07-18-2021, 07:57 PM | #1 |
Rep 31
Help! - N55 - New Plugs - Missfiring **RESOLVED**
***ISSUE RESOLVED ***
Update: Ordered the NGK 97506, installed with gap of .022 and everything is running amazing, no more miss-fires or anything. Thank you everyone for all the suggestions given, much appreciated!! Hello everyone, Vehicle: 2013 335i F30 - N55 Engine Mods: BM3 - Stage 1 Flash, BMS Intake, CP Prior Status: Vehicle was running absolutely great with no problems. Issue Now: Idles fine but step on the gas it throws a code, INSTA-D shows miss-fire on CYL1-2-4. Details: Preventive maintenance, replaced plugs from Parts Avatar and they listed the ZR5TPP33 as the replacement. I installed them with default gap and now I have all kinds of issues. I'm reading that plugs should have been ZR5TPP33S instead for the N55 but should it cause that much of an issue right from the start? If I rev slowly through RPM range no issue but floor it and it just choques up and throws code. Troubleshooting Done: Put factory plugs back in and now even those are making the car even worst then the ZR5TPP33. I don't understand what has changed and why the originals now are even worst. The gap is ok on the used plugs they were just sitting on my bench. Idles fine no problem only under heavy load again. I have reseated and re-tightened everything the ignition connections are all the way in and clipped properly. I have tried swapping coils and problem stays on the same cylinders. I've swapped spark plugs around and some problem seems to always hit 1-2-4 or sometimes just 2-4. I have tried gapping the ZR5TPP33 with 28, 26, 24 and 22 very carefully and nothing has resolved my issue. I understand there are some differences in the ZR5TPP33S plugs that should have been correct but what is troubling me the most is how the originals that had absolutely no problem what so ever are now not working either. I'm thinking of picking up the NGK 97506 plugs or maybe just getting them from BMW directly but before I spend more money I'm looking for some help here from anyone that might have any suggestions. I'm really stumped how the factory are not working and the job is very simple. Thank you, Rui
2013 BMW 335i
07-18-2021, 08:49 PM | #2 | |
1296
Rep 3,533
07-19-2021, 12:29 AM | #3 | ||
Rep 1,148
07-19-2021, 11:01 AM | #4 |
Rep 1,572
Concur with previous comments. First time I changed plugs on my 13 F30 335i, I had a similar issue. Found that I did not fully seat one of the electrical connectors before closing the latch. Also, if you applied any more than very minimal dielectric grease inside the boot, it may be slipping up off the plug and breaking contact.
BMW ZR5TPP33 Spark Plug - Bosch 0242145515 is the correct spark-plug for your car. https://www.fcpeuro.com/products/bmw...ch-12120037580 |
07-19-2021, 01:09 PM | #5 |
Rep 768
I have been an auto technician for over 20 years now. I have yet to ever see a single car that runs good on Bosch plugs. Not a single one. In fact Bosch plugs are just a no-no in the independent shop world.
07-19-2021, 06:01 PM | #6 | |
Rep 1,572
Maybe so, but from my experience with all the BMW's I have had since 2001, I've used the recommended Bosch Plugs with no issues. Guess I'm just lucky. |
07-19-2021, 06:08 PM | #7 | ||
Rep 1,148
Just did a swap recently with the revised Bosch with zero issues. |
07-20-2021, 01:12 AM | #9 |
@_sunbish
282
Rep 611
I wouldn’t be surprised if one of your ignition coils went bad.
Start the engine and let it catch a normal idle speed, while running unplug one ignition coil connector at a time and see if the idle speed changes. If it does react, move onto the next cylinder. If you find one that doesn’t cause an engine idle speed change, turn the engine off and swap that coil with one that did drop engine speed (known good coil) and see if the misfire follows the coil. |
07-20-2021, 06:12 AM | #10 |
Rep 10,351
ZR5TPP33 is the correct replacement plug. I have them on my 435i.
fwiw Bosch stopped selling the ZR5TPP33(S). almost 2 yrs ago.
"Drive more, worry less. "
07-20-2021, 10:55 AM | #11 |
Rep 31
Hi everyone,
Thank you for all the responses. I think over-all I re-installed plugs 4-5 times between factory and stock plugs. I was very careful to make sure the coils are pushed as far as they can go, I only ever did one coil at a time so no chance of mixing up connectors and I also tried swapping coils from cylinder 5 & 6 to 1 & 2 where I had the miss-fires and problem did not move so doesn't seem to be the coil. The coils are sitting in the grooves and connectors seem to be snapped in all the way into the coil as far as they go. With the new plugs only have any issues on hard acceleration other then that it runs fine but putting the old plugs multiple times through my testing the revving in neutral you can feel some of the hesitation. I'm kind of stumped, I've checked it so many times and make sure everything was pushed in properly on both coil and plugs. I've ordered the recommended NGK plugs just to have something else to try here but after speaking with bosh I coincidentally got a former BMW mechanic of 40 years who was telling me to try doing an adaptation reset on the computer, mentioned that I should test with the stock intake in it and wondering if something may have been disconnected like some vacuum line. He mentioned if I had the ability to check the adaptive fuel mixture values when highway travelling but this part is getting over my head. He even mentioned checking the oil filler cap if not seated properly and not enough vacuum or something could give me some issues as well. I'll recheck everything again today after work and see if I spot anything off. I did try one thing yesterday and replaced the miss-firing cylinder spark plugs with the new bosch instead of the factory BMW plugs and the neutral revving issue goes away but still miss-fires under heavy acceleration. I'd hate to think that I could mess up such an easy job especially being as careful as I man in nature but I agree something had to have changed.
2013 BMW 335i
07-20-2021, 12:59 PM | #12 | |
Rep 10,351
Perhaps damage the plugs? Also don't forget that the torque value for installing a used plug differs from a new plug. Let us know.
07-20-2021, 02:02 PM | #13 | |
Rep 31
I was using ISTA-D and would clear all codes every time I tried something new with the plugs to get fresh readings.I have attached some pictures of top view of ignition coils. I checked them all over again today and everything seems to be clipped properly. Thank you for your respone. Rui Order of images is LEFT - Cyl 2 - 1 MIDDLE - CYl 4 - 3 RIGHT - Cyl 6 -5 in that order.
2013 BMW 335i
F32Fleet3570.00 |
07-21-2021, 08:42 PM | #14 | ||
Rep 75
Drives: 2023 BMW X5 M50i
X5 M50I
07-22-2021, 08:14 AM | #15 |
Rep 31
Yes, that's right I figure when the fuel/air is at it's highest that the spark isn't good enough or something along those lines but I'm not an expert. The odd part again is that it was not doing it before switching out the plugs, it literally started immediately after. I have new NGK plugs hopefully arriving today so hoping to have some different results and I will post back once I've swapped them.
2013 BMW 335i
07-22-2021, 01:04 PM | #16 |
Rep 5,369
Might seem crazy but start the car and let it run and warm up fully. While in park/nuetral, disconnect the MAF sensor and let it run for 10 minutes or so. Turn the car off and reconnect the MAF. Then restart and see if you still have misfire issues.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
07-22-2021, 08:42 PM | #17 |
Rep 2,357
What was the problem???
(A Dane in China) |
n55david1295.50 Eschmacher334.50 |
07-23-2021, 07:39 AM | #20 |
1296
Rep 3,533
don't worry man, none of the shops I've worked would use bosch plugs either.
07-23-2021, 10:46 AM | #21 |
Rep 31
Yeah, I questioned everything I did, redid everything so many times over and all I had to do was put in the NGK plugs and I'm back in business without having to do anything else at all.
Once again, thank you to the community for the suggestions. I'm glad I decided to go with the recommendation of NGK plugs since nothing else made sense (special thanks to LA1Z24). Sounds like Bosch will refund me the money directly so that's a bonus. Thanks everyone!
2013 BMW 335i
F32Fleet3570.00 |
