07-27-2021, 09:49 PM | #1 |
Rep 142
Hey guys so I went to do a pull and scanned the car got this code 128901 I believe this is the primary o2 sensor correct? Just want to make sure I have the correct understanding before throwing a part at a problem. Screenshot below from bm3
Also took a log to see if anything odd is coming up. Got one knock event but I'm assuming bad gas since I had it happen before. Car is EWG, drop in intake/Catless/Race IC/Turbosmart BOV/Turbo inlet are the mods on BM3 multimap stage 2 running 93 on the 91 map Link is here: https://www.bootmod3.net/log?id=6100...90c64360f53c81 Car feels good at the moment. Any advice is appreciated
2017 M240i
CD919 Custom E40/flex fuel tune | catless downpipe | TU Pump | XHP Stage 3 | MHD flexfuel kit |
08-02-2021, 03:00 PM | #2 |
Rep 7,602
Yes that is the primary/upstream o2 sensor (before cat). And yes you have a knock in the log and in addition your timing looks pretty bad even after the knock, at higher RPM. I would log again on a fresh tank of gas.
09-24-2022, 02:24 PM | #3 |
Rep 738
Drives: '11 328xi |'18 440xi GranCoupe
I just got this same code, 128901. The car has 14K miles on it & is stock other than an MST intake & one resonator delete. I filled up with 93 Oct & 1 gallon of e85 2 days ago if that makes a difference.
Not sure what would cause this code. I cleared it but I haven't driven it to see if it comes back.
09-26-2022, 02:06 PM | #4 | |
Rep 7,602
09-27-2022, 06:52 AM | #5 | |
Rep 1,597
09-27-2022, 08:08 PM | #6 |
1296
Rep 3,533
E85 doesn't normally do that
03-02-2023, 06:36 PM | #7 |
Rep 738
Sorry, I’m just seeing this as I never got a notification of any responses. Funny enough, the code just came back and I started researching again and saw I commented here. No, I don’t have an N55, didn’t realize this was N55 section when I first commented, sorry.
