do. The information in the videos about 360 degree LEDs is useful and accurate, but it's not new. I found similar videos when I was researching LEDs five years ago.
The third video does have some misinformation. They recommend fan heatsinks, which are known to have a high failure rate. Passive heatsinks can't fail. It's true that the highest output LEDs need fan cooling, but the highest output LEDs aren't necessary. Lower output passive cooled LEDs are still on average three times brighter than halogen. |
navid030840.00 |
11-18-2020, 09:29 AM | #48 | |
Rep 92
11-18-2020, 11:31 AM | #49 |
Rep 16,054
Most of the wattages listed for LEDs are fake, to take advantage of the uninformed. Wattage doesn't measure light output, it measures power consumption. Since LEDs are more efficient than incandescent they produce far more light with far less power consumption. One average a 15 watt LED produces as much light output as a 100 watt incandescent.
Bmwkurdos1.50 |
03-22-2021, 03:04 PM | #50 |
Rep 1
Did not fit Depo V3 and BMW 2015 328i
Yo. I purchased the Light Moses 360 bulbs for low beams and the recommended retainer clips, and the bulb does not fit the retainer clips. Tried installing the retainer clip upside down, as mentioned in this thread and recommended installation process. I also tried installing the retainer clips right side up...But the bulbs are just too loose. I've been looking around for other retainer clips, they all look the same.
Can anyone recommend retainer clips that are known to work for Light Moses 360 degree bulbs & Depo V3 Projector headlights? I've contacted the Light Moses support, so far no answer. But I'll give it a few days. |
04-18-2021, 01:36 AM | #51 | |
Rep 92
05-07-2021, 07:48 AM | #52 |
Rep 16,054
I can't say if they will fit, but I wouldn't buy them. The only thing LED about them are the imitation Angel Eyes. The bulbs used are still H7 incandescent.
05-07-2021, 10:39 AM | #53 |
Rep 16,054
I can't recommend any from experience. I was dissatisfied with how my H7 headlights worked, I replaced the halogen bulbs with LED, problem solved. These may be OK, but I'd only buy them after seeing a verified review by someone who has them.
Bmwkurdos1.50 |
05-30-2021, 01:35 PM | #54 |
Rep 16
Do you have the depo projector headlights or factory halogen? What led bulbs did you use?
05-30-2021, 02:32 PM | #55 |
Rep 16,054
05-31-2021, 04:53 PM | #56 |
Rep 16
My apologies Bill as I am unsure who/what this was in response to. What are you saying is not true LED? Are you referencing the Light Moses bulbs discussed in this thread, the Depot headlights in general, or something else? I was considering trying the setup discussed in this thread/using the Light Moses in my Depot's, but don't want to bother if they are not truly LED's. I ask you, as I respect your opinion and was a bit confused as to what you were referencing in the above quote. Thanks, J.C
05-31-2021, 05:37 PM | #57 |
Rep 16,054
I don't know who the replies were to, a couple of posts were deleted, probably by whoever posted them. It was probably in reference to a complete replacement headlamp that advertises as being LED, but when you look at the details only the angels eyes are LED, while the rest of the bulbs are not. The Light Moses bulbs may be OK, only someone who has them can say for sure. I'm not wild about fan cooled bulbs, though.
07-20-2021, 05:31 PM | #58 | |
Rep 4
Hey, bro. Thank you for your advice. Could you provide the link to your ZEVO LED? I can only find SYLVANIA - H7 LED Fog Light from Amazon, I am sure if it's the one you said. Btw, do you use them for both low and high beams? |
07-25-2021, 02:48 PM | #59 | |||
Rep 16
Help needed with Light Moses LED's in USR Depot Projectors F30
I pulled the trigger on the same led's and adapter myself and what a pain in the a** they have proven to be. I've quoted several other users in this thread to hopefully gain some attention from others who have seemingly had success in this endeavor. For starters, I pulled the wheels as I do not see how you could do this without the extra room to work. Let me ask you in the photo is the led collar facing inside the headlight housing or does it protrude outwards or outside the housing(if that makes any sense) In the photo it looks as if it is placed inside the housing. I struggled a great deal with my install and am still uncertain that I have it correct. My beam pattern is way off and for whatever reason I can not adjust it. If I do go to adjust it the led falls out of housing on one side while the other side won't move at all using a screwdriver. I question whether or not I installed them correctly, well obviously I did not. Heck, I had to break the original halogen bulbs just to remove them. I watched a video that showed a simple left twist would remove them. Mine were super tight. I attempted to loosen the two screws, one on each side, to see if that would help, and ended up stripping both screws out. After I eventually removed the halogens and the halogen adapter, I struggled placing the collar and adapter into the housing. I fitted the adapter and the collar together, then eventually got them as close to the photo as I could. I placed the collar on the inside of the housing. When I say "inside" I mean inside the bulb housing with the adapter at its' back. Looking at your photo I can not tell for sure if you did yours the same way or not. It looks as if you did, but it's just difficult to tell for sure. It was a real pain getting the adapter and collar to fit into the low beam little round metal ring in headlight. Any hints, tips, or tricks still appreciated as I will likely have to re-do what I've already done. Oh, yea, not to mention I get a low beam error message upon every start up. This is something I believe/hope that I can and will "code" out as I have everything I need to do so I just have yet to do it. Apart from the error message and the really bad beam pattern that I can not seem to aim/level, the led's work just fine If I could get them to level out I'd be satisfied yet can't drive around at night with one headlight aimed 4 foot higher than the other. When I went to aim them, I initially had no issues, they seemed to be aligning using a screwdriver, until they simply stopped and the screwdriver method began to prove pointless as it had no effect on raising or lowering them. Hopefully, this made some sense as it's difficult to articulate when there doesn't seem to be any set terminology, at least that I am aware of, for all the parts of the headlight and everyone uses different words for different parts( it gets confusing) OK if anyone can make any sense of this and provide any insight/knowledge it would be greatly appreciated. Last edited by jodyc256; 07-26-2021 at 10:55 AM.. |
07-26-2021, 12:53 PM | #60 | |
Rep 16
07-27-2021, 11:06 AM | #61 |
Rep 576
08-28-2021, 02:55 AM | #62 |
Rep 2
Hi chaps. I know this post was last year but any ideas how to get LED bulbs to lock into the Depo headlight unit. I finally found a set that seemed to be secure but after a week I found both had dropped out.
I’ve got the metal bulb holders but they just spin around the bulb base fan and won’t click in. 🤷*♂️ |
09-18-2021, 09:42 PM | #63 |
You got my money?
3120
Rep 4,640
Drives: Ice Cream Truck
I just bought a 2013 328I for a daily beater. I have bimmer code.
Can I just get these amazon LED bulbs for FACTORY headlights? https://www.amazon.com/gp/product/B0...=AS346V861QKU1 And use my bimmercode app to remove the checking? Or should I get the sylvania zevos?
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
09-19-2021, 08:29 AM | #64 |
Rep 16,054
I wouldn't recommend a fan cooled bulb, the fans are a weak point. Passive cooled bulbs are two to three times as bright as halogen, so there's no need for a bulb that requires fan cooling. For instance: https://www.amazon.com/dp/B08K7353HW...xpY2s9dHJ1ZQ==
09-19-2021, 08:59 AM | #65 | |
You got my money?
3120
Rep 4,640
Thank you very much. If I order those. Do I need anything else? And if I want to replace the headlamps all together to get actual halo's. Do I get the DEPOs and just use these LED bulbs? Or do those headlamps take an entirely different bulb? My goal is try the LED in the stock housings. And or just buy new plug and play headlamps with real halos and maybe a projector lens. Thank you for your advice.
09-26-2021, 04:23 PM | #66 |
Rep 43
I was able to install the Moses H7 LED bulbs today. Was pretty easy to install, I had to remove my wheels for better access. I didn't need the adapter. See pictures here:
Remove metal sleeve from Moses bulb, install / secure that in back of headlights first. Once secure, gently push LED bulb into its sleeve, and it should be a tight fit. I'll update with night time pictures later. |
